✨ NEW RELEASE: uibuilder v6.5.0 - Feature & Bug Fix Release
Hi all uibuilder fans! This release took rather longer than expected to release at over 4 months.
Apologies, the documentation has fallen a little behind with this release as things took longer and more new features were added than expected. But I needed to get this release out as it contains some important bug fixes as well.
Hope you like the new features. As always, comments and bug reports always welcome - as are pull requests.
NEW Features
  • New zero-code node uib-tag - creates a single html element based on the given tag name (e.g. create a link element from an a tag). Also works with web component custom tags. Use this when you want to add something not covered by uib-element. Lets you specify slot content (html or Markdown) and attributes at the same time.
  • The client library now filters inbound messages according to pageName, clientId, and/or tabId set in either msg._uib or msg._ui. The uib-element, uib-update and uib-tag nodes will be updated in a future release to allow you to specify them in the Editor. Until then, simply apply a change node to the output of those nodes.
  • There is a new, dynamic page at ../uibuilder/apps that lists (with links) all uibuilder instance endpoints. Currently only a very simple list but the plan is to add an instance title and description field to uibuilder which would then be populated into this page. Use as an index of all of your main web pages (strictly, this is a list of all of the uibuilder-driven web apps. Apps may have multiple pages of course).
  • The uibuilder client connection control msg now reports the URL parameters (AKA search parameters) for the connection from the client. This is another way of passing data from a client to the server. Obviously, you should never trust user input - always limit, check and validate user input.
  • uib-element now allows the core data for the element to be defined in the node or on a context variable and other locations, you are no longer forced to use msg.payload. It also now allows the incoming msg.payload to be sent to the client to allow for local processing if required.
  • uibuilder Instance routes/middleware
    You can now add ExpressJS routes and other middleware to a single instance of uibuilder (a specific uibuilder node), not just to all nodes. Especially useful if you want to add custom security (login, registration, etc) to just one instance.
    The new feature lets you specify the sub-url-path, the HTTP method and the callback function. Paths can include wildcards and parameters too. The routes are always added to the instance router which forces them to only ever be sub-url-paths of the specified instance. e.g. if your instance url is test, a route with a path of /foo/:bah will ALWAYS be .../test/foo/.... This is for security. Note that you are responsible for creating unique URL paths, no checking is done and ExpressJS is quite happy to have multiple path handlers but if you provide a terminating response (e.g. res.status(200)) and no next() call, the call stack is obviously terminated. If you include a call to next(), overlapping route callbacks will also be triggered. In that case, make sure you do not do any more res.xxxx() responses otherwise you will get an ERR_HTTP_HEADERS_SENT error.
    To add route handlers, create 1 or more .js files in the <instanceRoot>/routes/ folder. See the docs for details.
    What can I do? Authentication, authorisation, http headers, dynamic html changes/additions, js inserts, logging, server-side includes, server-side rendering (e.g. Jade, ...) ...
NEW NODE: uib-tag
  • Creates a single html element based on the given tag name (e.g. create a link element from an a tag).
  • Works with web component custom tags.
  • Lets you specify slot content (html or Markdown) and attributes at the same time.
  • Filters out msg._ui from input if it includes msg._ui.from set to "client". We don't want to loop from output to input. ref
Changes to uibuilder client Library
  • FIX Change warn msg "[Ui:_uiManager] No method defined for msg._ui[0]. Ignoring" to an error so it is more visible.
  • FIX Issue #213 - SVG flow example not working _uiComposeComponent is not a function at htmlClone index.js:52:15
    Caused by the move of all ui fns to a separate class. So _uiComposeComponent is no longer accessible. It should not have been used in the example anyway since anything starting with an underscore should be for internal use only. My bad.
    `uibuilder.uiEnhanceElement(el, component)`` added. Example will be updated again once this is released
  • NEW FUNCTION uibuilder.notify(config) - If possible (not all browsers yet fully support it), use the browser Notification API to show an operating system notification. Supports a simple click reponse which can be used with uibuilder.eventSend to notify Node-RED that a user clicked the notification. Note that there are significant inconsistencies in how/whether this API is handled by browsers. It may not always work.
  • No longer processes input messages if either msg._uib or msg._ui includes either pageName, clientId, and/or tabId and where those parameters do not match the current page or client.
  • Improvements and corrections to the eventSend function. Allowing more event types to be sensible handled (including the Notify response). Also added CSS class information & specific outputs for notifications. Also, added input field types to form outputs.
  • Added window.uib as a synonym of window.uibuilder. So you can do things like uib.logLevel = 5 instead of uibuilder.logLevel = 5
  • Added flag to indicate if the DOMPurify library is loaded. Added warnings to the include() function when it is loaded since some includes will be filtered by the purify process for safety. Updated the front-end client introduction document with details about DOMPurify, how to load it and use it.
  • Added flag to indicate if the Markdown-IT library is loaded. Updated the front-end client introduction document with details about how to load the library and use it.
  • Trigger onChange when msg.payload received along with msg._ui. Previous update turned this off completely but that is too restrictive. Use the Passthrough option in uib-element for example so that data can be further processed in the front-end if required.
  • When the client sends a msg back to Node-RED that includes msg._ui properties, the client adds msg._ui.from set to "client". This lets the uib-element, uib-update, and uib-tag nodes filter them out when flow editors have looped an output msg back to the input. ref
Changes to uibuilder main node
  • NEW Instance route/middleware handlers - allows you to create custom url routes and custom middleware functions that only impact routes for a single instance of uibuilder.
  • NEW Deep object find function added as RED.util.uib.deepObjFind so that it can be used in function nodes. Useful for manipulating msg._ui objects which can get very deep. See Manipulating msg._ui for details.
  • NEW A dynamically generated list of all uibuilder apps is now available at ../uibuilder/apps. In addition, title and description fields have been added to the Advanced tab in the uibuilder node. These are used on the apps page. You can also output the detailed list in Node-RED using a function node with RED.util.uib.listAllApps(). The detailed list also shows what node defines the app.
  • Filter out msg._ui from input if it includes msg._ui.from set to "client". We don't want to loop from output to input. ref
Changes to uib-element node
  • FIX Was issuing a node.warn showing the input type (happening on v6.1 as well) - only for table type. Now removed.
  • FIX Chaining to a page title deleted the previous chain - putting title first was ok. Now works either way.
  • FIX Form checkbox "value" output from auto-send was always "on". Because HTML is sometimes utterly stupid! Input tags of type "checkbox" do not set a value like other inputs! They only set the "checked" attribute. Fixed by forcing the value attribute to be set. Issue #221, Discussion #219.
  • KEY CHANGE Added option to select core data input other than msg.payload.
    This means that you can define the UI element directly in the node if you want. This includes the use of JSONata for dynamically defined elements, allowing for even simpler msg inputs should this be desired.
  • KEY CHANGE Added an option to pass through msg.payload. When sent to the front-end, the client library will trigger standard events to allow further processing of the data in the front-end.
    This means that you can use uibuilder.onChange etc in the front-end even though the msg contains msg._ui which would normally prevent this from happening.
  • Order of node properties changed in the Editor. Hopefully more logical.
  • Form additions:
    • Textarea input.
    • Select options drop-down input.
Changes to the uib-update node
Changes to CSS styles (uib-brand.css)
  • NEW Minified version included, use as @import url("../uibuilder/uib-brand.min.css");
  • Reduced thickness of error border on form input fields.
  • Switched form layout from Float to Flex. Added breakpoint at width=600px where layout becomes vertical instead of horizontal.
  • CSS Variables
    • NEW --mode - "light" or "dark" according to the current browser preference or html class override.
    • NEW --text-hue and --surface-hue allows independent colour control of standard text and backgrounds. Defaults to --brand-hue.
    • NEW --complementary-offset - defaults to 180, you are unlikely to want to change this.
    • NEW --font-style - set to sans-serif by default.
  • CSS Classes
    • NEW .flex-wrap - auto-wrapping flex layout.
    • NEW .grid-fit - auto-columns with number set by --grid-fit-min.
    • NEW .compact - removes margin and reduces top/bottom padding to a minimum (0.2rem).
    • NEW button.compact - Removes rounded corners and reverts background to parent. Minimises margin and padding.
Changes to uibuilder templates
  • Replaced all references to uib-brand.css with uib-brand.min.css for efficiency.
