My node-red-contrib-gpio cannot be install ,please help me,thank you very much
019-10-08T07:23:14.638Z 安装 : node-red-contrib-gpio 0.14.0
2019-10-08T07:23:14.673Z npm.cmd install --no-audit --no-update-notifier --save --save-prefix="~" --production node-red-contrib-gpio@0.14.0
2019-10-08T07:23:44.986Z [out]
2019-10-08T07:23:44.986Z [out] > serialport@6.0.5 install C:\Users\Administrator.node-red\node_modules\johnny-five\node_modules\firmata\node_modules\serialport
2019-10-08T07:23:44.986Z [out] > prebuild-install || node-gyp rebuild
2019-10-08T07:23:47.207Z [err] prebuild-install
2019-10-08T07:23:47.207Z [err] WARN install No prebuilt binaries found (target=10.16.3 runtime=node arch=x64 platform=win32)
2019-10-08T07:23:47.237Z [out]
2019-10-08T07:23:47.237Z [out] C:\Users\Administrator.node-red\node_modules\johnny-five\node_modules\firmata\node_modules\serialport>if
2019-10-08T07:23:47.237Z [out] not defined npm_config_node_gyp (node "C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\....\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node "C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
2019-10-08T07:23:50.103Z [err] gyp
2019-10-08T07:23:50.103Z [err] ERR! find VS
2019-10-08T07:23:50.104Z [err]
2019-10-08T07:23:50.104Z [err] gyp ERR!
2019-10-08T07:23:50.104Z [err] find VS msvs_version was set from command line or npm config
2019-10-08T07:23:50.104Z [err] find VS - looking for Visual Studio version 2017
2019-10-08T07:23:50.104Z [err] find VS VCINSTALLDIR not set, not running in VS Command Prompt
2019-10-08T07:23:50.104Z [err] ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer
2019-10-08T07:23:50.104Z [err] gyp ERR! find VS
2019-10-08T07:23:50.104Z [err] looking for Visual Studio 2015
2019-10-08T07:23:50.104Z [err] find VS - not found
2019-10-08T07:23:50.104Z [err] ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
2019-10-08T07:23:50.104Z [err] find VS valid versions for msvs_version:
2019-10-08T07:23:50.104Z [err] **************************************************************
2019-10-08T07:23:50.104Z [err] find VS You need to install the latest version of Visual Studio
2019-10-08T07:23:50.105Z [err] find VS including the "Desktop development with C++" workload.
2019-10-08T07:23:50.105Z [err] gyp
2019-10-08T07:23:50.105Z [err] ERR! find VS For more information consult the documentation at:
2019-10-08T07:23:50.105Z [err] ERR! find VS https://github.com/nodejs/node-gyp#on-windows
2019-10-08T07:23:50.105Z [err] gyp ERR! find VS
2019-10-08T07:23:50.105Z [err] **************************************************************
2019-10-08T07:23:50.107Z [err] gyp ERR! configure error
2019-10-08T07:23:50.107Z [err] gyp ERR! stack Error: Could not find any Visual Studio installation to use
2019-10-08T07:23:50.107Z [err] gyp ERR! stack at VisualStudioFinder.fail (C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)
2019-10-08T07:23:50.107Z [err] gyp ERR! stack at findVisualStudio2013 (C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16)
2019-10-08T07:23:50.107Z [err] gyp ERR! stack at VisualStudioFinder.findVisualStudio2013 (C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:344:14)
2019-10-08T07:23:50.107Z [err] gyp ERR! stack at findVisualStudio2015 (C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14)
2019-10-08T07:23:50.107Z [err] gyp ERR! stack at regSearchKeys (C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:365:16)
2019-10-08T07:23:50.107Z [err] ERR! stack at regGetValue (C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7)
2019-10-08T07:23:50.107Z [err] ERR! stack at C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
2019-10-08T07:23:50.107Z [err] ERR! stack at ChildProcess.exithandler (child_process.js:301:5)
2019-10-08T07:23:50.107Z [err] at ChildProcess.emit (events.js:198:13)
2019-10-08T07:23:50.107Z [err] stack at maybeClose (internal/child_process.js:982:16)
2019-10-08T07:23:50.108Z [err] gyp
2019-10-08T07:23:50.108Z [err] ERR! System
2019-10-08T07:23:50.108Z [err] Windows_NT 6.1.7601
2019-10-08T07:23:50.108Z [err] ERR! command "C:\Program Files\nodejs\node.exe" "C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
2019-10-08T07:23:50.108Z [err] gyp ERR!
2019-10-08T07:23:50.108Z [err] cwd C:\Users\Administrator.node-red\node_modules\johnny-five\node_modules\firmata\node_modules\serialport
2019-10-08T07:23:50.108Z [err] node -v v10.16.3
2019-10-08T07:23:50.108Z [err] node-gyp -v v5.0.3
2019-10-08T07:23:50.108Z [err] ERR! not ok
2019-10-08T07:23:50.135Z [out]
2019-10-08T07:23:50.135Z [out] > serialport@6.0.5 install C:\Users\Administrator.node-red\node_modules\node-red-contrib-gpio\node_modules\firmata\node_modules\serialport
2019-10-08T07:23:50.135Z [out] > prebuild-install || node-gyp rebuild
2019-10-08T07:23:52.358Z [err] prebuild-install
2019-10-08T07:23:52.359Z [err] WARN install No prebuilt binaries found (target=10.16.3 runtime=node arch=x64 platform=win32)
2019-10-08T07:23:52.384Z [out]
2019-10-08T07:23:52.384Z [out] C:\Users\Administrator.node-red\node_modules\node-red-contrib-gpio\node_modules\firmata\node_modules\serialport>if not defined npm_config_node_gyp (node "C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\....\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node "C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
2019-10-08T07:23:54.979Z [err] gyp
2019-10-08T07:23:54.979Z [err] ERR! find VS
2019-10-08T07:23:54.979Z [err] gyp ERR!
