New line constant with text variable
hello
I am trying output some text from a function to a text node using:
let var1 = "";
var1 = var1 + "new text \r \n";
var1 = var1 + "new text 2 \r \n";
msg.payload = var1;
It works fine and var1 displays in the text node, but I need it to add a new line constant between new text and new text 2, so far I am seeing all new text and new text 2 on the same line
Any thoughts?
Hi @Sirhc
Which text node are you referring to? Is this Node-RED Dashboard? FlowFuse Dashboard? Or something else entirely?
This is in the node red dashboard, using the text node.
Ok, I don't really know, but I thought it was <br> for new line.
(Sorry, I'll go away)
Ah it is
! thank you very much!
If it was me, please mark it to help anyone else with the same problem.
Just a comment that instead of
let var1 = "";
var1 = var1 + "new text";
var1 = var1 + "<br>";
var1 = var1 + "new text 2";
msg.payload = var1;
Your function could be
msg.payload = "new text" + "<br>" + "new text 2"
