Newbie - msg.payload into SQL
Hi. I'm a newbie to NODE RED, SQL, webserver ...
I try to put all the info from msg.payload into a database.
I installed everthing and it works for me.
SQL connect. Datas are going in.
my function is:
msg.topic = "INSERT INTO dbasename(data1) VALUES ('"+msg.payload+"')";
debug output:
INSERT INTO dbasename(data1) VALUES ('[object Object]') : msg.payload : Object
[object Object] are going into database but not the json datas
Could you please give me a advise regarding my funktion. I dont want to split the json file. I want to input the entire info.
payload is eg.
 msg.payload : string[179]
"{"time" : "2019-12-11 23:23:26", "model" : "GT-WT02", "id" : 165, "channel" : 1, "battery" : "OK", "temperature_C" : 4.000, "humidity" : 100.000, "button" : 0, "mic" : "CHECKSUM"}"
What are the definitions of the columns in the dbasename table?
As a self described newbie, have you taken a mySQL tutorial? Something like https://www.w3schools.com/sql/default.asp
Hello Zenofmud
thanks for your reply. My database info are:
10.3.18-MariaDB-0+deb10u1 - Debian 10
The dbase name ="dbasename"
there are 2 columns in it. 1. name is "timestamp" typ "timestamp"
the 2nd is named "data1" typ "text"
I administrate it with phpmyadmin
And I havnt take done this tutorial. But I watched several videos on youtube.
BTW I changed my function to
var obj = msg.payload;
var myJSON = JSON.stringify(obj);
msg.topic = "INSERT INTO dbasename(data1) VALUES ('"+myJSON+"')";
Now I see the json object in my column "data1"
Congratulations you’ve figured it out!
But is it right?
Do I have to "stringify" my object to a variable?
Well you can't store a json object into a text column since the data types don't match. Have a read of this and see if it helps.
According to the first post the payload is a string, but that cannot be correct, it must be a javascript object.
[Edit] By that I mean that if it were a string it would work, to get the error posted the payload must in fact contain an object.