2019-10-08T07:23:54.979Z [err] find VS msvs_version was set from command line or npm config
2019-10-08T07:23:54.979Z [err] ERR! find VS - looking for Visual Studio version 2017
2019-10-08T07:23:54.979Z [err] VCINSTALLDIR not set, not running in VS Command Prompt
2019-10-08T07:23:54.979Z [err] find VS could not use PowerShell to find Visual Studio 2017 or newer
2019-10-08T07:23:54.979Z [err] find VS looking for Visual Studio 2015
2019-10-08T07:23:54.980Z [err] ERR! find VS
2019-10-08T07:23:54.980Z [err] - not found
2019-10-08T07:23:54.980Z [err] gyp ERR!
2019-10-08T07:23:54.980Z [err] find VS not looking for VS2013 as it is only supported up to Node.js 8
2019-10-08T07:23:54.980Z [err] find VS valid versions for msvs_version:
2019-10-08T07:23:54.980Z [err] ERR! find VS **************************************************************
2019-10-08T07:23:54.980Z [err] find VS You need to install the latest version of Visual Studio
2019-10-08T07:23:54.980Z [err] including the "Desktop development with C++" workload.
2019-10-08T07:23:54.980Z [err] find VS For more information consult the documentation at:
2019-10-08T07:23:54.980Z [err] https://github.com/nodejs/node-gyp#on-windows
2019-10-08T07:23:54.981Z [err] gyp ERR!
2019-10-08T07:23:54.981Z [err] find VS
2019-10-08T07:23:54.982Z [err] gyp ERR! configure error
2019-10-08T07:23:54.983Z [err] gyp
2019-10-08T07:23:54.983Z [err] ERR! stack Error: Could not find any Visual Studio installation to use
2019-10-08T07:23:54.983Z [err] ERR! stack at VisualStudioFinder.fail (C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)
2019-10-08T07:23:54.983Z [err] at findVisualStudio2013 (C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16)
2019-10-08T07:23:54.983Z [err] gyp ERR!
2019-10-08T07:23:54.983Z [err] stack at VisualStudioFinder.findVisualStudio2013 (C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:344:14)
2019-10-08T07:23:54.983Z [err] at findVisualStudio2015 (C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14)
2019-10-08T07:23:54.983Z [err] stack at regSearchKeys (C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:365:16)
2019-10-08T07:23:54.983Z [err] ERR! stack at regGetValue (C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7)
2019-10-08T07:23:54.983Z [err] gyp ERR! stack
2019-10-08T07:23:54.983Z [err] at C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
2019-10-08T07:23:54.983Z [err] stack at ChildProcess.exithandler (child_process.js:301:5)
2019-10-08T07:23:54.983Z [err] stack at ChildProcess.emit (events.js:198:13)
2019-10-08T07:23:54.983Z [err] ERR! stack at maybeClose (internal/child_process.js:982:16)
2019-10-08T07:23:54.984Z [err] gyp
2019-10-08T07:23:54.984Z [err] ERR! System Windows_NT 6.1.7601
2019-10-08T07:23:54.984Z [err] ERR! command
2019-10-08T07:23:54.984Z [err] "C:\Program Files\nodejs\node.exe" "C:\Users\Administrator\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
2019-10-08T07:23:54.984Z [err] ERR! cwd C:\Users\Administrator.node-red\node_modules\node-red-contrib-gpio\node_modules\firmata\node_modules\serialport
2019-10-08T07:23:54.985Z [err] gyp ERR! node -v v10.16.3
2019-10-08T07:23:54.985Z [err] gyp ERR! node-gyp -v v5.0.3
2019-10-08T07:23:54.985Z [err] gyp ERR! not ok
2019-10-08T07:23:55.473Z [err] npm
2019-10-08T07:23:55.473Z [err] WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.0.5 (node_modules\johnny-five\node_modules\firmata\node_modules\serialport):
2019-10-08T07:23:55.473Z [err] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.0.5 install: prebuild-install || node-gyp rebuild
2019-10-08T07:23:55.473Z [err] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
2019-10-08T07:23:55.516Z [err] npm
2019-10-08T07:23:55.517Z [err] ERR! code ELIFECYCLE
2019-10-08T07:23:55.517Z [err] npm
2019-10-08T07:23:55.517Z [err] ERR! errno 1
2019-10-08T07:23:55.517Z [err] ERR! serialport@6.0.5 install: prebuild-install || node-gyp rebuild
2019-10-08T07:23:55.517Z [err] npm ERR!
2019-10-08T07:23:55.517Z [err] Exit status 1
2019-10-08T07:23:55.517Z [err] npm ERR! Failed at the serialport@6.0.5 install script.
2019-10-08T07:23:55.517Z [err] ERR! This is probably not a problem with npm. There is likely additional logging output above.
2019-10-08T07:23:55.603Z [err]
2019-10-08T07:23:55.603Z [err] npm ERR! A complete log of this run can be found in:
2019-10-08T07:23:55.603Z [err] npm ERR! C:\Users\Administrator\AppData\Roaming\npm-cache_logs\2019-10-08T07_23_55_522Z-debug.log
2019-10-08T07:23:55.636Z rc=1
Please don't open multiple threads for the same issue.
Please continue the thread you started yesterday Cannot install node-red-contrib-gpio
