I meant that it sounds as if it should be simple to use setTimeout to interject a delay into the loop, which will allow other flows in node red to continue at the same time. However, unless you are experienced in using the timer functions there are a number of pitfalls that one can easily fall into. Without knowing your experience level and without seeing the details of your code I can't tell whether you have avoided them or not.
Colin
21
Related topics
| Topic | Replies | Views | Activity | |
| Can node-red node/flow run in parallel? | 29 | 16611 | 11 June 2020 | |
| General Node Red behavior? | 5 | 497 | 8 November 2019 | |
| When the timestamp period is 0.1s, the deployment becomes stuck | 18 | 370 | 6 June 2023 | |
| Custom node development help (prevent wiring 2 injects to same node/determin running state of node/take care of proper functioning when facing multiple injects) | 14 | 444 | 28 September 2023 | |
| Node-red performance benchmark | 5 | 3192 | 23 March 2021 |
