Nested Split and Delay nodes hammering REST API
Hi everyone,
I am calling a REST API with the http request node inside nested split nodes. I would like to limit the API calls to an arbitrary rate.
The Delay node in Rate Limit mode does the trick, but as soon as I nest the split nodes, simultaneous calls occur to the REST API. I need to nest as I need to feed the result (JSON array) of the API call into the next split.
I want to limit the http request calls to the REST API to one every three seconds.
The current output is:
Time Calls
0 A, X (simultaneous calls)
3 B, Y (simultaneous calls)
6 C, X (simultaneous calls)
9 Y
12 X
15 Y
My desired output:
Time Calls
0 A
3 X
6 Y
9 B
12 X
15 Y
18 C
21 X
24 Y
I suspect using a function node with a flush to the delay node would help but I cannot figure it out.
On second thoughts I think my problem is related to the how the split works. It parallels everything. I was assuming that it works serially.
Can anyone please provide some here. My goal looks like making the split nodes execute serially in a loop.
Cheers,
Chris
here is a simplified flow that represents my challenge
        "id": "058fb5958f470e48",
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": "",
        "env": []
        "id": "56dd7928a9459d2a",
        "type": "inject",
        "z": "058fb5958f470e48",
        "name": "[\"A\", \"B\", \"C\"]",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "[\"A\", \"B\", \"C\"]",
        "payloadType": "json",
        "x": 170,
        "y": 160,
                "710df86d6b197cff"
        "id": "710df86d6b197cff",
        "type": "split",
        "splt": "\\n",
        "spltType": "str",
        "arraySplt": 1,
        "arraySpltType": "len",
        "stream": false,
        "addname": "",
        "x": 350,
        "y": 160,
                "df33284335bffebb"
        "id": "b27cdeaac4471314",
        "type": "debug",
        "name": "Debug ABC",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 710,
        "y": 100,
        "id": "0be44aaa65e1f281",
        "type": "template",
        "name": "[\"X\", \"Y\"]",
        "field": "payload",
        "fieldType": "msg",
        "format": "handlebars",
        "syntax": "mustache",
        "template": "[\"X\", \"Y\"]",
        "output": "json",
        "x": 880,
        "y": 160,
                "b1668ae01e9f46d7"
        "id": "5c55a06787c9d3a2",
        "type": "split",
        "splt": "\\n",
        "spltType": "str",
        "arraySplt": 1,
        "stream": false,
        "addname": "",
        "x": 210,
        "y": 300,
                "aed2a5c75af4b18d"
        "id": "96cb8e104a0d6bd4",
        "type": "debug",
        "name": "Debug XY",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "x": 600,
        "y": 240,
        "id": "539fc7d2d2d7fa6c",
        "type": "function",
        "name": "Placeholder\\n HTTP Req",
        "func": "\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 610,
        "y": 300,
                "05f98fa8bb5b6880"
        "id": "d35c94d55a345441",
        "type": "function",
        "func": "msg.payloadsplit1 = msg.payload;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 710,
        "y": 160,
                "0be44aaa65e1f281"
        "id": "c13782c0a9c6f5ef",
        "type": "join",
        "mode": "auto",
        "build": "object",
        "property": "payload",
        "propertyType": "msg",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": "false",
        "timeout": "",
        "count": "",
        "reduceRight": false,
        "x": 950,
        "y": 300,
                "2371ebc235e95b3f"
        "id": "b1668ae01e9f46d7",
        "type": "link out",
        "name": "link out 14",
        "mode": "link",
        "links": [
            "6d796ef8be569c35"
        "x": 985,
        "y": 160,
        "id": "6d796ef8be569c35",
        "type": "link in",
        "name": "link in 14",
        "links": [
            "b1668ae01e9f46d7"
        "x": 115,
        "y": 300,
                "5c55a06787c9d3a2"
        "id": "df33284335bffebb",
        "type": "delay",
        "pauseType": "rate",
        "timeout": "5",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "3",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 520,
        "y": 160,
                "d35c94d55a345441",
                "b27cdeaac4471314"
        "id": "aed2a5c75af4b18d",
        "type": "delay",
        "timeout": "5",
        "rate": "1",
        "nbRateUnits": "3",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 400,
        "y": 300,
                "539fc7d2d2d7fa6c",
                "96cb8e104a0d6bd4"
        "id": "05f98fa8bb5b6880",
        "type": "join",
        "mode": "auto",
        "build": "object",
        "key": "topic",
        "joiner": "\\n",
        "timeout": "",
        "count": "",
        "x": 790,
        "y": 300,
                "c13782c0a9c6f5ef",
                "f16f170955f3a4c6"
        "id": "f16f170955f3a4c6",
        "type": "debug",
        "name": "debug 89",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 960,
        "y": 240,
        "id": "2371ebc235e95b3f",
        "type": "debug",
        "name": "debug 90",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1140,
        "y": 240,
This would probably work.
[{"id":"56dd7928a9459d2a","type":"inject","z":"058fb5958f470e48","name":"[\"A\", \"B\", \"C\"]","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[\"A\", \"B\", \"C\"]","payloadType":"json","x":170,"y":160,"wires":[["710df86d6b197cff"]]},{"id":"710df86d6b197cff","type":"split","z":"058fb5958f470e48","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":350,"y":160,"wires":[["df33284335bffebb"]]},{"id":"df33284335bffebb","type":"delay","z":"058fb5958f470e48","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"30","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":520,"y":160,"wires":[["d35c94d55a345441","b27cdeaac4471314"]]},{"id":"66217ee313e52c5b","type":"function","z":"058fb5958f470e48","name":"function 15","func":"\nreturn {flush:1};","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":870,"y":360,"wires":[["df33284335bffebb"]]},{"id":"d35c94d55a345441","type":"function","z":"058fb5958f470e48","name":"Placeholder\\n HTTP Req","func":"msg.payloadsplit1 = msg.payload;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":710,"y":160,"wires":[["0be44aaa65e1f281"]]},{"id":"b27cdeaac4471314","type":"debug","z":"058fb5958f470e48","name":"Debug ABC","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":710,"y":100,"wires":[]},{"id":"05f98fa8bb5b6880","type":"join","z":"058fb5958f470e48","name":"","mode":"auto","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":"false","timeout":"","count":"","reduceRight":false,"x":770,"y":300,"wires":[["c13782c0a9c6f5ef","f16f170955f3a4c6","66217ee313e52c5b"]]},{"id":"0be44aaa65e1f281","type":"template","z":"058fb5958f470e48","name":"[\"X\", \"Y\"]","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"[\"X\", \"Y\"]","output":"json","x":880,"y":160,"wires":[["b1668ae01e9f46d7"]]},{"id":"539fc7d2d2d7fa6c","type":"function","z":"058fb5958f470e48","name":"Placeholder\\n HTTP Req","func":"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":610,"y":300,"wires":[["05f98fa8bb5b6880","8226be2340f44d54"]]},{"id":"c13782c0a9c6f5ef","type":"join","z":"058fb5958f470e48","name":"","mode":"auto","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":"false","timeout":"","count":"","reduceRight":false,"x":950,"y":300,"wires":[["2371ebc235e95b3f"]]},{"id":"f16f170955f3a4c6","type":"debug","z":"058fb5958f470e48","name":"debug 89","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":960,"y":240,"wires":[]},{"id":"b1668ae01e9f46d7","type":"link out","z":"058fb5958f470e48","name":"link out 14","mode":"link","links":["6d796ef8be569c35"],"x":985,"y":160,"wires":[]},{"id":"aed2a5c75af4b18d","type":"delay","z":"058fb5958f470e48","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"30","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":400,"y":300,"wires":[["539fc7d2d2d7fa6c","96cb8e104a0d6bd4"]]},{"id":"8226be2340f44d54","type":"function","z":"058fb5958f470e48","name":"function 16","func":"\nreturn {flush:1};","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":670,"y":360,"wires":[["aed2a5c75af4b18d"]]},{"id":"2371ebc235e95b3f","type":"debug","z":"058fb5958f470e48","name":"debug 90","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1140,"y":240,"wires":[]},{"id":"5c55a06787c9d3a2","type":"split","z":"058fb5958f470e48","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":210,"y":300,"wires":[["aed2a5c75af4b18d"]]},{"id":"96cb8e104a0d6bd4","type":"debug","z":"058fb5958f470e48","name":"Debug XY","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":600,"y":240,"wires":[]},{"id":"6d796ef8be569c35","type":"link in","z":"058fb5958f470e48","name":"link in 14","links":["b1668ae01e9f46d7"],"x":115,"y":300,"wires":[["5c55a06787c9d3a2"]]}]
Thanks, I will give it a go. This enforces the order and gives me a starting point to find the final solution
