Hi
i am having abit of an issue with the node-red-contrib-bool-gate.
no matter what i do, it always outputs null, even when the node displays the correct state.
need help would be appreciated.
this is my flows:
[{"id":"b9a636b7.ca0238","type":"tab","label":"Flow Varmestyrring ver 01","disabled":false,"info":""},{"id":"b6c07aeb.ea12c8","type":"persist in","z":"b9a636b7.ca0238","name":"data 1","storageNode":"6b1ad341.02faec","x":390,"y":40,"wires":[]},{"id":"c3c4eb1a.4284c8","type":"inject","z":"b9a636b7.ca0238","name":"","topic":"","payload":"","payloadType":"date","repeat":"5","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":520,"wires":[["d7605b87.fd25c8","a236c694.384c48","36b78317.f7160c","982c22f2.29fde","f55d728f.cd0f4"]]},{"id":"d7605b87.fd25c8","type":"persist out","z":"b9a636b7.ca0238","name":"data 1","storageNode":"6b1ad341.02faec","x":390,"y":520,"wires":[["7ed6a0ce.9c02e","12a567ad.597008"]]},{"id":"7ed6a0ce.9c02e","type":"ramp-thermostat","z":"b9a636b7.ca0238","name":"","profile":"83fb9945.db0278","hysteresisplus":"1","hysteresisminus":"1","x":680,"y":520,"wires":[["15a16ab6.170e85","5b168be2.6f2524","a2735a55.fd60a8"],["158ac80a.41e768","ccd59f1b.7e7d8"],["158ac80a.41e768"]]},{"id":"158ac80a.41e768","type":"ui_chart","z":"b9a636b7.ca0238","name":"","group":"d7ff2b1.e73ddd8","order":4,"width":0,"height":0,"label":"","chartType":"line","legend":"true","xformat":"dd HH:mm","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"7","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1110,"y":560,"wires":[[]]},{"id":"12a567ad.597008","type":"debug","z":"b9a636b7.ca0238","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":680,"y":460,"wires":[]},{"id":"b8725f6a.d8199","type":"ui_slider","z":"b9a636b7.ca0238","name":"","label":"Manual Setpunkt","tooltip":"","group":"d7ff2b1.e73ddd8","order":1,"width":0,"height":0,"passthru":true,"outs":"end","topic":"setTarget","min":0,"max":"40","step":1,"x":430,"y":460,"wires":[["7ed6a0ce.9c02e"]]},{"id":"ed8aba31.3fca08","type":"ui_led","z":"b9a636b7.ca0238","group":"d7ff2b1.e73ddd8","order":2,"width":0,"height":0,"label":"Ventil aktiv","labelPlacement":"right","labelAlignment":"right","colorForValue":[{"color":"green","value":"false","valueType":"bool"},{"color":"gray","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"","x":1110,"y":460,"wires":[]},{"id":"986a18c6.708298","type":"rpi-gpio out","z":"b9a636b7.ca0238","name":"","pin":"40","set":"","level":"0","freq":"","out":"out","x":1120,"y":500,"wires":[]},{"id":"8fa44fe7.0b4e7","type":"ui_slider","z":"b9a636b7.ca0238","name":"Master","label":"Master","tooltip":"","group":"523b25f9.3c231c","order":1,"width":15,"height":1,"passthru":true,"outs":"end","topic":"","min":0,"max":"40","step":1,"x":170,"y":460,"wires":[["b8725f6a.d8199","91e850a3.01cba","fe04fbee.5044f8","80e3bc37.48fb4","49b57d67.06a8a4"]]},{"id":"15a16ab6.170e85","type":"InvertUltimate","z":"b9a636b7.ca0238","name":"Invert","x":890,"y":500,"wires":[["986a18c6.708298","ed8aba31.3fca08"]]},{"id":"a236c694.384c48","type":"persist out","z":"b9a636b7.ca0238","name":"data 2","storageNode":"bee7a4d8.f76928","x":390,"y":760,"wires":[["854d0c8e.55ec6","20e22c8c.b8cc34"]]},{"id":"854d0c8e.55ec6","type":"ramp-thermostat","z":"b9a636b7.ca0238","name":"","profile":"83fb9945.db0278","hysteresisplus":"1","hysteresisminus":"1","x":680,"y":760,"wires":[["ed140786.eb5f58","8fe4db05.b6de38"],["e043c58e.8ff448","30daea68.e07656"],["e043c58e.8ff448"]]},{"id":"e043c58e.8ff448","type":"ui_chart","z":"b9a636b7.ca0238","name":"","group":"54eb4a6.ab426b4","order":4,"width":0,"height":0,"label":"","chartType":"line","legend":"true","xformat":"dd