Node and plugin in same package.json
Hello everyone, i'm trying to prepare the package for my own set of nodes and i've encountered a problem.
I have a plugin node and various other nodes and i want them to be installed in a single package but this keeps returning me an error if the plugins and node sections are together.
Basically this is my package.json:
  "name": "@sss/node-red-sss-dataManipulation",
  "version": "1.0.0",
  "description": "",
  "dependencies": {
		"axios": "^0.27.2",
		"crypto": "^1.0.1",
		"node-rsa": "^1.1.1",
		"rsa-pem-from-mod-exp": "^0.8.4",
		"utf8": "^3.0.0",
		"uuid": "^9.0.0",
		"mysql2": "^2.3.3",
        "pg": "^8.8.0",
		"alasql": "^1.7.3",
		"xlsx": "https://cdn.sheetjs.com/xlsx-0.18.10/xlsx-0.18.10.tgz",
		"sss-server": "file:./sss_server"
  "node-red": {
    "nodes": {
      "addcolumns": "sss_add_columns/addcolumns.js",
	  "create-view": "sss_create_view/create-view.js",
  	  "csv2array": "sss_csv2array/sss-csv2array.js",
	  "db-hub": "sss_db_hub/db-hub.js",
	  "filter": "sss_filter/sss-filter.js",
	  "get-view-values": "sss_get_view_values/get-view-values.js",
	  "joinmatrix": "sss_join_matrix/joinmatrix.js",
	  "merge-messages": "sss_merge_messages/merge-messages.js",
	  "register-notification": "sss_register_notification/register-notification.js",
	  "renamelabels": "sss_rename_labels/renamelabels.js",
	  "sss-server": "sss_server/sss-server.js",
	  "update-view": "sss_update_view/update-view.js",
	  "sss-user": "sss_user/sss-user.js",
	  "xlsx2array": "sss_xlsx2array/sss_xlsx2Array.js"
    "plugins": {
	  "sss-api": "sss_api/sss-api.js"
  "author": "DocSpace",
  "license": "ISC"
this does not work giving a similar exception:
TypeError: Cannot read properties of undefined (reading 'forEach')
at Object.addModule (/usr/src/node-red/node_modules/@node-red/registry/lib/registry.js:195:27)
at /usr/src/node-red/node_modules/@node-red/registry/lib/loader.js:138:34
Is there a way to fix this?
Strangely, if i put my plugin node inside the nodes section everything will work except for a warning displayed at the start of nodered:
[warn] [@sss/node-red-sss-dataManipulation/sss-api] TypeError: Cannot read properties of undefined (reading 'plugins')
I came across someone with the same problem : How do Node-RED plugins work?
Is it fixable?
Thanks in advance
This may simply be a bug in Node-RED around how it handles modules that have both plugins and nodes in.
I know that's something I tested when we introduced plugins, but I cannot immediately point to an example module that does this today.
I think we need to investigate a bit more closely.
Depending on what you have in the plugin code, a working could be to list it in the nodes section... but again, you'd need to test that carefully to make sure it behaved as you wanted.
Ok, i'll check for good, thanks a lot
As per my reply in the other thread, looks like you've hit this known issue: Race condition when loading module with both Plugin and Nodes · Issue #3523 · node-red/node-red (github.com)
