New SCADA ui nodes
Sorry Dave, dealing with a Boiler Outage and an API that has been changed without letting people know!!
Thanks for the feedback. Very delighted to see it being adopted by the NR family. Please allow a couple off weeks for fixes.
:slight_smile: :love_you_gesture:
Hi
I’d like to know if any of you are noticing a ‘flickering effect’ with the 3DM SCADA trend element (refresh rate)?
I created a simple trend with a single value on my Raspberry Pi (one that isn’t under much load): the effect is very slight.
I created the same trend on my other Raspberry Pi (a development Raspberry Pi, which is under slightly more load) and there, the curve disappears briefly but completely.
Is this something you’ve noticed before?
Kind regards,
Jean-Remy
Thanks for doing this! Scada HMIs for home automation are a major missing link.
I just installed this and played around a bit. One of the first things I added was a valve. I could only find one symbol however. As you know, there are a bunch of valve types e.g. three port, proportional, etc. How would these be handled?
Haven't noticed any flickering with the Trend/Line Chart widget even though I have four of them displaying different readings. Readings are sent every 5-min by a Python script in the sensors.
As the readings update fairly slowly, I set the refresh in the Trend widget as follow...
The traces disappear for a fraction of a second during refresh - which is what I expected.
@dynamicdave: Thank you for your answer.
The message that appear at the refresh is "Loading History..."
when your have a very low system :wink:.
Simple question: Did you find how to add two (or more) Y axe at a trend ?
Regards
Jean-Remy
If you mean the Horizontal Axis (X), it is a time Axis, so no, you can't add.
If the Vertical Axis (Y), then it is a simple trend chart so you can add measurements/telemetry variables, but not change the Axis scales as far as I can see - there is no input to do this.
Also - if you're using a desktop machine (e.g. PC) you can use the wheel on the mouse to zoom in/out of the traces and by holding-down the left-hand mouse button you can move the position on the traces.
Not sure if I am missing it, but is there a straight Push Button switch? (Push on / push off)
@smithtek It would be nice (for me :lol) if there was a switch which had feedback i.e. a change in state controlled by the Controller would change the switch colour. If a status changed an Input (ON/OFF) would be sent and a colour of the switch could be set to match (say Red/Green). Push the button, Output initiated, goes to Controller, changed state of Input registered by Push Button as message received from Controller. (Push to switch on, push to switch off with feedback of state from Controller).
Still looking for more than one valve...
Apologies for taking a while.
A new update is available 2.4.0
Most of the feedback and glitches should be fixed.
Any issues leave a message on here.
To install or upgrade to the latest version from the command line do this...
cd ~/.node-red
npm install smithtek-3dm-scada-canvas@latest
And to check installed version do this...
npm list smithtek-3dm-scada-canvas
Don't update this version!
There are some uncaught weird issues, it will break previous versions.
Will do an update. apologies. :frowning:
