Node Red Connection Errors after safe start
I've been trying to troubleshoot this experience all day with my pi and node-red. I understand that the credential secret option is totally useless right now but I don't understand any of the other errors. Whenever I first start node-red this seems to go on forever after restarting until I start in safe mode. However, when I open up the node-red dashboard on my laptop it says everything is ok until I redeploy anything in which it says "you have lost connection" and this pops up on the pi:
pi@raspberrypi:~ $ node-red --safe
14 Mar 18:53:00 - [info]
Welcome to Node-RED
14 Mar 18:53:00 - [info] Node-RED version: v1.0.3
14 Mar 18:53:00 - [info] Node.js version: v10.15.2
14 Mar 18:53:00 - [info] Linux 4.19.50-v7l+ arm LE
14 Mar 18:53:02 - [info] Loading palette nodes
14 Mar 18:53:05 - [info] Dashboard version 2.17.1 started at /ui
14 Mar 18:53:06 - [warn] ------------------------------------------------------
14 Mar 18:53:06 - [warn] [node-red-contrib-easybotics-gphoto-upload/gphotos] Error: Cannot find module 'axios/lib/helpers/isAbsoluteURL'
14 Mar 18:53:06 - [warn] [node-red-contrib-easybotics-ina219-sensor/ina] Error: Cannot find module 'ina219' (line:1)
14 Mar 18:53:06 - [info] Settings file : /home/pi/.node-red/settings.js
14 Mar 18:53:06 - [info] Context store : 'default' [module=memory]
14 Mar 18:53:06 - [info] User directory : /home/pi/.node-red
14 Mar 18:53:06 - [warn] Projects disabled : editorTheme.projects.enabled=false
14 Mar 18:53:06 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
your credentials.
14 Mar 18:53:06 - [info] *****************************************************************
14 Mar 18:53:06 - [info] Flows stopped in safe mode. Deploy to start.
14 Mar 18:53:06 - [info] Server now running at http://127.0.0.1:1880/
14 Mar 18:53:29 - [warn]
your credentials.
14 Mar 18:53:29 - [info] Stopping flows
14 Mar 18:53:29 - [info] Stopped flows
14 Mar 18:53:29 - [info] Starting flows
14 Mar 18:53:29 - [info] Started flows
14 Mar 18:53:29 - [red] Uncaught Exception:
14 Mar 18:53:29 - Error: EREMOTEIO: remote I/O error, read
at Object.readSync (fs.js:494:3)
at Bus.i2cReadSync (/home/pi/.node-red/node_modules/i2c-bus/i2c-bus.js:334:13)
at Oled._readI2C (/home/pi/.node-red/node_modules/oled-i2c-bus/oled.js:170:15)
at tick (/home/pi/.node-red/node_modules/oled-i2c-bus/oled.js:182:10)
at Timeout._onTimeout (/home/pi/.node-red/node_modules/oled-i2c-bus/oled.js:194:27)
at ontimeout (timers.js:436:11)
at tryOnTimeout (timers.js:300:5)
at listOnTimeout (timers.js:263:5)
at Timer.processTimers (timers.js:223:10)
Do you have something connected to the GPIO pins and/or do you have that setup in your flows, it seems like that is the culprit:
Safe mode is a special mode for troubleshooting, the purpose is to disable/remove/update offending nodes, when done, you can deploy after which the flows will be started (hopefully without errors).
You are running an old version of node-red and an obsolete version of node.js. The latest in the 10.x series is 10.24 I think.
How did you install node-red? I suspect you did not use the recommended method for a pi. I suggest you run the script there which will bring you up to date. It may not help but at least you can then rule out that issue.
