For instance the msg.payload is this:
DayEnd,33,128,99
I want to derive 4 variables:
time, r, g and b
to use in the same node to do things.
DayEnd,33,128,99
time, r, g and b
Unless i am misunderstanding:
let input = msg.payload.split(",") // DayEnd,33,128,99
let time = input[0]
let r = input[1]
let g = input[2]
let b = input[3]
Thanks.
I just found that command and was in the process of testing it.
You posting it is good to see.
The die-hards would use consts instead of lets, but you get the gist ![]()
FYI, you can also assign the list of split parts to multiple vars like so:
let [time, r, g, b] = msg.payload.split(",");
Btw, if the split only returned 3 parts, the 4th variable would have the value undefined
