Need help with flow variables
I'm new here so I apologize in advance if I don't pose this question correctly or don't post the right stuff.
I have an iot app (rtl_433) feeding mqtt. My goal is to create a web page that will display the latest readings from 2 temperature sensors.
I am doing this by updating several flow variables every time an mqtt message arrives and then reading all the variables on a web request,
it almost works.
This part creates and updates the variables:
        "id": "4c373b36d685d664",
        "type": "mqtt in",
        "z": "800755e5a3a92a74",
        "name": "rtl433",
        "topic": "rtl_433",
        "qos": "0",
        "datatype": "auto-detect",
        "broker": "09e0e9cb5c03de03",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 70,
        "y": 20,
                "8e04b49a0199527a"
        "id": "8e04b49a0199527a",
        "type": "json",
        "property": "payload",
        "action": "obj",
        "pretty": true,
        "x": 110,
        "y": 100,
                "4de57660ad2e7bb4",
                "24c115a6.3b06d2"
        "id": "4de57660ad2e7bb4",
        "type": "debug",
        "name": "message trace",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 460,
        "y": 100,
        "id": "24c115a6.3b06d2",
        "type": "function",
        "name": "Set Context Variables",
        "func": "var outdoor = flow.get('outdoor') || 0;\n//if (typeof outdoor==\"undefined\") outdoor = 0;\nvar indoor = flow.get('indoor') || 0;\n//if (typeof indoor==\"undefined\") indoor = 0;\nvar outdoor_bat = flow.get('outdoor_bat') || 0;\n//if (typeof outdoor_bat==\"undefined\") outdoor_bat = 0;\nvar indoor_bat = flow.get('indoor_bat') || 0;\n//if (typeof outdoor_bat==\"undefined\") outdoor_bat = 0;\n\nvar channel = Number(msg.payload.channel);  // convert it to a number in case it is a string\nvar temperature = Number(msg.payload.temperature_F);  // convert it to a number in case it is a string msg.payload = {\"channel is \" : channel , \"temp is \" : temperature};\nvar battery = Number(msg.payload.battery_ok);\nif (channel == 1) {\n    //outdoor = temperature\n    flow.set('outdoor', temperature)\n    flow.set('outdoor_bat', battery)\n    msg.payload = {\n        \"outdoor temp is \": flow.get('outdoor'),\n        \"outdoor battery is \": + flow.get('outdoor_bat')\n    };\n}\nelse {\n    //indoor = temperature\n    flow.set('indoor', temperature)\n    flow.set('indoor_bat', battery)\n    msg.payload = {\n        \"indoor temp is \": flow.get('indoor'),\n        \"indoor battery is \": + flow.get('indoor_bat')\n    };\n}\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 280,
        "y": 180,
                "1051c8a369344a09"
        "id": "1051c8a369344a09",
        "type": "debug",
        "name": "debug 1",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "x": 480,
        "y": 180,
        "id": "09e0e9cb5c03de03",
        "type": "mqtt-broker",
        "name": "rtl433",
        "broker": "192.168.1.108",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
The other part works except it says that indoor_bat is undefined.
        "id": "ecbb4afc2f0a2d5a",
        "type": "http in",
        "url": "/mysite",
        "method": "get",
        "upload": false,
        "swaggerDoc": "",
        "x": 90,
        "y": 320,
                "930e5bee17edd3b4"
        "id": "930e5bee17edd3b4",
        "type": "function",
        "name": "msg.url = \"mysitepost\";",
        "func": "//msg.outdodor = flow.get('outdoor');\n//msg.outdodor_bat = flow.get('outdoor_bat');\nmsg.indoor = flow.get('indoor');\nmsg.indoor_bat = flow.get('indodor_bat');\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 330,
        "y": 320,
                "f401178b48986e0a",
                "91fdaec28a2d5846"
        "id": "76c9419f34710a07",
        "type": "template",
        "name": "CSS",
        "field": "payload.style",
        "fieldType": "msg",
        "format": "html",
        "syntax": "mustache",