Documentation updates
  • Details and links for using the DOMPurify external library.
  • Lots more detail added to the uib-brand.css documentation.
  • The usual set of documentation improvements, slowly improving things and trying to ensure that the documentation matches the actual implementation. :grin:
Other Changes
  • Remove dependency on express-validator as this is no longer used.
  • Add .keep empty files to template folders that should be empty because GIT doesn't think anyone needs to keep empty folders - stupid!
And as I didn't get a chance to update the examples, here are a couple of test flows for you.
Firstly, some simple tests for the new uib-tag node that illustrate how to use it.
[{"id":"f5891d10dc837fd3","type":"comment","z":"3badb0a6906eef7f","name":"uib-tag example - similar to uib-element but adds/replaces a single HTML or web component element (tag)","info":"","x":400,"y":2580,"wires":[]},{"id":"e32ba9f821a3e9f2","type":"group","z":"3badb0a6906eef7f","name":"Add a <div> tag contining some dynamic text, an <hr>, and an <a> tag using uib-tag nodes \\n <hr> has no ID so cannot be removed on its own, only via its parent. <a> tag's slot text is defined in the node so no extra change node needed. \\n ","style":{"fill":"#bfdbef","fill-opacity":"0.32","label":true,"color":"#000000"},"nodes":["bbc98d588f537ebe","50bd68a804728c63","0551e90124f1644a","30c550e25667339a","411f46b6e8198d5a","f5f1c92f67f79b61","870f9db775b0e44a"],"x":34,"y":2607,"w":992,"h":154},{"id":"bbc98d588f537ebe","type":"link out","z":"3badb0a6906eef7f","g":"e32ba9f821a3e9f2","name":"link out 54","mode":"link","links":["c203417099e22d29"],"x":985,"y":2680,"wires":[]},{"id":"50bd68a804728c63","type":"inject","z":"3badb0a6906eef7f","g":"e32ba9f821a3e9f2","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"uib-tag","payload":"\"[\" & $formatInteger($random() * 100, \"#00\") & \"] Dynamic title\"","payloadType":"jsonata","x":150,"y":2680,"wires":[["0551e90124f1644a"]]},{"id":"0551e90124f1644a","type":"uib-tag","z":"3badb0a6906eef7f","g":"e32ba9f821a3e9f2","name":"","topic":"","tag":"div","parent":"body","parentSourceType":"str","elementId":"tag-div1","elementIdSourceType":"str","position":"last","positionSourceType":"str","slotSourceProp":"payload","slotSourcePropType":"msg","attribsSource":"{\"style\":\"border:1px solid red;padding:1em;background-color:var(--surface3);\"}","attribsSourceType":"json","slotPropMarkdown":false,"x":330,"y":2680,"wires":[["f5f1c92f67f79b61"]]},{"id":"30c550e25667339a","type":"uib-tag","z":"3badb0a6906eef7f","g":"e32ba9f821a3e9f2","name":"","topic":"","tag":"a","parent":"#tag-div1","parentSourceType":"str","elementId":"tag-a1","elementIdSourceType":"str","position":"last","positionSourceType":"str","slotSourceProp":"A Link","slotSourcePropType":"str","attribsSource":"{\"href\":\"http://example.com\",\"title\":\"A link\"}","attribsSourceType":"json","slotPropMarkdown":false,"x":800,"y":2680,"wires":[["bbc98d588f537ebe"]]},{"id":"411f46b6e8198d5a","type":"inject","z":"3badb0a6906eef7f","g":"e32ba9f821a3e9f2","name":"Remove","props":[{"p":"mode","v":"remove","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":140,"y":2720,"wires":[["0551e90124f1644a"]]},{"id":"f5f1c92f67f79b61","type":"uib-tag","z":"3badb0a6906eef7f","g":"e32ba9f821a3e9f2","name":"","topic":"","tag":"hr","parent":"#tag-div1","parentSource":"","parentSourceType":"str","elementId":"","elementIdSourceType":"str","position":"last","positionSourceType":"str","slotSourceProp":"","slotSourcePropType":"msg","attribsSource":"","attribsSourceType":"msg","slotPropMarkdown":false,"x":550,"y":2680,"wires":[["30c550e25667339a"]]},{"id":"870f9db775b0e44a","type":"inject","z":"3badb0a6906eef7f","g":"e32ba9f821a3e9f2","name":"Remove","props":[{"p":"mode","v":"remove","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":590,"y":2720,"wires":[["30c550e25667339a"]]},{"id":"1a0c9ab3c2f839e0","type":"group","z":"3badb0a6906eef7f","name":"Dynamically