Hi, I actually found a tutorial about how to access the message object in template script:
https://flows.nodered.org/flow/2f1aaf0635f9bf23207152682323240a
but I dont understand what is "scope" in the closure function..
hope someone can help on this ![]()
Scope is an object generated by the AngularJS framework that node-red-dashboard is built around.
Read the built in help for the ui-template node. it shows you an example of using scope.
Also, see here for more info
Thank you
I will study on it