HH:mm","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"7","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1110,"y":800,"wires":[[]]},{"id":"20e22c8c.b8cc34","type":"debug","z":"b9a636b7.ca0238","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":680,"y":700,"wires":[]},{"id":"91e850a3.01cba","type":"ui_slider","z":"b9a636b7.ca0238","name":"","label":"Manual Setpunkt","tooltip":"","group":"54eb4a6.ab426b4","order":1,"width":0,"height":0,"passthru":true,"outs":"end","topic":"setTarget","min":0,"max":"40","step":1,"x":430,"y":700,"wires":[["854d0c8e.55ec6"]]},{"id":"9f17425c.9bb66","type":"ui_led","z":"b9a636b7.ca0238","group":"54eb4a6.ab426b4","order":2,"width":0,"height":0,"label":"Ventil aktiv","labelPlacement":"right","labelAlignment":"right","colorForValue":[{"color":"green","value":"false","valueType":"bool"},{"color":"gray","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"","x":1110,"y":700,"wires":[]},{"id":"b16f6b7f.6f8e48","type":"rpi-gpio out","z":"b9a636b7.ca0238","name":"","pin":"38","set":"","level":"0","freq":"","out":"out","x":1120,"y":740,"wires":[]},{"id":"ed140786.eb5f58","type":"InvertUltimate","z":"b9a636b7.ca0238","name":"Invert","x":890,"y":740,"wires":[["b16f6b7f.6f8e48","9f17425c.9bb66"]]},{"id":"36b78317.f7160c","type":"persist out","z":"b9a636b7.ca0238","name":"data 3","storageNode":"4504d922.ae83f8","x":390,"y":1020,"wires":[["94e1f6e7.571928","e84f653b.9bdfd8"]]},{"id":"94e1f6e7.571928","type":"ramp-thermostat","z":"b9a636b7.ca0238","name":"","profile":"83fb9945.db0278","hysteresisplus":"1","hysteresisminus":"1","x":680,"y":1020,"wires":[["3d700897.388958","a83a71ff.e58b1"],["e16cbe86.93c83","5a4982db.6ca77c"],["e16cbe86.93c83"]]},{"id":"e16cbe86.93c83","type":"ui_chart","z":"b9a636b7.ca0238","name":"","group":"adede9ff.790528","order":4,"width":0,"height":0,"label":"","chartType":"line","legend":"true","xformat":"dd HH:mm","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"7","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1110,"y":1060,"wires":[[]]},{"id":"e84f653b.9bdfd8","type":"debug","z":"b9a636b7.ca0238","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":680,"y":960,"wires":[]},{"id":"fe04fbee.5044f8","type":"ui_slider","z":"b9a636b7.ca0238","name":"","label":"Manual Setpunkt","tooltip":"","group":"adede9ff.790528","order":1,"width":0,"height":0,"passthru":true,"outs":"end","topic":"setTarget","min":0,"max":"40","step":1,"x":430,"y":960,"wires":[["94e1f6e7.571928"]]},{"id":"11858a10.8ab9f6","type":"ui_led","z":"b9a636b7.ca0238","group":"adede9ff.790528","order":2,"width":0,"height":0,"label":"Ventil aktiv","labelPlacement":"right","labelAlignment":"right","colorForValue":[{"color":"green","value":"false","valueType":"bool"},{"color":"gray","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"","x":1110,"y":960,"wires":[]},{"id":"67cf4511.34b71c","type":"rpi-gpio out","z":"b9a636b7.ca0238","name":"","pin":"36","set":"","level":"0","freq":"","out":"out","x":1120,"y":1000,"wires":[]},{"id":"3d700897.388958","type":"InvertUltimate","z":"b9a636b7.ca0238","name":"Invert","x":890,"y":1000,"wires":[["67cf4511.34b71c","11858a10.8ab9f6"]]},{"id":"982c22f2.29fde","type":"persist out","z":"b9a636b7.ca0238","name":"data 4","storageNode":"f7aae969.7b2998","x":390,"y":1260,"wires":[["5b832651.5ccbc8","b7367580.50d0b8"]]},{"id":"5b832651.5ccbc8","type":"ramp-thermostat","z":"b9a636b7.ca0238","name":"","profile":"83fb9945.db0278","hysteresisplus":"1","hysteresisminus":"1","x":680,"y":1260,"wires":[["3a336632.c86b8a","ba21a8d7.118f98"],["2cb16bdf.0f6c04","c341c53e.2d8348"],["2cb16bdf.0f6c04"]]},{"id":"2cb16bdf.0f6c04","type":"ui_chart","z":"b9a636b7.ca0238","name":"","group":"37acbef5.938792","order":4,"width":0,"height":0,"label":"","chartType":"line","legend":"true","xformat":"dd