Node-red-contrib-buffer-parser issue
I am trying to get this new node working on data coming from a bluetooth pressure sensor. I cant seem to get at the nested data correctly.
Here is the data for the first value.
3/18/2021, 10:29:25 AMnode: 3880141e.2cbf04
msg : Object
object
payload: object
uuid: "0081f9974020"
characteristics: object
2a07: buffer[1]
0: 0xa
_msgid: "5c78a7a7.e92c18"
Here is the testing flow.
[{"id":"c0d5dea4.880a9","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"ea7a7199.23adb","type":"inject","z":"c0d5dea4.880a9","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"835ab4c051e411e3a5bd0002a5d5c51b","payloadType":"str","x":300,"y":360,"wires":[["6c40fa5c.0c67c4"]]},{"id":"ad0b93de.c385f","type":"inject","z":"c0d5dea4.880a9","name":"Connect","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"connect","payloadType":"str","x":400,"y":440,"wires":[["6c40fa5c.0c67c4"]]},{"id":"a65a7d65.34f43","type":"inject","z":"c0d5dea4.880a9","name":"Disconnect","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"disconnect","x":400,"y":480,"wires":[["6c40fa5c.0c67c4"]]},{"id":"3880141e.2cbf04","type":"debug","z":"c0d5dea4.880a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1230,"y":140,"wires":[]},{"id":"33480316.ff149c","type":"inject","z":"c0d5dea4.880a9","name":"Subscribe","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"notify\":true,\"period\":0}","payloadType":"json","x":400,"y":520,"wires":[["6c40fa5c.0c67c4"]]},{"id":"6c40fa5c.0c67c4","type":"Generic BLE in","z":"c0d5dea4.880a9","name":"91087","genericBle":"9078f63b.0dc458","useString":false,"notification":true,"x":910,"y":140,"wires":[["dd81fdd0.ff58e8","3880141e.2cbf04"]]},{"id":"97906e53.8d662","type":"inject","z":"c0d5dea4.880a9","name":"Temperature Measurement","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a1c","payloadType":"str","x":350,"y":320,"wires":[["6c40fa5c.0c67c4"]]},{"id":"8b4f2471.4be59","type":"inject","z":"c0d5dea4.880a9","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"8cd67da0da9b11e390870002a5d5c51b","x":300,"y":400,"wires":[["6c40fa5c.0c67c4"]]},{"id":"9ba2bc2d.00f108","type":"inject","z":"c0d5dea4.880a9","name":"Measurement Interval","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a21","payloadType":"str","x":360,"y":280,"wires":[["6c40fa5c.0c67c4"]]},{"id":"f83805b4.357a28","type":"inject","z":"c0d5dea4.880a9","name":"Model Number String","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a24","payloadType":"str","x":360,"y":200,"wires":[["6c40fa5c.0c67c4"]]},{"id":"388476a2.477302","type":"inject","z":"c0d5dea4.880a9","name":"<Unnamed>","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2aff","payloadType":"str","x":390,"y":240,"wires":[["6c40fa5c.0c67c4"]]},{"id":"d6d0ad88.2c0918","type":"inject","z":"c0d5dea4.880a9","name":"Serial Number String","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a25","payloadType":"str","x":370,"y":160,"wires":[["6c40fa5c.0c67c4"]]},{"id":"501297f9.7c5b9","type":"inject","z":"c0d5dea4.880a9","name":"Tx Power Level","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a07","x":380,"y":40,"wires":[["6c40fa5c.0c67c4"]]},{"id":"bc0b41.65bcbcc","type":"inject","z":"c0d5dea4.880a9","name":"Firmware Revision String","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a26","payloadType":"str","x":350,"y":120,"wires":[["6c40fa5c.0c67c4"]]},{"id":"b3e31ee5.6fbaa8","type":"inject","z":"c0d5dea4.880a9","name":"Manufacturer Name String","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a29","payloadType":"str","x":350,"y":80,"wires":[["6c40fa5c.0c67c4"]]},{"id":"dd81fdd0.ff58e8","type":"buffer-parser","z":"c0d5dea4.880a9","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int8","name":"2a07","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"string","name":"Manufacturer Name","offset":0,"length":22,"offsetbit":0,"scale":"1","mask":""},{"type":"string","name":"Firmware Revision","offset":0,"length":7,"offsetbit":0,"scale":"1","mask":""},{"type":"string","name":"Serial Number","offset":0,"length":5,"offsetbit":0,"scale":"1","mask":""},{"type":"string","name":"Model Number","offset":0,"length":20,"offsetbit":0,"scale":"1","mask":""},{"type":"string","name":"<Unnamed>","offset":0,"length":12,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"Measurement