MySQL connection Error
Hi All,
I am beginner to Node Red . I am trying to connect MySQL database using "node-red-node-mysql" through a simple MySQL Query . I am getting following error
Error: ER_NOT_SUPPORTED_AUTH_MODE: Client does not support authentication protocol requested by server; consider upgrading MySQL client
MySQL version is 8.0
Node Red Node-RED version: v1.0.3
Node.js version: v12.13.1
The MySQL Node Settings are as follows
Please help In case anybody has come across this issue and solved .
Thanks in Advance.
Looks like version 8 is not currently supported (see: https://github.com/node-red/node-red-nodes/issues/534)
Not sure if this is a solution for you but I get the same error with Mariadb.
Doing a "grant all privileges on mydb.* to myuser identified by 'mypassword';" solved it for me.
Thanks for your response.
I just found the solution on MySql forum and it is working with version 8.0
The solution is as follows
Execute the following query in MYSQL Workbench
ALTER USER 'root'@'localhost' IDENTIFIED WITH mysql_native_password BY 'password'
Where root as your user localhost as your URL and password as your password
Then run this query to refresh privileges:
flush privileges;
Thanks for your response. I could solve this issue by following solution provided on MySQl forum.
The Solution is as follows
flush privileges;
