Node name or friendly name for notification
Hello.
These are my first steps with Node Red and Home Assistant. I have some battery-powered devices where I would like to send a notification when the battery runs low.
This has been my idea so far:
[{"id":"0ef04dc37c3d2c33","type":"tab","label":"Flow 3","disabled":false,"info":"","env":[]},{"id":"be534ff6981c7c7c","type":"api-call-service","z":"0ef04dc37c3d2c33","name":"Benachrichtigung R. Handy","server":"ea544f4f.d7486","version":4,"debugenabled":false,"domain":"notify","service":"mobile_app_rmx1993_roman","target":{"entityId":[],"areaId":[],"deviceId":[]},"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":840,"y":60,"wires":[[]]},{"id":"948391439ac32016","type":"server-state-changed","z":"0ef04dc37c3d2c33","name":"Wohnzimmer Fensterkontakt","server":"ea544f4f.d7486","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.wohnzimmer_fensterkontakt_hinten_battery","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":160,"y":40,"wires":[["dc4008089b6c239e"]]},{"id":"dc4008089b6c239e","type":"switch","z":"0ef04dc37c3d2c33","name":"Status bat_low","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"bat_low","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":420,"y":60,"wires":[["e44370e6cd475414"]]},{"id":"e44370e6cd475414","type":"function","z":"0ef04dc37c3d2c33","name":"Msg","func":"msg.payload = {\"data\":{\"message\":\"Batterie von\" + \" ist schwach! \",\"title\":\"Wichtige Nachricht von HomeAssistant!\",\"data\":{\"group\":\"Batterie\"}}};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":610,"y":60,"wires":[["be534ff6981c7c7c"]]},{"id":"4a41b1aaac511640","type":"server-state-changed","z":"0ef04dc37c3d2c33","name":"Küche Fensterkontakt","server":"ea544f4f.d7486","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.kueche_fensterkontakt_battery","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":140,"y":100,"wires":[["dc4008089b6c239e"]]},{"id":"ea544f4f.d7486","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":""}]
I hope this works the way I want it to. How do I get the name of the node or the friendly name in the function node? So that the name of the device is instead of the +.
function node:
msg.payload = {"data":{"message": "Batterie von" "+" " ist schwach! ","title":"Wichtige Nachricht von HomeAssistant!","data":{"group":"Batterie"}}};
Or does someone have a better idea to implement my project? I would be very grateful for help.
Thank you.
You can't get the name of an upstream node, the nodes are designed to be independent of each other.
What you should do is to get the device name from the incoming msg. I don't use HA so I don't know what data you get but there should be something in the incoming msgs that indicates the device name.
Ok thanks. I'll have to see how I can solve this.
Normally such nodes send a topic to identify the origin.
