Hello good day
I would like to ask for your advice, I would need to process more msg.payload from several topics in 1 functional node and then publish it. I don't know how to parse it. I have multiple topics like mete/hum, meteo/temp, meteo/wind and each of them sending value by msg.payload. I need to catch these values and publish to domoticz/in in a single function node. Is that possible?
I have allready did somethinh like this, but it doesnt work
Hi, welcome to the forum.
NB: Best to show code in a pre-formatted text block </> rather than an image. It makes it easier to read and for people to copy/change/paste.
So I assume that you are getting multiple messages, each with a different msg.topic? And you want to do different processing depending on the topic?
If that is so, something like this might be helpful:
switch (msg.topic) {
case 'meteo/temp': {
break
case 'meteo/hum: {
break
default: {
// If you want to handle an unknown topic, you can use this section
break
return msg
But take care reusing the input msg as output as you will need to ensure that you are doing things in the right order. If in doubt, create a new msg with const msg2 = {} and set everything on that then do return msg2 at the end.
