Node edit dialog in custom node not work
hi
I am use TypedInput Select box in my config node
check in this link
https://nodered.org/docs/creating-nodes/edit-dialog
but when open this config all value reset in default value ?
    RED.nodes.registerType('ClientConfig',{
        category: 'config',
        defaults: {
            name:    {value:"name of config" ,required:true},
            ASDUAddrLeng: { value: "", required:true,validate:RED.validators.number()},
            ASDUAddr : { value: "", required:true},
            IOAaddrLeng:{ value: "", required:true,validate:RED.validators.number()},
            COTaddrLeng:{ value:"", required:true,validate:RED.validators.number()},
            OriginAddr:{ value:"", required:true,validate:RED.validators.number()}
        label: function() {
            return this.name||"ClientConfig";
        oneditprepare: function () {
            var tabs = RED.tabs.create({
                onchange: function(tab) {
                    $("#node-config-client-config-content").children().hide();
                    $("#" + tab.id).show();
            tabs.addTab({
                label: this._("Application Layer")
            tabs.addTab({
                label: this._("Link Layer")
            tabs.addTab({
                label: this._("option")
            $("#node-config-input-ASDUAddrLeng").typedInput({
    types: [
            value: "ASDUAddrLeng",
            options: [
                { value: 1, label: "One Octet"},
                { value: 2, label: "Tow Octet"},
$("#node-config-input-IOAaddrLeng").typedInput({
    types: [
            value: "IOAaddrLeng",
            options: [
                { value: 3, label: "Three Octet"},
$("#node-config-input-COTaddrLeng").typedInput({
    types: [
            value: "COTaddrLeng",
            options: [
</script>
<script type="text/html" data-template-name="ClientConfig">
    <div class="form-row">
        <label for="node-config-input-name"><i class="fa fa-tag"></i> <span data-i18n="common.label.name"></span>name</label>
        <input type="text" id="node-config-input-name" data-i18n="[placeholder]common.label.name">
    </div>
        <ul style="min-width: 600px; margin-bottom: 20px;" id="node-config-client-config-tabs"></ul>
    </div>
    <div id="node-config-client-config-content" style="min-height:150px;">
        <div id="config-client-tab-Application" style="display:none">
                <label for="node-config-input-ASDUAddrLeng" style="width: auto;"><i class="fa fa-tag"></i> <span data-i18n="common.label.ASDUAddrLeng"></span>SADU Address Size</label>
                <input type="text" id="node-config-input-ASDUAddrLeng" style="width: 17%;">
                <label for="node-config-input-ASDUAddr" style="margin-left:30px; width: auto;"><i class="fa fa-tag"></i> <span data-i18n="common.label.ASDUAddr"></span>SADU Address</label>
                <input type="text" id="node-config-input-ASDUAddr" style="width: 17%;">
            </div>
                <label for="node-config-input-IOAaddrLeng" style="width: auto;"><i class="fa fa-tag"></i> <span data-i18n="common.label.IOAaddrLeng"></span>IOA Address Size</label>
                <input type="text" id="node-config-input-IOAaddrLeng" style="width: 17%;">
                <label for="node-config-input-COTaddrLeng" style="margin-left:30px; width: auto;"><i class="fa fa-tag"></i> <span data-i18n="common.label.COTaddrLeng"></span>COT Address Size</label>
                <input type="text" id="node-config-input-COTaddrLeng" style="width: 17%;">
            </div>
                <label for="node-config-input-OriginAddr" style="width: auto;"><i class="fa fa-tag"></i> <span data-i18n="common.label.OriginAddr"></span>Originator Address</label>
                <input type="text" id="node-config-input-OriginAddr" style="width: 17%;">
            </div>
        </div>
        <div id="config-client-tab-link" style="display:none"> </div>
        <div id="config-client-tab-options" style="display:none"> </div>
    </div>
</script>
<script type="text/html" data-help-name="ClientConfig">
    <p>A simple node that converts the message payloads into all Client characters</p>
</script>
