Multiple URL posts in a single session
Hello everyone, I have a bit of a conundrum that I'm not sure why it is occuring.
I'm building a middleware of sorts to facilitate the communications of two systems. It's fairly straight forward and I've already had success in the past with similar flows using XML. This newer process is using JSON which shouldn't be an issue but for some reason when I get to the point of verification, the post is empty. Here is a high level overview of what is happening.
  • A. There is a local .net application is waiting for input from an application to generate HTTP XML post messages. The process is; Logon, perform a lookup, logoff.
  • B. There is a 3rd party REST service waiting to answer requests in JSON. Simply a
    logon and establish a session, perform a verification with results, and logoff
The Node-Red application I am building will basically intercept the local .net application request, translate it a JSON request for the REST service and answer back to the .net application based on the REST service response.
I have nodes built to take information from the lookup and transform it to a verification. The secondary service I am reaching out to requires a persistent session instead of relying on session identifiers. So I enabled the keep alive option on the login post with the goal of carrying it through the process. Once the process continually failed I created temporary listeners to capture both ends as troubleshooting the 3rd party service is impossible at the moment. I'm attaching a screenshot of what the nodes I used.
The problem is, I can initiate each process with the 3rd party separately using the inject nodes without issue. However, because they are using a persistent session instead of session identifiers the lookup fails as their system interprets it as a new request that is unauthenticated. If I link the nodes together and select the persistent session, the "Lookup" node is empty and there is no data being sent. Despite having a template with data, which works individually.
[{"id":"41ff3755.b19ca8","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"66b3b782.6963d8","type":"debug","z":"41ff3755.b19ca8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1270,"y":460,"wires":[]},{"id":"406bacff.fb36f4","type":"change","z":"41ff3755.b19ca8","name":"Headers","rules":[{"t":"set","p":"headers.accept","pt":"msg","to":"application/json","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":460,"wires":[["f8d927bc.098648"]]},{"id":"f8d927bc.098648","type":"DataOut","z":"41ff3755.b19ca8","collection":"34b6e44b.fe0f8c","name":"","path":"/id","error":false,"x":550,"y":460,"wires":[["e967f770.db7008"]]},{"id":"ab27c427.7efe38","type":"inject","z":"41ff3755.b19ca8","name":"ManualLookup","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":460,"wires":[["406bacff.fb36f4"]]},{"id":"b8875dd7.3aa7d","type":"delay","z":"41ff3755.b19ca8","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":880,"y":380,"wires":[["dbb73823.64c108","406bacff.fb36f4"]]},{"id":"72903cc2.eec954","type":"inject","z":"41ff3755.b19ca8","name":"ManualLogin","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":380,"wires":[["f32a76b4.272368"]]},{"id":"dbb73823.64c108","type":"debug","z":"41ff3755.b19ca8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1230,"y":380,"wires":[]},{"id":"f32a76b4.272368","type":"template","z":"41ff3755.b19ca8","name":"LogonTemplate","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"    {\n    \"userid\": \"TIBA\",\n    \"password\": \"Park2021!\"\n    }","output":"json","x":320,"y":380,"wires":[["febc37ac.441e58"]]},{"id":"febc37ac.441e58","type":"json","z":"41ff3755.b19ca8","name":"","property":"payload","action":"","pretty":false,"x":470,"y":380,"wires":[["560a14df.b0120c"]]},{"id":"c7353195.7fb7c","type":"json","z":"41ff3755.b19ca8","name":"","property":"payload","action":"","pretty":true,"x":730,"y":380,"wires":[["b8875dd7.3aa7d"]]},{"id":"560a14df.b0120c","type":"http request","z":"41ff3755.b19ca8","name":"LoginURL","method":"POST","ret":"txt","paytoqs":"query","url":"http://localhost:1880/listenerp","tls":"","persist":false,"proxy":"","authType":"","x":600,"y":380,"wires":[["c7353195.7fb7c"]]},{"id":"70fa72d.5a8628c","type":"http