My template nodes are ignoring my relations
Hi erveryone,
I'm trying to change my gauge css properties depending in wha'ts the value of my msg.status. So I added a switch and I have a template for each option like on the image.
But my css is allways changing for the bottom template properties, even when the program don't pass there.
My up template code:
<style>
    [node-id="2074463f2a4e057d"]{
        border: 4px solid red !important;
        color: black !important;
        border-radius: 20px;
</style>
My bottom template:
<style>
        border: 4px solid black !important;
        /*border: none !important;*/
</style>
Thanks in advance!
If these are head templates then they will both be present in the output & the bottom one will always win.
A better solution is to use class names....
Check the built in help info on the dashboard nodes and search the forum for msg.className for clues
Hi @Steve-Mcl thanks for the reply. It's working now! :smiling:
I don't know if it's better to create a new topic for this new question, but how can I change the color of the gauge metrics text?
Probably :wink:
Here is a demo for you to play with...
(Use CTRL-I to import)
[{"id":"ea334285a1c63cbd","type":"ui_template","z":"7ecba32db86f0617","group":"ef2301c8f15e8f4a","name":"Head template styles","order":2,"width":0,"height":0,"format":"<style>\n     .red-border .nr-dashboard-gauge svg {\n        border: 4px solid red !important;\n        color: black !important;\n        border-radius: 20px;\n    }\n\n    .simple-border .nr-dashboard-gauge svg {\n        border: 4px solid black !important;\n        /*border: none !important;*/\n    }\n    \n    .red-gauge-text .nr-dashboard-gauge text {\n        fill: red !important;\n    }\n    \n    .green-gauge-text .nr-dashboard-gauge text {\n        fill: green !important;\n    }\n</style>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","className":"","x":1020,"y":440,"wires":[[]]},{"id":"17863e1bd2c477b3","type":"ui_gauge","z":"7ecba32db86f0617","name":"","group":"ef2301c8f15e8f4a","order":3,"width":0,"height":0,"gtype":"gage","title":"gauge","label":"units","format":"{{value}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","className":"","x":1290,"y":580,"wires":[]},{"id":"a2c5cb774e54d342","type":"change","z":"7ecba32db86f0617","name":"red-border","rules":[{"t":"set","p":"className","pt":"msg","to":"red-border","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":500,"wires":[["17863e1bd2c477b3"]]},{"id":"c549ae52ecc81c9d","type":"inject","z":"7ecba32db86f0617","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"5","payloadType":"num","x":830,"y":500,"wires":[["a2c5cb774e54d342"]]},{"id":"c15144351af12644","type":"change","z":"7ecba32db86f0617","name":"red-border green-gauge-text","rules":[{"t":"set","p":"className","pt":"msg","to":"red-border green-gauge-text","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1040,"y":580,"wires":[["17863e1bd2c477b3"]]},{"id":"34f2b82dcae7934c","type":"change","z":"7ecba32db86f0617","name":"simple-border green-gauge-text","rules":[{"t":"set","p":"className","pt":"msg","to":"simple-border green-gauge-text","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":660,"wires":[["17863e1bd2c477b3"]]},{"id":"685af3951f3f15c8","type":"change","z":"7ecba32db86f0617","name":"simple-border","rules":[{"t":"set","p":"className","pt":"msg","to":"simple-border","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":620,"wires":[["17863e1bd2c477b3"]]},{"id":"24263e80a6458842","type":"change","z":"7ecba32db86f0617","name":"red-border red-gauge-text","rules":[{"t":"set","p":"className","pt":"msg","to":"red-border red-gauge-text","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":540,"wires":[["17863e1bd2c477b3"]]},{"id":"fd6240e5fd474449","type":"inject","z":"7ecba32db86f0617","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"7","payloadType":"num","x":830,"y":540,"wires":[["24263e80a6458842"]]},{"id":"89bb34d8f4e3d33f","type":"inject","z":"7ecba32db86f0617","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"2","payloadType":"num","x":830,"y":580,"wires":[["c15144351af12644"]]},{"id":"53dfdf157e86478f","type":"inject","z":"7ecba32db86f0617","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"9","payloadType":"num","x":830,"y":660,"wires":[["34f2b82dcae7934c"]]},{"id":"49c5143d5813f089","type":"inject","z":"7ecba32db86f0617","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":830,"y":620,"wires":[["685af3951f3f15c8"]]},{"id":"ef2301c8f15e8f4a","type":"ui_group","name":"Carica Certificato Taratura","tab":"21286fd2ee7bdc0c","order":5,"disp":true,"width":"10","collapse":false,"className":""},{"id":"21286fd2ee7bdc0c","type":"ui_tab","name":"Inserimento Date Controllo","icon":"assignment","order":5,"disabled":false,"hidden":false}]
chrome_e87PpkUGhJ
This was exactly what I needed. Thanks a lot for the help!
