Need an if operation, don't know how to do
Hi there,
I'm doing a geolocation lookup via Google API.
I get the MAC Addresses proper, but i need a function wich will lookup if the address has 12 characters, if not, i need a "0" in front of my string.
Sorry for the noob question :slight_smile:
What do you have so far to do the processing? Not sure if I know what you're asking. Adding 0 to a MAC address or what?
You do not need if, you can use padStart() or padEnd()
//str.padStart(targetLength, padString)
msg.payload = "12345678".padStart(9, "0");
If 9 characters in length no padding is added.
Hi there,
so my case would be:
msg.payload = "123456789as".padStart(11, "0");
Thanks!
You could experiment to find out, but if you want a string 12 chars long then set "12345678910".padStart(12,"0")This should output "012345678910".
Play around and try it.
i did, it works already, thanks everyone!