        "template": "input[type=text], select {\n    width: 100%;\n    padding: 12px 20px;\n    margin: 8px 0;\n    display: inline-block;\n    border: 1px solid #ccc;\n    border-radius: 4px;\n    box-sizing: border-box;\n}\n\ninput[type=submit] {\n    width: 100%;\n    background-color: #4CAF50;\n    color: white;\n    padding: 14px 20px;\n    margin: 8px 0;\n    border: none;\n    border-radius: 4px;\n    cursor: pointer;\n}\n\ninput[type=submit]:hover {\n    background-color: #45a049;\n}\n\ndiv {\n    border-radius: 5px;\n    background-color: #f2f2f2;\n    padding: 20px;\n}\n\nhtml {\n    font - family: 'Open Sans', sans-serif display: block margin: 0px auto text-align: centercolor: #444444\n}\n\nbody {\n    margin: 0px\n}\n\nh1 {\n    margin: 25px auto 15px;\n    text-align: center;\n}\n\nh3 {\n    text-align: center;\n}\n\n.side-by-side {\n    display: table - cellvertical - align: middleposition: relative\n}\n\n.text {\n    font - weight: 600font-size: 19pxwidth: 200px\n}\n\n.reading {\n    font - weight: 300font-size: 50pxpadding-right: 25px\n}\n\n.temperature .reading {\ncolor: #F29C1F\n}\n\n.humidity .reading {\n    color: #3B97D3\n}\n\n.pressure .reading {\n    color: #26B99A\n}\n\n.altitude .reading {\n    color: #955BA5\n}\n\n.superscript {\n    font - size: 17pxfont-weight: 600position: absolutetop: 10px\n}\n\n.data {\n    padding: 10px\n}\n\n.container {\n    display: tablemargin: 0 auto\n}\n\n.icon {\n    width: 65px\n}\n\n",
        "x": 490,
        "y": 420,
                "c8f17365680d23fc"
        "id": "f401178b48986e0a",
        "type": "template",
        "name": "JavaScript",
        "field": "payload.script",
        "fieldType": "msg",
        "format": "javascript",
        "syntax": "plain",
        "template": "$(document).ready(function(e) {\n    \n    $(\"form[ajax=true]\").submit(function(e) {\n        \n        e.preventDefault();\n        \n        var form_data = $(this).serialize();\n        var form_url = $(this).attr(\"action\");\n        var form_method = $(this).attr(\"method\").toUpperCase();\n        \n        $(\"#loadingimg\").show();\n        \n        $.ajax({\n            url: form_url, \n            type: form_method,      \n            data: form_data,     \n            cache: false,\n            success: function(returnhtml){                          \n                $(\"#result\").html(returnhtml); \n                $(\"#loadingimg\").hide();                    \n            }           \n        });    \n        \n    });\n    \n});",
        "x": 330,
        "y": 420,
                "76c9419f34710a07"
        "id": "454fc4dacfaa7a48",
        "type": "http response",
        "x": 770,
        "y": 420,
        "id": "c8f17365680d23fc",
        "type": "template",
        "name": "HTML",
        "field": "payload",
        "fieldType": "msg",
        "format": "handlebars",
        "template": "<html>\n<head>\n    <title>Oregon and ESP8266 Weather Station</title>\n    <meta name=\"viewport\" content=\"initial-scale=1.0, width=device-width\">\n    <meta charset=\"utf-8\">\n    <meta http-equiv='refresh' content='30'>\n    <script src=\"http://cdnjs.cloudflare.com/ajax/libs/jquery/2.1.0/jquery.min.js\">\n    </script>\n    <style>\n{{{payload.style}}}\n    </style>\n</head>\n<h1>Oregon and ESP8266 Weather Station</h2>\n<h3>Location: Monrovia, CA (alt 705 feet)</h3>\n\n<div class='container'>\n    <div class='data temperature'>\n        <div class='side-by-side icon'>\n            <svg enable-background='new 0 0 19.438 54.003' height=54.003px id=Layer_1 version=1.1\n                viewBox='0 0 19.438 54.003' width=19.438px x=0px xml:space=preserve xmlns=http:>/www.w3.org/2000/svg\n            xmlns:xlink=http://www.w3.org/1999/xlink y=0px>\n            <g>\n            <path d='M11.976,8.82v-2h4.084V6.063C16.06,2.715,13.345,0,9.996,0H9.313C5.965,0,3.252,2.715,3.252,6.063v30.982\nC1.261,38.825,0,41.403,0,44.286c0,5.367,4.351,9.718,9.719,9.718c5.368,0,9.719-4.351,9.719-9.718\nc0-2.943-1.312-5.574-3.378-7.355V18.436h-3.914v-2h3.914v-2.808h-4.084v-2h4.084V8.82H11.976z M15.302,44.833\nc0,3.083-2.5,5.583-5.583,5.583s-5.583-2.5-5.583-5.583c0-2.279,1.368-4.236,3.326-5.104V24.257C7.462,23.01,8.472,22,9.719,22\ns2.257,1.01,2.257,2.257V39.73C13.934,40.597,15.302,42.554,15.302,44.833z' fill=#F29C21/></g></svg>\n        </div>\n        <div class='side-by-side text'>\n            Temperature\n        </div>\n        <div class='side-by-side reading'>\n<!