HH:mm","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"7","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1110,"y":1300,"wires":[[]]},{"id":"b7367580.50d0b8","type":"debug","z":"b9a636b7.ca0238","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":680,"y":1200,"wires":[]},{"id":"80e3bc37.48fb4","type":"ui_slider","z":"b9a636b7.ca0238","name":"","label":"Manual Setpunkt","tooltip":"","group":"37acbef5.938792","order":1,"width":0,"height":0,"passthru":true,"outs":"end","topic":"setTarget","min":0,"max":"40","step":1,"x":430,"y":1200,"wires":[["5b832651.5ccbc8"]]},{"id":"494d7fe6.cf7f4","type":"ui_led","z":"b9a636b7.ca0238","group":"37acbef5.938792","order":2,"width":0,"height":0,"label":"Ventil aktiv","labelPlacement":"right","labelAlignment":"right","colorForValue":[{"color":"green","value":"false","valueType":"bool"},{"color":"gray","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"","x":1110,"y":1200,"wires":[]},{"id":"6a7f472f.80a6f8","type":"rpi-gpio out","z":"b9a636b7.ca0238","name":"","pin":"32","set":"","level":"0","freq":"","out":"out","x":1120,"y":1240,"wires":[]},{"id":"3a336632.c86b8a","type":"InvertUltimate","z":"b9a636b7.ca0238","name":"Invert","x":890,"y":1240,"wires":[["6a7f472f.80a6f8","494d7fe6.cf7f4"]]},{"id":"f55d728f.cd0f4","type":"persist out","z":"b9a636b7.ca0238","name":"data 5","storageNode":"d6fe1fbd.3a0a8","x":390,"y":1500,"wires":[["c16ba82.59f8258","64df17ed.b2da38"]]},{"id":"c16ba82.59f8258","type":"ramp-thermostat","z":"b9a636b7.ca0238","name":"","profile":"83fb9945.db0278","hysteresisplus":"1","hysteresisminus":"1","x":680,"y":1500,"wires":[["b13e2b38.f76ff8","b7e79a9f.2179b8","f83b5b80.06a1e8"],["9e4238ce.74d688","260c81ff.e79d7e"],["9e4238ce.74d688"]]},{"id":"9e4238ce.74d688","type":"ui_chart","z":"b9a636b7.ca0238","name":"","group":"9313779c.c6c878","order":4,"width":6,"height":4,"label":"","chartType":"line","legend":"true","xformat":"dd HH:mm","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"7","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1110,"y":1540,"wires":[[]]},{"id":"64df17ed.b2da38","type":"debug","z":"b9a636b7.ca0238","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":680,"y":1440,"wires":[]},{"id":"49b57d67.06a8a4","type":"ui_slider","z":"b9a636b7.ca0238","name":"","label":"Manual Setpunkt","tooltip":"","group":"9313779c.c6c878","order":1,"width":6,"height":1,"passthru":true,"outs":"end","topic":"setTarget","min":0,"max":"40","step":1,"x":430,"y":1440,"wires":[["c16ba82.59f8258"]]},{"id":"b13e2b38.f76ff8","type":"ui_led","z":"b9a636b7.ca0238","group":"9313779c.c6c878","order":2,"width":6,"height":1,"label":"Ventil aktiv","labelPlacement":"right","labelAlignment":"right","colorForValue":[{"color":"green","value":"true","valueType":"bool"},{"color":"gray","value":"false","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"","x":1110,"y":1440,"wires":[]},{"id":"b7e79a9f.2179b8","type":"rpi-gpio out","z":"b9a636b7.ca0238","name":"","pin":"31","set":"","level":"0","freq":"","out":"out","x":1120,"y":1480,"wires":[]},{"id":"8c05bd41.f0c67","type":"persist in","z":"b9a636b7.ca0238","name":"data 2","storageNode":"bee7a4d8.f76928","x":390,"y":100,"wires":[]},{"id":"3619d6c5.fc073a","type":"persist in","z":"b9a636b7.ca0238","name":"data 3","storageNode":"4504d922.ae83f8","x":390,"y":160,"wires":[]},{"id":"db06ea6b.592e38","type":"persist in","z":"b9a636b7.ca0238","name":"data 4","storageNode":"f7aae969.7b2998","x":390,"y":220,"wires":[]},{"id":"a3b3989d.b5f178","type":"persist in","z":"b9a636b7.ca0238","name":"data 