Node-red command in linux shell doesn't work in script
I installed Node-RED on CenOS 7 web server.
Node-RED works fine, but I happen to reload the Apache server and then Node-RED.
I want to write a script to reload Apache and Node-RED :
# !/bin/bash
systemctl restart httpd
node-red&
PID=$!
sleep 5
kill $PID
disown -h
The problem is the Linux console warns the node-red command is unknown.
What am I doing wrong?
Thanks!
I use RaspberryPiOS not CenOS so this may not be available to you, but the NR installation script creates and enables a systemd script.
So I can restart Node-red with systemctl restart nodered
ps Does your #! /bin/bash line work with a space between the hash and the bang?
Thanks for your reply!
Apparently, the Node-RED restart works with this command, but with "node-red" instead of "nodered"!
#!/bin/bash        #Yes, there was a space in my last post, but it wasn't in my script!
systemctl restart node-red
PID=$!
sleep 2
kill $PID
disown -h
I have another problem by the way: in this script, I want to kill de $PID because I have to press CTRL+C after the Node-RED restart. The GNU/Linux console replies:
kill : man kill page
line 8 : disown : current : unknown task (not sure about the translation from French)
Any tip?
I had to look up the meaning of $! - it's the PID of the last background process created.
As far as I can see, your script doesn't create any background processes, though your original version with node-red& did.
This might explain the problem with disown -h too.
So I suggest you get rid of
PID=$!
sleep 2
kill $PID
disown -h
If after doing that you still "have to press CTRL+C after the Node-RED restart", there is something wrong with your systemd script.
Your installation is not standard. Did the "official" installation instructions for CentOS https://github.com/node-red/linux-installers not work for you?
Did you follow some online tutorial? Why and which one?
Thanks for you reply!
Thinking about the information you provided, I modified the script:
#!/bin/bash
I loaded the script and, apparently, it worked, with no error message.
Good news :grinning:
I still think you are storing up trouble for the future by not using the standard installation script.
