i need a function with 2 out´s, which track my msg.payload.
- If msg.payload input less than -1000 send on first out "1" and on second output the input msg.payload value
- After this, if the value greater than +1000, send on first out "0" and on second output "0"
These two functions are so simple and I programmed them
But now:
After the input value was -1000 for the first time, every time the input value changes until +1000 is reached, the input value should be to second output.
Can help some one, to create this function?
I am not sure I have computed this correctly.
The if statements returns for a given criteria, so it will not continue passed that point.
const lastValue = context.get('lastValue');
/* If msg.payload input less than -1000 send on first out "1" and on second output the input msg.payload value */
if(msg.payload < -1000){
context.set('lastValue',msg.payload);
return [{payload:1},msg]
/* After this, if the value greater than +1000, send on first out "0" and on second output "0" */
if(lastValue < -1000 && msg.payload > -1){
return [{payload:0},{payload:0}]
if(!lastValue){
// do nothing ??
return [undefined, undefined]
/* After the input value was -1000 for the first time, every time the input value changes until +1000 is reached, the input value should be to second output. */
if(msg.payload < -1){
return [undefined,msg]
Thank for help. context was the function i have search.
It wasn't 100% functional, but I adjusted it the way it should be. It wasn't perfectly described by me either.
I would now like to add a modification, namely that the function is only deactivated when the value of 1000 is exceeded for more than 30 seconds at a time.
const active = context.get('active');
/* If Input greater then 1000 deactivate function */
if (msg.payload > 1000) {
context.set('lastValue', msg.payload);
context.set('active', 0);
return [{ payload: 0 }, { payload: 0 }]
/* If function active */
if (active > 0) {
context.set('active', 1);
return [{ payload: 1 }, msg]
/* If msg.payload input less than -1000 activate function */
if (msg.payload < -1000) {
