Thanks for the response.
"id": "7e0db130af3023fb",
"type": "subflow",
"name": "level2",
"info": "",
"category": "",
"in": [
"x": 140,
"y": 160,
"id": "5205d3ce0a7b11d2"
"out": [],
"env": [],
"meta": {},
"color": "#DDAA99"
"id": "cb683474f694958c",
"type": "change",
"z": "7e0db130af3023fb",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "#:(tofile)::level2",
"tot": "flow"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 570,
"y": 80,
"0dfd1ab5128ccf38"
"id": "0dfd1ab5128ccf38",
"type": "debug",
"name": "level2",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 770,
"y": 80,
"id": "5205d3ce0a7b11d2",
"type": "change",
"rules": [
"t": "set",
"p": "#:(tofile)::level2",
"pt": "flow",
"to": "level2",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 380,
"y": 160,
"id": "ec161b52fcccc16c",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "",
"payloadType": "date",
"x": 210,
"y": 80,
"cb683474f694958c"
"id": "b98a91283534ce8f",
"type": "subflow",
"name": "level1",
"info": "",
"category": "",
"in": [
"x": 60,
"y": 160,
"id": "8599f276d85be9a9"
"id": "d116b8a8ed7b3499"
"out": [],
"env": [],
"meta": {},
"color": "#DDAA99"
"id": "d116b8a8ed7b3499",
"type": "subflow:7e0db130af3023fb",
"z": "b98a91283534ce8f",
"env": [],
"x": 520,
"y": 240,
"id": "9f077f1f577ad0ba",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "#:(tofile)::level1",
"tot": "flow"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 560,
"y": 80,
"2ffa5379e2e92a3a"
"id": "2ffa5379e2e92a3a",
"type": "debug",
"name": "level1",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 760,
"y": 80,
"id": "8599f276d85be9a9",
"type": "change",
"rules": [
"t": "set",
"p": "#:(tofile)::level1",
"pt": "flow",
"to": "level1",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 370,
"y": 160,
"id": "cccd01e20f14d038",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "",
"x": 200,
"y": 80,
"9f077f1f577ad0ba"
"id": "67e8422ee554afd3",
"type": "comment",
"name": "flow to msg payload",
"info": "",
"x": 550,
"y": 20,
"id": "3cbe543c3d6d04d4",
"type": "subflow:b98a91283534ce8f",
"z": "f26c3086d2e77026",
"env": [],
"x": 530,
"y": 200,
"id": "6ad93daec4b7eeed",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "Write Data to File",
"payloadType": "str",
"x": 330,
"y": 200,
"3cbe543c3d6d04d4",
"ecd555748fa21395"
"id": "ecd555748fa21395",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"x": 560,
"y": 160,
and in the settings:
contextStorage: {
tofile: { module: "localfilesystem"},
default: { module: "memory" }
