Need help for my first function
I'm struggling with a very basic principle.
I would like to trigger a custom message payload based on a time trigger.
For example, if it's 9:00 AM I'd like to send this payload "colorTemp":153 to another node.
Right now I'm experimenting with a timestamp chained with a series of "time range" nodes.
Each time range node has a time frame, if my message doesn't match node's timeframe then it goes one node further etc until it triggers a function.
My function contains this code
    msg.payload="colorTemp\"\:153"
I'm confused because returning the function above doesn't create the same effect as this code from my inject node
{"colorTemp":153}
Here is what I get from the debugging window:
msg.payload : string[14]
"colorTemp":153"
Thanks for your help
you are creating it as a string but you need/want to create it as a javascript object.
The w3schools web pages on javascript objects will give you all the information you need and will also help you understand what you need to do in a Node-RED function node