5","storageNode":"d6fe1fbd.3a0a8","x":390,"y":280,"wires":[]},{"id":"ccd59f1b.7e7d8","type":"ui_gauge","z":"b9a636b7.ca0238","name":"","group":"d7ff2b1.e73ddd8","order":3,"width":0,"height":0,"gtype":"gage","title":"Aktuelle Temperatur","label":"C","format":"{{value}}","min":0,"max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1160,"y":600,"wires":[]},{"id":"30daea68.e07656","type":"ui_gauge","z":"b9a636b7.ca0238","name":"","group":"54eb4a6.ab426b4","order":3,"width":0,"height":0,"gtype":"gage","title":"Aktuelle Temperatur","label":"C","format":"{{value}}","min":0,"max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1160,"y":840,"wires":[]},{"id":"5a4982db.6ca77c","type":"ui_gauge","z":"b9a636b7.ca0238","name":"","group":"adede9ff.790528","order":3,"width":0,"height":0,"gtype":"gage","title":"Aktuelle Temperatur","label":"C","format":"{{value}}","min":0,"max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1160,"y":1100,"wires":[]},{"id":"c341c53e.2d8348","type":"ui_gauge","z":"b9a636b7.ca0238","name":"","group":"37acbef5.938792","order":3,"width":0,"height":0,"gtype":"gage","title":"Aktuelle Temperatur","label":"C","format":"{{value}}","min":0,"max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1160,"y":1340,"wires":[]},{"id":"260c81ff.e79d7e","type":"ui_gauge","z":"b9a636b7.ca0238","name":"","group":"9313779c.c6c878","order":3,"width":0,"height":0,"gtype":"gage","title":"Aktuelle Temperatur","label":"C","format":"{{value}}","min":0,"max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1160,"y":1580,"wires":[]},{"id":"d72474c4.418678","type":"sensor-ds18b20","z":"b9a636b7.ca0238","name":"","topic":"","sensorid":"28-03139779337e","timer":"21","repeat":true,"x":170,"y":100,"wires":[["8c05bd41.f0c67"]]},{"id":"d1666157.1e1cd","type":"sensor-ds18b20","z":"b9a636b7.ca0238","name":"","topic":"","sensorid":"28-0416935cceff","timer":"22","repeat":true,"x":170,"y":160,"wires":[["3619d6c5.fc073a"]]},{"id":"db6f413.15ba0c","type":"sensor-ds18b20","z":"b9a636b7.ca0238","name":"","topic":"","sensorid":"28-03139779aebd","timer":"23","repeat":true,"x":170,"y":220,"wires":[["db06ea6b.592e38"]]},{"id":"3f2c8bcf.774bf4","type":"sensor-ds18b20","z":"b9a636b7.ca0238","name":"","topic":"","sensorid":"28-031455b707ff","timer":"24","repeat":true,"x":170,"y":280,"wires":[["a3b3989d.b5f178"]]},{"id":"6ff7d4bb.6b6c6c","type":"sensor-ds18b20","z":"b9a636b7.ca0238","name":"","topic":"","sensorid":"28-03139779aff4","timer":"20","repeat":true,"x":170,"y":40,"wires":[["b6c07aeb.ea12c8"]]},{"id":"5b168be2.6f2524","type":"debug","z":"b9a636b7.ca0238","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1090,"y":380,"wires":[]},{"id":"a2735a55.fd60a8","type":"change","z":"b9a636b7.ca0238","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"valve 1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1130,"y":640,"wires":[["5774e97f.ecc308","2f66d751.c741f8"]]},{"id":"8fe4db05.b6de38","type":"change","z":"b9a636b7.ca0238","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"valve 2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1130,"y":880,"wires":[["69f88116.87d1f","2f66d751.c741f8"]]},{"id":"5774e97f.ecc308","type":"debug","z":"b9a636b7.ca0238","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":1770,"y":640,"wires":[]},{"id":"69f88116.87d1f","type":"debug","z":"b9a636b7.ca0238","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":1770,"y":880,"wires":[]},{"id":"ba21a8d7.118f98","type":"change","z":"b9a636b7.ca0238","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"valve 