Interval","offset":0,"length":2,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"Temperature Measurement","offset":0,"length":5,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"item9","offset":0,"length":5,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"item10","offset":0,"length":5,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"object","resultTypeType":"output","multipleResult":true,"fanOutMultipleResult":true,"setTopic":true,"outputs":10,"x":1070,"y":320,"wires":[["3880141e.2cbf04"],[],[],[],[],[],[],[],[],[]]},{"id":"9078f63b.0dc458","type":"Generic BLE","localName":"91087              ","address":"00:81:f9:97:40:20","uuid":"0081f9974020","characteristics":[{"uuid":"2a07","name":"Tx Power Level","type":"org.bluetooth.characteristic.tx_power_level","notifiable":false,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"2a29","name":"Manufacturer Name String","type":"org.bluetooth.characteristic.manufacturer_name_string","notifiable":false,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"2a26","name":"Firmware Revision String","type":"org.bluetooth.characteristic.firmware_revision_string","notifiable":false,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"2a25","name":"Serial Number String","type":"org.bluetooth.characteristic.serial_number_string","notifiable":false,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"2a24","name":"Model Number String","type":"org.bluetooth.characteristic.model_number_string","notifiable":false,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"2aff","name":"<Unnamed>","type":"(Custom Type)","notifiable":false,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"2a21","name":"Measurement Interval","type":"org.bluetooth.characteristic.measurement_interval","notifiable":false,"readable":true,"writable":true,"writeWithoutResponse":false},{"uuid":"2a1c","name":"Temperature Measurement","type":"org.bluetooth.characteristic.temperature_measurement","notifiable":true,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"8cd67da0da9b11e390870002a5d5c51b","name":"<Unnamed>","type":"(Custom Type)","notifiable":false,"readable":true,"writable":true,"writeWithoutResponse":false},{"uuid":"835ab4c051e411e3a5bd0002a5d5c51b","name":"<Unnamed>","type":"(Custom Type)","notifiable":true,"readable":true,"writable":false,"writeWithoutResponse":false}]}]
I stringified the bluetooth output to this, and still cant seem to get it retrieved.
3/18/2021, 11:05:15 AMnode: 3880141e.2cbf04
msg : Object
object
payload: "{"uuid":"0081f9974020","characteristics":{"2a29":{"type":"Buffer","data":[84,114,97,110,115,100,117,99,101,114,115,32,68,105,114,101,99,116,32,76,76,67]}}}"
_msgid: "6f68c25.88fb13c"
I should mention that the payload has 2 items of interest.
  1. Characteristics key
  2. Data
The sensor returns all of the following.
Tx Power Level (2a07)Read
Manufacturer Name String (2a29)Read
Firmware Revision String (2a26)Read
Serial Number String (2a25)Read
Model Number String (2a24)Read
<Unnamed> (2aff)Read
(Custom Type)
Measurement Interval (2a21)ReadWrite
Temperature Measurement (2a1c)ReadNotify
<Unnamed> (8cd67da0da9b11e390870002a5d5c51b)ReadWrite
(Custom Type)
<Unnamed> (835ab4c051e411e3a5bd0002a5d5c51b)ReadNotify
(Custom Type)
Hi, when you capture a debug output - please do the following...
  1. Press the "Copy Value" button that appears under your mouse pointer when you hover over the message in the debug sidebar (it copies it correctly - what you pasted is pretty much unusable)
  2. Be sure to paste it as a code block (surrounded by 3 backticks on new lines)
OK, so by the looks of it, your buffer from the BLE node is in msg.payload["2a29"].characteristics but you have the input property of the buffer parser set to read msg.payload - hence the error.
So, I have put together a demo using the buffer values I found in your post [84,114,97,110,115,100,117,99,101,114,115,32,68,105,114,101,99,116,32,76,76,67] and connected that to the buffer parser (to fake your BLE node (I dont have BLE or your device so I have to fabricate the data))
This is the result ...
^ note how all values are essentially starting from the 1st byte? ...
This is because yo havent set any offsets...
any how, here is the demo flow...
