Need help taking this message apart and making a new one
This is the error message I get:
{"_msgid":"95a5f34b.89b7f","topic":"ERROR_REPORT/BedPi/Logging/","error":{"message":"ReferenceError: a is not defined (line 1, col 19)","source":{"id":"f15d59f6.b745","type":"function","name":"This will throw an error","count":1}},"_error":{},"time":"2020-05-20 19:41:31","payload":"Cause an error"}
I am wanting to create a message showing the error which can be written to a text file - human readable.
This is the code I have so far:
let when = msg.time;
let who = msg.topic;
let what = msg.error;
let where = msg.error.source;
node.warn("What " + what);
node.warn("Where " + where);
msg.payload = "When " + when + "\nWho " + who + "\nWhat " + what + "\nWhere " + where;
But I get this as the output:
When 2020-05-20 19:41:31Who ERROR_REPORT/BedPi/ERROR_REPORT/BedPi/Logging/What [object Object]Where [object Object]
I'm messing up with the objects. I know.
This is a big (huge) re-write of a lot of code as I finally discovered that what I had doesn't work.
I'm stupid.
Worked it out with this:
let when_ = msg.time;
let who_ = msg.topic;
let what_ = msg.error.message;
let where_ = msg.error.source.id;
node.warn("What " + what_);
node.warn("Where " + where_);
msg.payload = "When " + when_ + "\nWho " + who_ + "\nWhat " + what_ + "\nWhere " + where_;
Are you using node-red-contrib-flogger?
You can simply pass an object to it & it'll add the whole msg object (as JSON) into a file - no fuss, no muss.
Never heard of that.
(Dumb question) would it be better for me for this single use?
I have since added more stuff to the code to again make it more readable.
But not to the point of rocket science.
I may have a peep at the node, but was just wondering about its overheads.