--            global.get('outdoor') -->\n                {{#payload}}\n                \n                {{/payload}}\n            < span class='superscript'>&degF</span>\n        </div>\n    </div>\n<!--    <div class='data pressure'>        -->\n<!--        <div class='side-by-side icon'>        -->\n<!--            <svg enable-background='new 0 0 40.542 40.541' height=40.541px id=Layer_1 version=1.1                          -->\n<!--                viewBox='0 0 40.542 40.541' width=40.542px x=0px xml:space=preserve xmlns=http:>/www.w3.org/2000/svg       -->\n<!--            xmlns:xlink=http://www.w3.org/1999/xlink y=0px>        -->\n<!--            <g>        -->\n<!--            <path d='M34.313,20.271c0-0.552,0.447-1,1-1h5.178c-0.236-4.841-2.163-9.228-5.214-12.593l-3.425,3.424           -->\n<!--c-0.195,0.195-0.451,0.293-0.707,0.293s-0.512-0.098-0.707-0.293c-0.391-0.391-0.391-1.023,0-1.414l3.425-3.424                -->\n<!--c-3.375-3.059-7.776-4.987-12.634-5.215c0.015,0.067,0.041,0.13,0.041,0.202v4.687c0,0.552-0.447,1-1,1s-1-0.448-1-1V0.25      -->\n<!--c0-0.071,0.026-0.134,0.041-0.202C14.39,0.279,9.936,2.256,6.544,5.385l3.576,3.577c0.391,0.391,0.391,1.024,0,1.414           -->\n<!--c-0.195,0.195-0.451,0.293-0.707,0.293s-0.512-0.098-0.707-0.293L5.142,6.812c-2.98,3.348-4.858,7.682-5.092,12.459h4.804      -->\n<!--c0.552,0,1,0.448,1,1s-0.448,1-1,1H0.05c0.525,10.728,9.362,19.271,20.22,19.271c10.857,0,19.696-8.543,20.22-19.271h-5.178    -->\n<!--C34.76,21.271,34.313,20.823,34.313,20.271z M23.084,22.037c-0.559,1.561-2.274,2.372-3.833,1.814                             -->\n<!--c-1.561-0.557-2.373-2.272-1.815-3.833c0.372-1.041,1.263-1.737,2.277-1.928L25.2,7.202L22.497,19.05                          -->\n<!--C23.196,19.843,23.464,20.973,23.084,22.037z' fill=#26B999/></g></svg>                                                      -->\n<!--        </div>        -->\n<!--        <div class='side-by-side text'>        -->\n<!--            Pressure        -->\n<!--        </div>        -->\n<!--        <div class='side-by-side reading'>        -->\n<!--            (int)pressure        -->\n<!--            <span class='superscript'>hPa</span>        -->\n<!--        </div>        -->\n<!--    </div>        -->\n<!--        -->\n    <div>\n        <form method=\"post\" action=\"/{{url}}\" ajax=\"true\">\n            <label for=\"fname\">First Name</label>\n            <input type=\"text\" id=\"fname\" name=\"firstname\">\n\n            <label for=\"lname\">Last Name</label>\n            <input type=\"text\" id=\"lname\" name=\"lastname\">\n\n            <label for=\"country\">Country</label>\n            <select id=\"country\" name=\"country\">\n                <option value=\"uk\">United Kingdom</option>\n                <option value=\"canada\">Canada</option>\n                <option value=\"usa\">USA</option>\n            </select>\n\n            <input type=\"submit\" value=\"Submit\">\n        </form>\n    </div>\n    <div>\n        <span id=\"result\"></span>\n    </div>\n\n    </body>\n</html>\n<script>\n    { { { payload.script } } }\n</script>\n\n",
        "x": 630,
        "y": 420,
                "454fc4dacfaa7a48"
        "id": "f11b2d67bb30c7d7",
        "type": "comment",
        "name": "Login Form",
        "info": "",
        "x": 290,
        "y": 380,
        "id": "77a000a0a2ac2e4f",
        "type": "comment",
        "name": "Inject msg object properties",
        "info": "",
        "x": 340,
        "y": 280,
        "id": "f62e63adabd04bec",
        "type": "comment",
        "name": "Website",
        "info": "",
        "x": 80,
        "y": 280,
        "id": "91fdaec28a2d5846",
        "type": "debug",
        "name": "debug 4",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 620,
        "y": 320,
I am completely baffled as yo why 3 of the 4 variables work as expected while indoor_bat is undefined when I try to access.
Help will be greatly appreciated.
Thank you
indodor_bat?
Thanks, I thought I fixed all of those, but I guess not. It's working now
