After checking the three global variables (global, flow, context), no continuous increase in data was found, and the reason is unknown. Thank you for your answer.
@xingzhe welcome to the forum.
You haven't provided enough information for anyone to even give a guess as to what your issue is.
Please provide some details
- what device are you running NR on?
- what version of node-red and node.js are you running? (see the startup log for this)
- how big is your flow and what are you doing in it?
- are you using dashboard graphs and if so how much data do you send to it and how often?
- are you using Docker and/or Home Assistant?
- how did you check the space used by the context variables?
- how much is the memory increase and over what amount of time?
- what is your flow doing?
Providing the answers to all these questions will give people a chance to help you.
[note: I'm moving this thread to the 'General' category.]