add a button that sends a msg back here using eventSend. \\n ","style":{"fill":"#bfdbef","fill-opacity":"0.32","label":true},"nodes":["c083601aa040378a","293d0b3149c64d12","ddedd347be10cd4b","1a1fdf8d6401b8b1"],"x":34,"y":2783,"w":992,"h":138},{"id":"c083601aa040378a","type":"inject","z":"3badb0a6906eef7f","g":"1a0c9ab3c2f839e0","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"uib-tag","payload":"\"[\" & $formatInteger($random() * 100, \"#00\") & \"] Dynamic title\"","payloadType":"jsonata","x":150,"y":2840,"wires":[["ddedd347be10cd4b"]]},{"id":"293d0b3149c64d12","type":"inject","z":"3badb0a6906eef7f","g":"1a0c9ab3c2f839e0","name":"Remove","props":[{"p":"mode","v":"remove","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":140,"y":2880,"wires":[["ddedd347be10cd4b"]]},{"id":"ddedd347be10cd4b","type":"uib-tag","z":"3badb0a6906eef7f","g":"1a0c9ab3c2f839e0","name":"","topic":"","tag":"button","parent":"body","parentSourceType":"str","elementId":"tag-btn1","elementIdSourceType":"str","position":"last","positionSourceType":"str","slotSourceProp":"A Button","slotSourcePropType":"str","attribsSource":"{\"onclick\":\"uibuilder.eventSend(event)\"}","attribsSourceType":"json","slotPropMarkdown":false,"x":560,"y":2840,"wires":[["1a1fdf8d6401b8b1"]]},{"id":"1a1fdf8d6401b8b1","type":"link out","z":"3badb0a6906eef7f","g":"1a0c9ab3c2f839e0","name":"link out 56","mode":"link","links":["c203417099e22d29"],"x":985,"y":2840,"wires":[]}]
Update: Sorry, the big flow is too big to share here! So please get it from GitHub:
node-red-contrib-uibuilder/examples/zero-code.json at main · TotallyInformation/node-red-contrib-uibuilder (github.com)
It loads a complete tab of examples for both uib-element and uib-tab. It is the updated "Zero-Code" example in the library (or rather it will be when the next update is pushed out).
Amazing work since i have tried uibuilder last time !!!
Just a small (and stupid) question : I've created a form with uib-element. It works with a inject node but i want that the form will be displayed by default on my html page. Is it possible ?
Where is my hard work on your 3D modes Julian :wink:
I don't use it - But awsome work!
EDIT
I have just realised how old this thread is :crazy_face: (hey its Friday)
Thanks. Lots more to come and v6.6 is very close to release, I just need to stop myself from adding things to it!
No stupid questions exist, only stupid answers! :rofl:
So each time you trigger the same uib-element node, it REPLACES (or adds if it doesn't yet exist) the element. But of course, that is only happening at the time the inject happens.
If your page wasn't open when the inject happened, then when you open the page, you don't get it.
That is why the uib-cache node was created. Add a cache node between the element and the uibuilder node and make sure you set a unique topic for each flow that contains a sequence of uib nodes. That will let the cache node record the last output. You then connect from the 2nd output of the uibuilder node also into the cache node and then any newly or re-loaded page will get the last output.
There is a cache example in the uibuilder examples in the node-red library so you can just import it to see how it works.
As a bonus, you also have another option. This is useful if the structure of your page doesn't really change very much. Once you have the basic structure set up, you can simply copy the live HTML from your browsers developer console and paste it into your index.html file. Now you don't need to cache all of the basic structure and send it on each (re)load. That has the added advantage that proxy and browser caching will kick in and potentially make things even faster.
In v6.6, there is even a new node that will let you do this automatically. :slight_smile:
Thank you very much for the answer !
I think the best solution for me will be to wait for V.6.6 :stuck_out_tongue_winking_eye:
