i want sen 3 messages, the values of Inductive sensor, LM35 sensor and LM335 sensor
Hi @smalhao
as you have changed the Join node to generate a key/value object, the msg.payload[0] way of accessing its properties is no longer the right way to do it.
This page in the docs explains how you can use the Debug sidebar to identify how to access different parts of a message: https://nodered.org/docs/user-guide/messages
If you look at the Debug message, you can see msg.payload is no longer an array, but an Object. It has three properties:
"ns=2;s=LM35": 23.0550....,
"ns=2;s=SensorIndutivo": 7514.689.....,
"ns=2;s=LM335": 22.2104...
So you would access those properties as:
msg.payload["ns=2;s=LM35"]
msg.payload["ns=2;s=SensorIndutivo"]
msg.payload["ns=2;s=LM335"]
in your Function node, in place of msg.payload[0], msg.payload[1] and msg.payload[2].
I was making a small program to test more easily and that was as follows:
The configuration of each is :
The configuration of Joins is:
The function is
var newmsg=new Date().toString();
msg.topic= "INSERT INTO testebase VALUES ('"+new Date().toString()+"','"+msg.payload[0].toFixed(2)+"','"+msg.payload[1].toFixed(2)+"','"+msg.payload[2].toFixed(2)+"')";
The debug output of function is :
and send the data correctly to database. When i apply the same method in other program i want (yesterday )programming don´t show the array with the values correctly.
Why have you changed the Join back to array mode? You need it to be the key/value object.
In array mode, it will join each 3 messages it receives into the array - regardless of the order they arrive in.
So if you have three sensors, A, B and C, and you get a stream of messages:
A B C B A B B C A
You will end up with [A,B,C], [B,A,B], [B,C,A].
By using the key/value object join mode, it will use msg.topic to ensure each message has one message from each topic it receives.
The Join configuration I have
is as follows:
the output of Join is:
When i change to key/value Object
and i need to send the value of sensor to database, but in database the values appears in that way
the values 1360.30.... are meters, 20, 00 are the temperature of sensor LM335 and 20.74 are the temperature of sensor LM35 and i need to put them in column correctly.
What does your function node that is generating the query look like?
Please don't screenshot it. Copy the code and paste it here - making sure you've read this post How to share code or flow json about how to properly share code on this forum.
in the function to send data to database i configured that way:
msg.topic="INSERT INTO Sensores VALUES ('"+ new Date().toString() +"','"+ msg.payload[0] +"','"+ msg.payload[1] +"','"+ msg.payload[2] +"')";
i think i missing something in the function i think
Did you read this reply from me? MySQL NODE-RED table
It explained how you needed to change your query to access the properties of msg.payload after changing the Join node configuration.
Put the query like this :
msg.topic="INSERT INTO Sensores VALUES ('"+ new Date().toString() +"','"+ msg.payload["ns=2;s=SensorIndutivo"] +"','"+ msg.payload["ns=2;s=LM335"] +"','"+ msg.payload["ns=2;s=LM35"] +"')";
You need to understand the difference between an object and an array in javascript.
It is worth spending 30minutes reading one of the many online tutorials.
After that also read the following https://nodered.org/docs/user-guide/messages
Okay. And did that work? What output did that generate? Did you use the Debug node to see what the query it generated?
Its working, thanks for your help knolleary
06/02/2019, 11:27:15node: output of function
INSERT INTO Sensores VALUES ('Wed Feb 06 2019 11:27:01 GMT+0000 (GMT)','1899.0927590950298','20.44695023999293','21.19148479999994') : msg.payload : Object
{ ns=2;s=LM35: 21.19148479999994, ns=2;s=LM335: 20.44695023999293, ns=2;s=SensorIndutivo: 1899.0927590950298 }
the database is now correctly
if i need to check each one of topics if they are sending the data, how i coud make that in a function of switch case ?