[{"id":"3880141e.2cbf04","type":"debug","z":"c0d5dea4.880a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1478,"y":144,"wires":[]},{"id":"dd81fdd0.ff58e8","type":"buffer-parser","z":"c0d5dea4.880a9","name":"","data":"payload[\"2a07\"].characteristics","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int8","name":"2a07","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"string","name":"Manufacturer Name","offset":0,"length":22,"offsetbit":0,"scale":"1","mask":""},{"type":"string","name":"Firmware Revision","offset":0,"length":7,"offsetbit":0,"scale":"1","mask":""},{"type":"string","name":"Serial Number","offset":0,"length":5,"offsetbit":0,"scale":"1","mask":""},{"type":"string","name":"Model Number","offset":0,"length":20,"offsetbit":0,"scale":"1","mask":""},{"type":"string","name":"<Unnamed>","offset":0,"length":12,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"Measurement Interval","offset":0,"length":2,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"Temperature Measurement","offset":0,"length":5,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"item9","offset":0,"length":5,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"item10","offset":0,"length":5,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"output","multipleResult":true,"fanOutMultipleResult":true,"setTopic":true,"outputs":10,"x":1238,"y":352,"wires":[["3880141e.2cbf04"],["bdad8685.3637e8"],["3c6d5ff3.29ade"],["605ab10.845f75"],["fc4ca81f.1989f8"],["aea4a54e.a88bb8"],["6dc8407e.d300a"],["dffd79e.18a6288"],["2510148b.2a56cc"],["d4a42ff8.c34cf"]]},{"id":"b9a795bb.efaa78","type":"function","z":"c0d5dea4.880a9","name":"","func":"msg.payload = {};\nmsg.payload[\"2a07\"] = {\n    characteristics: Buffer.from([84,114,97,110,115,100,117,99,101,114,115,32,68,105,114,101,99,116,32,76,76,67])\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1036,"y":256,"wires":[["dd81fdd0.ff58e8"]]},{"id":"adf48181.de88b","type":"inject","z":"c0d5dea4.880a9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1036,"y":208,"wires":[["b9a795bb.efaa78"]]},{"id":"bdad8685.3637e8","type":"debug","z":"c0d5dea4.880a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1478,"y":192,"wires":[]},{"id":"3c6d5ff3.29ade","type":"debug","z":"c0d5dea4.880a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1478,"y":240,"wires":[]},{"id":"605ab10.845f75","type":"debug","z":"c0d5dea4.880a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1478,"y":288,"wires":[]},{"id":"fc4ca81f.1989f8","type":"debug","z":"c0d5dea4.880a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1478,"y":336,"wires":[]},{"id":"aea4a54e.a88bb8","type":"debug","z":"c0d5dea4.880a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1478,"y":384,"wires":[]},{"id":"6dc8407e.d300a","type":"debug","z":"c0d5dea4.880a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1478,"y":432,"wires":[]},{"id":"dffd79e.18a6288","type":"debug","z":"c0d5dea4.880a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1478,"y":480,"wires":[]},{"id":"2510148b.2a56cc","type":"debug","z":"c0d5dea4.880a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1478,"y":528,"wires":[]},{"id":"d4a42ff8.c34cf","type":"debug","z":"c0d5dea4.880a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1478,"y":576,"wires":[]}]
PS Please read the built in help...
And try the built in demos
I stepped back and can't seem to get the data to represent the temperature.
Here is the payload and the configuration. The vendor says its a 32 Float BE value and I keep getting the error.
RangeError: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 4
This is the message passed into it.
3/18/2021, 9:41:23 PMnode: 3880141e.2cbf04
Temperature : msg : Object
object
topic: "Temperature"
payload: buffer[4]
0: 0x41
1: 0xcb
2: 0x30
3: 0x0
_msgid: "e79e3aec.168318"
As I said before...
e.g...
You did neither of these :frowning: that makes it is very difficult for me to help you as I cant easily copy what you pasted!
Onto your issue...
... your input data is only 4 bytes long & you are trying to read 3 floats from it.
More, so, that data [0x41,0xcb,0x30,0x0] looks suspiciously like a string.
[{"id":"6530f850.c3f6c8","type":"inject","z":"c0d5dea4.880a9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1452,"y":736,"wires":[["66510ff4.8f654"]]},{"id":"66510ff4.8f654","type":"function","z":"c0d5dea4.880a9","name":"","func":"msg.payload = Buffer.from([0x41,0xcb,0x30,0])\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1452,"y":784,"wires":[["cb979d92.213f9"]]},{"id":"cb979d92.213f9","type":"buffer-parser","z":"c0d5dea4.880a9","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"string","name":"item1","offset":0,"length":3,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":true,"setTopic":true,"outputs":1,"x":1478,"y":832,"wires":[["767ab56.3b7814c"]]},{"id":"767ab56.3b7814c","type":"debug","z":"c0d5dea4.880a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1510,"y":880,"wires":[]}]
I got it working, but had to drop the buffer parser except in one condition.
