Hey. I am trying to run Node-Red on my raspberry pi 4 but I am getting error:
Flows stopped due to missing node types.
- serial-port
In the Node-Red terminal I have the following issue which I cannot solve and could use your help:
Welcome to Node-RED
20 Jan 21:32:52 - [info] Node-RED version: v1.0.6
20 Jan 21:32:52 - [info] Node.js version: v14.15.4
20 Jan 21:32:52 - [info] Linux 5.4.83-v7l+ arm LE
20 Jan 21:32:53 - [info] Loading palette nodes
20 Jan 21:32:58 - [warn] ------------------------------------------------------
20 Jan 21:32:58 - [warn] [node-red-node-serialport/serialport] Error: The module '/usr/lib/node_modules/node-red-node-serialport/node_modules/@serialport/bindings/build/Release/bindings.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 64. This version of Node.js requires
NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
the module (for instance, using npm rebuild or npm install).
