Mustache statement not working
I have this code, and it's not working, could someone help me please ?
Not sure Mustache is 100% supported by Node-Red or maybe it's a simplified version without all statements !?
[{"id":"55271cabcb3274a6","type":"http in","z":"1418dae22be032be","name":"","url":"/job/add","method":"get","upload":false,"swaggerDoc":"","x":850,"y":1380,"wires":[["5337cd7e2fce6e88"]]},{"id":"5337cd7e2fce6e88","type":"function","z":"1418dae22be032be","name":"Prepare vars","func":"//msg.payload = global.get('conf');\nmsg.payload = {\n    containers :{\n        1: {\n            checked : 1\n        },\n        2: {\n            checked : 1\n        },\n        3: {\n            checked : 0\n        },\n        4: {\n            checked : 0\n        }, \n        5: {\n            checked : 0\n        },\n        6: {\n            checked : 0\n        }, \n        7: {\n            checked : 0\n        }\n    }\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1030,"y":1380,"wires":[["3dd281899b8e760b","4922c9bcdc6ddb06"]]},{"id":"3dd281899b8e760b","type":"template","z":"1418dae22be032be","name":"modal - ajouter un job","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<div class=\"modal-dialog modal-lg\">\n    <div class=\"modal-content\">\n\n\t\t<div class=\"modal-header\">\n\t\t\t<h5 class=\"modal-title\" id=\"exampleModalLabel\">title</h5>\n\t\t\t<button type=\"button\" class=\"btn-close\" data-bs-dismiss=\"modal\" aria-label=\"Annuler\"></button>\n\t\t</div>\n\t\t\n\t\t<div class=\"modal-body\">\n\t\t\t\n\t\t\t<form id=\"form-job-add\" method=\"post\" action=\"/job/add\">\n\t\t\t\t\n\t\t\t\t<input type=\"hidden\" name=\"ctrl\" value=\"job-edit\" />\n\t\t\t\t<input type=\"hidden\" name=\"cmd\"  value=\"add\" />\n\t\t\t\t\n\t\t\t\t<div class=\"tab-pane container fade show active\" id=\"general\" role=\"tabpanel\" aria-labelledby=\"description-tab\">\n\t\t\t\t\n\t\t\t\t\t<div class=\"row mt-3\">\n\t\t\t\t\t\t<div class=\"col-12\">\n\t\t\t\t\t\t\t\n\t\t\t\t\t\t\t<div class=\"row fabrication_order\">\n\t\t\t\t\t\t\t\t<table class=\"table-responsive table-sm table-fabrication_order_add\">\n\t\t\t\t\t\t\t\t\t<thead>\n\t\t\t\t\t\t\t\t\t\t<tr>\n\t\t\t\t\t\t\t\t\t\t\t<th scope=\"col\">Containers(s)</th>\n\t\t\t\t\t\t\t\t\t\t</tr>\n\t\t\t\t\t\t\t\t\t</thead>\n\t\t\t\t\t\t\t\t\t<tbody>\n\t\t\t\t\t\t\t\t\t\t<tr>\n\t\t\t\t\t\t\t\t\t\t\t<td class=\"container pt3s\">\n\t\t\t\t\t\t\t\t\t\t\t\t{{#containers}}\n\t\t\t\t\t\t\t\t\t\t\t\t\t{{#uuid}}\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t<input type=\"checkbox\" id=\"{{.}}\" {{#checked}}checked{{/checked}} name=\"fabrication_order[][container][]\">\n\t\t\t\t\t\t\t\t\t\t\t\t\t\t<label for=\"{{.}}\">{{@index}}</label>\n\t\t\t\t\t\t\t\t\t\t\t\t\t{{/uuid}}\n\t\t\t\t\t\t\t\t\t\t\t\t{{/containers}}\n\t\t\t\t\t\t\t\t\t\t\t</td>\n\t\t\t\t\t\t\t\t\t\t</tr>\n\t\t\t\t\t\t\t\t\t</tbody>\n\t\t\t\t\t\t\t\t</table>\n\t\t\t\t\t\t\t</div>\n\n\t\t\t\t\t\t</div>\n\t\t\t\t\t</div>\n\n\t\t\t\t</div>\t\t\n\n\t\t\t</form>\n\t\t\t\n\t\t</div>\n\t\t\n\t\t<div class=\"modal-footer\">\n\t\t\t<button type=\"button\" id=\"btn-cancel\" class=\"btn btn-secondary\" data-bs-dismiss=\"modal\">Fermer</button>\n\t\t\t<button type=\"button\" id=\"btn-save\" class=\"btn btn-primary\">Enregistrer</button>\n\t\t</div>\n\t\t\n    </div>\n</div>","output":"str","x":1260,"y":1380,"wires":[["665fc973cea60842"]]},{"id":"4922c9bcdc6ddb06","type":"debug","z":"1418dae22be032be","name":"debug 17","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1220,"y":1440,"wires":[]},{"id":"665fc973cea60842","type":"http response","z":"1418dae22be032be","name":"Send HTML","statusCode":"","headers":{},"x":1470,"y":1380,"wires":[]}]
Actually, I try to populate 7 checkboxes and auto-check them in a Mustache Template. I precise it's not used with Dashboard but with /get /post from ajax calls on html pages I control myself.
It would be a lot easier for people to help if you shared example input data and the mustache code. Not everyone is in a position to keep installing flows in order to help people.
Mustache likes arrays when looping, not objects, so your data would be best an array of objects.
Your data object(change to array) is also in payload.container.
$index does not work in mustache, i believe it is handlebar syntax.
Best to have you id, names, index all in the array objects.
e.g.
payload
    "containers": [
            "checked": 1,
            "id": 1
            "checked": 1,
            "id": 2
            "checked": 0,
            "id": 3
Then the mustache would be
{{#payload.containers}}
    <input type="checkbox" id="{{id}}" {{#checked}}checked{{/checked}} name="fabrication_order[][container][]">
	<label for="{{id}}">{{id}}</label>
{{/payload.containers}}
Output
<input type="checkbox" id="1" checked name="fabrication_order[][container][]">
<label for="1">1</label>.......................
