Node-red and logical functions
hello, a problem with a function: :face_with_raised_eyebrow:
the goal: when the virtual switch "A" in lovelace is "true" and the motion detector is "true" I have the plug on "on" in other cases on "off" *
But nothing comes out of the function? :sob:
can you help me?
I attach my flow file
flows (5).json (6.9 KB)
You are comparing apples with oranges. "on" is not equal to true
thank you jbudd
I changed the "true" to "on" and it works.
but it does not give a command to the socket?
I think I should use a "change" but I don't see how.
:roll_eyes:
Why not just set msg.payload to true or false instead on 'on' or 'off'
What mqtt topic does the socket listen for?
What payload causes it to switch on or off?
My smart socket is flashed with Tasmota and the topic is defined as (for example) "bedroom/light"
To turn them on I set topic to "cmnd/bedroom/light" and payload to "on"
That's Tasmota, if yours have different firmware then the topic will probably be different.
like this?
it does not change anything the socket does not change state
it's an IKEA socket that works with my zigbee2mqtt usb key
Exposes
#Switch
The current state of this switch is in the published state under the state property (value is ON or OFF ). To control this switch publish a message to topic zigbee2mqtt/FRIENDLY_NAME/set with payload {"state": "ON"} , {"state": "OFF"} or {"state": "TOGGLE"} . To read the current state of this switch publish a message to topic zigbee2mqtt/FRIENDLY_NAME/get with payload {"state": ""} .
However, I can order it on lovelace.
I tried that but it doesn't work either.
an idea ?
it's not very pretty but it works well.
[{"id":"bf54e42bbb243fab","type":"tab","label":"Flow alarme test","disabled":false,"info":"","env":[]},{"id":"f02add9212c79299","type":"inject","z":"bf54e42bbb243fab","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"switch_on","payloadType":"str","x":100,"y":180,"wires":[["5e6cc9945dfb26d8"]]},{"id":"e575a5d3ac10195a","type":"inject","z":"bf54e42bbb243fab","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"switch_off","payloadType":"str","x":100,"y":220,"wires":[["5e6cc9945dfb26d8"]]},{"id":"b8013777e540be29","type":"inject","z":"bf54e42bbb243fab","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"pir_on","payloadType":"str","x":90,"y":320,"wires":[["4c464465cae112a5"]]},{"id":"a669b618d825ac6d","type":"inject","z":"bf54e42bbb243fab","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"pir_off","payloadType":"str","x":90,"y":360,"wires":[["4c464465cae112a5"]]},{"id":"276a7239eeac557a","type":"function","z":"bf54e42bbb243fab","name":"","func":"let sensors = msg.payload; //don't need to  write msg.payload to acces sensors\n\n//Door open and window not false, or garage 0\nif  (sensors.alarme === \"switch_on\" && sensors.pir_hall === \"pir_on\")\n     { return [msg, null]; }\n     \n   else {\n    return [null, msg]; //Send message to second output\n}\n","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":620,"y":280,"wires":[["3bf66e090680aed5"],["1e0a2a1a3bf29a86"]]},{"id":"5e6cc9945dfb26d8","type":"change","z":"bf54e42bbb243fab","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"alarme","tot":"str"},{"t":"set","p":"alarme","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":200,"wires":[["23b715a59369d6e5"]]},{"id":"4c464465cae112a5","type":"change","z":"bf54e42bbb243fab","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"pir_hall","tot":"str"},{"t":"set","p":"pir_hall","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":340,"wires":[["23b715a59369d6e5"]]},{"id":"23b715a59369d6e5","type":"join","z":"bf54e42bbb243fab","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":470,"y":280,"wires":[["276a7239eeac557a"]]},{"id":"c42d5047228c82a7","type":"debug","z":"bf54e42bbb243fab","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":550,"y":80,"wires":[]},{"id":"98508b4f7c1d2c68","type":"debug","z":"bf54e42bbb243fab","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":770,"y":440,"wires":[]},{"id":"c11ccd637234e10a","type":"inject","z":"bf54e42bbb243fab","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":640,"wires":[["701ce8e588a465bd"]]},{"id":"701ce8e588a465bd","type":"function","z":"bf54e42bbb243fab","name":"","func":"let sensors = {\n    door: global.get(\"door\"),\n    garage: global.get(\"garage\"),\n    window: global.get(\"window\")\n}\n\n//Door open and window not false, or garage 0\nif ( (sensors.door === \"close\" && !sensors.window) || sensors.garage === 0){\n    return [msg, null]; //Send message to first output\n}else if (sensors.garage === 1){\n    return [null, msg]; //Send message to second output\n}\n","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":640,"wires":[["723ffc4aa03623cd"],["efd81456e2377e5f"]]},{"id":"723ffc4aa03623cd","type":"debug","z":"bf54e42bbb243fab","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":570,"y":600,"wires":[]},{"id":"efd81456e2377e5f","type":"debug","z":"bf54e42bbb243fab","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":570,"y":680,"wires":[]},{"id":"21f33a4dd9d78bc4","type":"comment","z":"bf54e42bbb243fab","name":"Sensor check on external event","info":"","x":630,"y":640,"wires":[]},{"id":"3bf66e090680aed5","type":"change","z":"bf54e42bbb243fab","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":180,"wires":[["c42d5047228c82a7","543e61eb5a75e7d5"]]},{"id":"1e0a2a1a3bf29a86","type":"change","z":"bf54e42bbb243fab","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":360,"wires":[["98508b4f7c1d2c68","0f498f62b38e18fe"]]},{"id":"543e61eb5a75e7d5","type":"api-call-service","z":"bf54e42bbb243fab","name":"Prise ON","server":"d260f8f066987915","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.prise_1"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":760,"y":40,"wires":[[]]},{"id":"0f498f62b38e18fe","type":"api-call-service","z":"bf54e42bbb243fab","name":"Prise off","server":"d260f8f066987915","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":["hall"],"deviceId":[],"entityId":["switch.prise_1"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":800,"y":300,"wires":[[]]},{"id":"65bdaf8a00c82f91","type":"server-state-changed","z":"bf54e42bbb243fab","name":"presence Hall","server":"d260f8f066987915","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.pir_hall_occupancy","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":90,"y":100,"wires":[["5934e1a664547d86"]]},{"id":"b882e4912395ce85","type":"server-state-changed","z":"bf54e42bbb243fab","name":"alarme on/off","server":"d260f8f066987915","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.alarme","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":90,"y":480,"wires":[["d2f93990fa908a59"]]},{"id":"d2f93990fa908a59","type":"change","z":"bf54e42bbb243fab","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"pir_on","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"pir_off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":420,"wires":[["4c464465cae112a5"]]},{"id":"5934e1a664547d86","type":"change","z":"bf54e42bbb243fab","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"switch_on","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"switch_off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":120,"wires":[["5e6cc9945dfb26d8"]]},{"id":"d260f8f066987915","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"}]