4","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1130,"y":1380,"wires":[["c8d785b4.634858"]]},{"id":"a83a71ff.e58b1","type":"change","z":"b9a636b7.ca0238","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"valve 3","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1130,"y":1140,"wires":[["37495616.7f6b1a"]]},{"id":"f83b5b80.06a1e8","type":"change","z":"b9a636b7.ca0238","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"valve 5","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1130,"y":1620,"wires":[["408dc35c.653ccc"]]},{"id":"37495616.7f6b1a","type":"debug","z":"b9a636b7.ca0238","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":1770,"y":1140,"wires":[]},{"id":"c8d785b4.634858","type":"debug","z":"b9a636b7.ca0238","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":1770,"y":1380,"wires":[]},{"id":"408dc35c.653ccc","type":"debug","z":"b9a636b7.ca0238","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":1770,"y":1620,"wires":[]},{"id":"296f0757.c5bd08","type":"rpi-gpio out","z":"b9a636b7.ca0238","name":"Pumpe","pin":"35","set":"","level":"0","freq":"","out":"out","x":2240,"y":880,"wires":[]},{"id":"8e32b59f.2f7308","type":"debug","z":"b9a636b7.ca0238","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":2040,"y":620,"wires":[]},{"id":"d1ace99d.10d878","type":"inject","z":"b9a636b7.ca0238","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":1990,"y":900,"wires":[["296f0757.c5bd08"]]},{"id":"a26daea7.be4e3","type":"inject","z":"b9a636b7.ca0238","name":"","topic":"","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":1990,"y":940,"wires":[["296f0757.c5bd08"]]},{"id":"2f66d751.c741f8","type":"or-gate","z":"b9a636b7.ca0238","name":"pumpe gate","rules":[{"t":"true","propertyType":"msg","property":"payload","topic":"valve 1"},{"t":"true","propertyType":"msg","property":"payload","topic":"valve 2"}],"outputTopic":"c pumpe","gateType":"or","emitOnlyIfTrue":false,"x":1990,"y":740,"wires":[["8e32b59f.2f7308"]]},{"id":"6b1ad341.02faec","type":"persist-store","z":"","filename":"persistanceS1.json","interval":"60"},{"id":"83fb9945.db0278","type":"profile","z":"","name":"22 grader","time1":"00:00","temp1":"22","time2":"23:59","temp2":"22","time3":"","temp3":"","time4":"","temp4":"","time5":"","temp5":"","time6":"","temp6":"","time7":"","temp7":"","time8":"","temp8":"","time9":"","temp9":"","time10":"","temp10":""},{"id":"d7ff2b1.e73ddd8","type":"ui_group","z":"","name":"Badeværelse","tab":"91b71e3e.d4adf","order":1,"disp":true,"width":"6","collapse":false},{"id":"523b25f9.3c231c","type":"ui_group","z":"","name":"Master","tab":"91b71e3e.d4adf","order":6,"disp":true,"width":15,"collapse":false},{"id":"bee7a4d8.f76928","type":"persist-store","z":"","filename":"persistanceS2.json","interval":"60"},{"id":"54eb4a6.ab426b4","type":"ui_group","z":"","name":"Gangen","tab":"91b71e3e.d4adf","order":2,"disp":true,"width":"6","collapse":false},{"id":"4504d922.ae83f8","type":"persist-store","z":"","filename":"persistanceS3.json","interval":"60"},{"id":"adede9ff.790528","type":"ui_group","z":"","name":"Køkken","tab":"91b71e3e.d4adf","order":3,"disp":true,"width":"6","collapse":false},{"id":"f7aae969.7b2998","type":"persist-store","z":"","filename":"persistanceS4.json","interval":"60"},{"id":"37acbef5.938792","type":"ui_group","z":"","name":"Spisestue","tab":"91b71e3e.d4adf","order":4,"disp":true,"width":"6","collapse":false},{"id":"d6fe1fbd.3a0a8","type":"persist-store","z":"","filename":"persistanceS5.json","interval":"60"},{"id":"9313779c.c6c878","type":"ui_group","z":"","name":"Tv Stue","tab":"91b71e3e.d4adf","order":5,"disp":true,"width":"6","collapse":false},{"id":"91b71e3e.d4adf","type":"ui_tab","z":"","name":"Gulvvarme","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