request","z":"41ff3755.b19ca8","name":"Lookup","method":"POST","ret":"txt","paytoqs":"query","url":"http://localhost:1880/listenerp1","tls":"","persist":false,"proxy":"","authType":"","x":1020,"y":460,"wires":[["66b3b782.6963d8","ee0ca639.a17ad8"]]},{"id":"e967f770.db7008","type":"template","z":"41ff3755.b19ca8","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n    \"actions\":[\n            {\n                \"method\": \"mark\",\n                \"params\": {\n                    \"ticket_number\": \"{{payload.visualid}}\"\n                }\n            }                \n    ],\n    \"set\":{\"Options::performance_ids\": \"\", \"Options::marking_options\": \"status\"},\n    \"get\":[\"Result\"],\n    \"objectname\": \"myticket\"\n}","output":"str","x":700,"y":460,"wires":[["1bacebec.6dec84"]]},{"id":"1bacebec.6dec84","type":"json","z":"41ff3755.b19ca8","name":"","property":"payload","action":"","pretty":true,"x":870,"y":460,"wires":[["70fa72d.5a8628c"]]},{"id":"ee0ca639.a17ad8","type":"http request","z":"41ff3755.b19ca8","name":"LogoffURL","method":"POST","ret":"txt","paytoqs":"ignore","url":"http://localhost:1880/listnerpl","tls":"","persist":false,"proxy":"","authType":"","x":510,"y":540,"wires":[["855c22e2.72cf9"]]},{"id":"855c22e2.72cf9","type":"json","z":"41ff3755.b19ca8","name":"","property":"payload","action":"","pretty":false,"x":650,"y":540,"wires":[["ce0c774a.eb7fb8"]]},{"id":"ce0c774a.eb7fb8","type":"debug","z":"41ff3755.b19ca8","name":"LogOffLog","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":990,"y":540,"wires":[]},{"id":"d9016124.c920c","type":"inject","z":"41ff3755.b19ca8","name":"ManualLogoff","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":540,"wires":[["ee0ca639.a17ad8"]]},{"id":"28582da.8b05dd2","type":"http in","z":"41ff3755.b19ca8","name":"PostListener","url":"/listenerp1","method":"post","upload":true,"swaggerDoc":"","x":150,"y":140,"wires":[["89518937.822028"]]},{"id":"f8792e9b.85569","type":"debug","z":"41ff3755.b19ca8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":730,"y":40,"wires":[]},{"id":"eaad1620.b8e128","type":"http response","z":"41ff3755.b19ca8","name":"","statusCode":"200","headers":{},"x":620,"y":140,"wires":[]},{"id":"89518937.822028","type":"template","z":"41ff3755.b19ca8","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\"version\":\"7.42.1\",\"session\":\"186816AE-D88F-4778-967D-4697FE7408B0\"}","output":"str","x":320,"y":140,"wires":[["1f0712fa.d8714d"]]},{"id":"1f0712fa.d8714d","type":"json","z":"41ff3755.b19ca8","name":"","property":"payload","action":"","pretty":false,"x":470,"y":140,"wires":[["eaad1620.b8e128","f8792e9b.85569"]]},{"id":"f549cec6.48f27","type":"http in","z":"41ff3755.b19ca8","name":"PostListener","url":"/listenerp11","method":"post","upload":true,"swaggerDoc":"","x":190,"y":280,"wires":[["7d6d6841.125698"]]},{"id":"2625bb99.afffb4","type":"debug","z":"41ff3755.b19ca8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":770,"y":180,"wires":[]},{"id":"7b0f1f51.4af84","type":"http response","z":"41ff3755.b19ca8","name":"","statusCode":"200","headers":{},"x":660,"y":280,"wires":[]},{"id":"7d6d6841.125698","type":"template","z":"41ff3755.b19ca8","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n    \"version\": \"7.42.1\",\n    \"session\": \"3E62F34B-4B9E-49C7-95D6-50A6BC89D5DB\",\n    \"data\": {\n        \"Result\": {\n            \"state\": \"0\",\n            \"colour\": {\n                \"standard\": \"#FF0000\",\n                \"input\": \"#FF0000\",\n                \"display\": \"#FF0000\"\n            },\n            \"mark_result\": {\n                \"standard\": \"The ticket number does not exist.\",\n                \"input\": \"The ticket number does not exist.\",\n                \"display\": \"The ticket number does not exist.