I'm using the node-red-node-mysql, but I need to escape the queries, mainly because the single quotes brakes the queries.
How can I do that?
Thanks!
Show us an example query you are trying to use.
You don't. Use parameters instead (see the nodes readme)
It will save you from a future sequel injection hack ![]()
Cool, thanks a lot, in this way the queries are even more readable!
I'm asking myself why in the GitHub page there's this:
By it's very nature it allows SQL injection... so be careful out there...
That looks outdated.
The real readme is up-to-date and details the use of parameters: node-red-node-mysql (node) - Node-RED
I'm having problem using LIKE
msg.payload.view_as == "master"){
msg.topic = "SELECT * FROM table1 WHERE column1 LIKE '%:view_as%'";
I can't seem to place that "view_as", I always get the variable name and not it's value.
Parameters dont have quotes.
Prepare a variable beforehand and specifiy its name in the query.
msg.payload.view = '%' + msg.payload.view_as + '%'
msg.topic = "SELECT * FROM table1 WHERE (column1 LIKE :view);
Thanks!!!
