Music from a file
I'm not sure the best way to make a system that pauses, plays and restarts music from a sound file that's on the machine. This is what I have so far and I can't get it to work... I have scrolled through and keep finding people using the http node(s) and I wanted to use the 'file-in' and 'audio-out' nodes. I haven't found anyone whose had experience with this, and I know i'm missing something but after hours of this and not being able to figure it out...if anyone can just point me in the direction of what to read then I think I can get it from there.
[{"id":"19636e55.bb21a2","type":"ui_button","z":"ca6973d9.194ca","name":"","group":"3346acfc.8202b4","order":1,"width":"1","height":"1","passthru":false,"label":"Start Music","tooltip":"","color":"Black","bgcolor":"light green","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":370,"y":180,"wires":[["559fe2ae.aefc5c"]]},{"id":"1bfec392.cd706c","type":"ui_button","z":"ca6973d9.194ca","name":"","group":"3346acfc.8202b4","order":3,"width":"1","height":"1","passthru":false,"label":"Reset Music","tooltip":"","color":"White","bgcolor":"Black","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":370,"y":340,"wires":[["f6730570.2d93c8"]]},{"id":"559fe2ae.aefc5c","type":"change","z":"ca6973d9.194ca","name":"","rules":[{"t":"set","p":"musicState","pt":"global","to":"playing","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":220,"wires":[[]]},{"id":"f6730570.2d93c8","type":"change","z":"ca6973d9.194ca","name":"","rules":[{"t":"set","p":"musicState","pt":"global","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":360,"wires":[[]]},{"id":"e6699e8b.23e79","type":"comment","z":"ca6973d9.194ca","name":"Music","info":"","x":350,"y":140,"wires":[]},{"id":"1a8e3816.0ec978","type":"play_audio_file","z":"ca6973d9.194ca","filename":"/home/jacob/Downloads/THNDR.mp3","x":540,"y":460,"wires":[["d09d5c1b.563c3"]]},{"id":"c7806677.07fcc8","type":"inject","z":"ca6973d9.194ca","name":"play","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Playing","payloadType":"msg","x":390,"y":220,"wires":[["559fe2ae.aefc5c"]]},{"id":"d09d5c1b.563c3","type":"ui_audio","z":"ca6973d9.194ca","name":"","group":"59b49b1a.fdf564","voice":"","always":"","x":720,"y":460,"wires":[]},{"id":"fe0afdd2.318d","type":"ui_button","z":"ca6973d9.194ca","name":"","group":"3346acfc.8202b4","order":1,"width":"1","height":"1","passthru":false,"label":"Pause Music","tooltip":"","color":"Black","bgcolor":"light green","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":370,"y":260,"wires":[["62a9a699.197698"]]},{"id":"62a9a699.197698","type":"change","z":"ca6973d9.194ca","name":"","rules":[{"t":"set","p":"musicState","pt":"global","to":"stopped","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":300,"wires":[[]]},{"id":"addfd2d.f2f253","type":"inject","z":"ca6973d9.194ca","name":"Pause","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"stop","payloadType":"msg","x":390,"y":300,"wires":[["62a9a699.197698"]]},{"id":"f9c30b23.750648","type":"inject","z":"ca6973d9.194ca","name":"Restart","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"musicState","payloadType":"global","x":390,"y":380,"wires":[["f6730570.2d93c8"]]},{"id":"3346acfc.8202b4","type":"ui_group","name":"Music","tab":"5c030594.084acc","order":5,"disp":false,"width":"6","collapse":false},{"id":"59b49b1a.fdf564","type":"ui_group","name":"","tab":"f976c216.1eb41","order":3,"disp":true,"width":"6","collapse":false},{"id":"5c030594.084acc","type":"ui_tab","name":"Game Master","icon":"dashboard","disabled":false,"hidden":false},{"id":"f976c216.1eb41","type":"ui_tab","name":"Escape Room","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
Hi, in order to make code more readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