\"\n            },\n            \"mark_cancel_reason\": {\n                \"standard\": \"\",\n                \"input\": \"\",\n                \"display\": \"\"\n            },\n            \"result_code\": {\n                \"standard\": \"5275\",\n                \"input\": \"5275\",\n                \"display\": \"5275\"\n            }\n        }\n    },\n    \"return\": [\n        {\n            \"method\": \"mark\",\n            \"message\": \"\"\n        }\n    ]\n}","output":"str","x":360,"y":280,"wires":[["8136370f.275028"]]},{"id":"8136370f.275028","type":"json","z":"41ff3755.b19ca8","name":"","property":"payload","action":"","pretty":false,"x":510,"y":280,"wires":[["7b0f1f51.4af84","2625bb99.afffb4"]]},{"id":"ceff341e.234628","type":"http in","z":"41ff3755.b19ca8","name":"PostListener","url":"/listenerpl","method":"post","upload":true,"swaggerDoc":"","x":930,"y":260,"wires":[["5bbfe558.0aac5c"]]},{"id":"98443f18.59563","type":"debug","z":"41ff3755.b19ca8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1510,"y":200,"wires":[]},{"id":"6848947e.7f1f7c","type":"http response","z":"41ff3755.b19ca8","name":"","statusCode":"200","headers":{},"x":1400,"y":260,"wires":[]},{"id":"5bbfe558.0aac5c","type":"template","z":"41ff3755.b19ca8","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n    \"version\": \"7.42.1\",\n    \"session\": \"A8894AF9-9768-4FAD-96DA-96D632D9BE3E\"\n}","output":"str","x":1100,"y":260,"wires":[["e888e7b7.1695f8"]]},{"id":"e888e7b7.1695f8","type":"json","z":"41ff3755.b19ca8","name":"","property":"payload","action":"","pretty":false,"x":1250,"y":260,"wires":[["6848947e.7f1f7c","98443f18.59563"]]},{"id":"34b6e44b.fe0f8c","type":"json-db-collection","z":"","name":"request","collection":"request","save":true}]
Hello and welcome to the forum.
I see a lot of bold words :stuck_out_tongue_winking_eye: and a little squinty image that shows nothing about the contents/logic of the nodes in the flow, so not much to go on.
Can you take a look at the screenshot now and see if it is more clear? Also, did I describe it better?
It seems odd to me. If I manually inject a timestamp on each individual process, it sends data just fine. If I link it together in one full set, it takes away the second template "ManualLookup" and just sends an empty JSON body demonstrated by the second log item on the right.
I tried a function node and got the same results so I thought it might have had something to do with the JSON db node but considering I can use the node separately with the "ManualLookup" it made me second guess that. If there is a good way to post the code, I'll give it all to you as there isn't anything proprietary at the moment since it's all local.
It wasn't the image as much as, yes, needing the "code" or flow as it is called, so that we can see the workings in your function nodes and such.
I am new to Node-Red, so may not be much use for the solution, but have had years in another forum helping drag out details to find solutions :grin:
So, in your case, click on the "hamburger" icon and Export the flow to the clipboard, then create a new post here and use the </> key and paste the flow there.
image image
Here is the code.
Hopefully that allows me to do this.
The injection is just adding the timestamp into the msg.payload. I suspect, but can't yet point out where (missing that blue node at my end), that when combining the whole you are loosing/discarding that msg.payload, thus ending up with a NULL value... or so is my wild @ guess :blush:
It's perplexing me. I have another node-red instance in product that is setup based on the same .net application. It takes the lookup and changes it to a validation instead of just a lookup. The only difference is the 3rd party uses XML. I know that's not enough to cause a problem, it's just odd to me.
Well, now that the flow is there, smrtr others may take notice
Thanks, I wrote my original question on the fly and left out some crucial information when asking for help. I've even tried hard coding the variable in the template and removing the DB node without any luck. It just seems so odd to me and it's probably something silly I'm missing.
Well... place a debug node after each step in the first and/or middle process (I am guessing that is where things go missing) and as you know what the data should look like, you might find the node that is blocking it.
I tried that, the only place that the content stops at is the HTTP POST "Lookup" nowhere else. It's very odd.
