Need help with creating an js object
My case:
I want to create an object which takes the value of x as value of the key location.
the following code does not work :frowning:
context.set('location','UGSK');
let x = context.get('location').valueOf();
msg.payload = JSON.parse('{"location":x,"switch":"Regler NoOp"}');
There is no need to use JSON parse - just build the object!
msg.payload = {
 "location": x,
 "switch": "Regler NoOp"
PS: not sure why you are calling .valueOf(); ???
ok, the object should look like this:
        node_send(JSON.parse('{"location":"UGSK","switch":"Regler on"}'),context.get('out-regler'));
"UGSK" is the value of the context variable location
        const l = (context.get('location'));
        node_send(l,context.get('out_debug'));
        node_send(JSON.parse('{"location":context.get('location').value.Of,"switch":"Regler NoOp"}'),context.get('out_regler'));
please check the threat. did not reply to you. sorry
problem solved!
I did not need JSON.parse()