Here is a good Bluetooth Flow. It works with the Transducers Direct TDWLB-LC0100034 Pressure Transducer.
Thanks all
[{"id":"c0d5dea4.880a9","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"ea7a7199.23adb","type":"inject","z":"c0d5dea4.880a9","name":"UUID2","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"835ab4c051e411e3a5bd0002a5d5c51b","payloadType":"str","x":230,"y":400,"wires":[["6c40fa5c.0c67c4"]]},{"id":"ad0b93de.c385f","type":"inject","z":"c0d5dea4.880a9","name":"Connect","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"connect","payloadType":"str","x":220,"y":620,"wires":[["6c40fa5c.0c67c4"]]},{"id":"a65a7d65.34f43","type":"inject","z":"c0d5dea4.880a9","name":"Disconnect","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"disconnect","x":220,"y":660,"wires":[["6c40fa5c.0c67c4"]]},{"id":"3880141e.2cbf04","type":"debug","z":"c0d5dea4.880a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1350,"y":140,"wires":[]},{"id":"33480316.ff149c","type":"inject","z":"c0d5dea4.880a9","name":"Subscribe","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"notify\":true,\"period\":300000}","payloadType":"json","x":220,"y":700,"wires":[["6c40fa5c.0c67c4"]]},{"id":"6c40fa5c.0c67c4","type":"Generic BLE in","z":"c0d5dea4.880a9","name":"91087","genericBle":"9078f63b.0dc458","useString":false,"notification":true,"x":450,"y":140,"wires":[["acca877e.c6a21"]]},{"id":"97906e53.8d662","type":"inject","z":"c0d5dea4.880a9","name":"Temperature","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a1c","x":210,"y":360,"wires":[["6c40fa5c.0c67c4"]]},{"id":"8b4f2471.4be59","type":"inject","z":"c0d5dea4.880a9","name":"UUID4","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"8cd67da0da9b11e390870002a5d5c51b","payloadType":"str","x":230,"y":440,"wires":[["6c40fa5c.0c67c4"]]},{"id":"9ba2bc2d.00f108","type":"inject","z":"c0d5dea4.880a9","name":"Measurement Interval","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a21","x":180,"y":320,"wires":[["6c40fa5c.0c67c4"]]},{"id":"f83805b4.357a28","type":"inject","z":"c0d5dea4.880a9","name":"Model Number","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a24","payloadType":"str","x":200,"y":240,"wires":[["6c40fa5c.0c67c4"]]},{"id":"388476a2.477302","type":"inject","z":"c0d5dea4.880a9","name":"Advertising Blob","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2aff","x":200,"y":280,"wires":[["6c40fa5c.0c67c4"]]},{"id":"d6d0ad88.2c0918","type":"inject","z":"c0d5dea4.880a9","name":"Serial Number","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a25","x":210,"y":200,"wires":[["6c40fa5c.0c67c4"]]},{"id":"501297f9.7c5b9","type":"inject","z":"c0d5dea4.880a9","name":"Tx Power Level","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a07","payloadType":"str","x":200,"y":80,"wires":[["6c40fa5c.0c67c4"]]},{"id":"bc0b41.65bcbcc","type":"inject","z":"c0d5dea4.880a9","name":"Firmware Revision","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a26","x":190,"y":160,"wires":[["6c40fa5c.0c67c4"]]},{"id":"b3e31ee5.6fbaa8","type":"inject","z":"c0d5dea4.880a9","name":"Manufacturer Name","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a29","x":190,"y":120,"wires":[["6c40fa5c.0c67c4"]]},{"id":"acca877e.c6a21","type":"switch","z":"c0d5dea4.880a9","name":"","property":"payload.characteristics","propertyType":"msg","rules":[{"t":"hask","v":"2a07","vt":"str"},{"t":"hask","v":"2a29","vt":"str"},{"t":"hask","v":"2a26","vt":"str"},{"t":"hask","v":"2a25","vt":"str"},{"t":"hask","v":"2a24","vt":"str"},{"t":"hask","v":"2a21","vt":"str"},{"t":"hask","v":"2a1c","vt":"str"},{"t":"hask","v":"835ab4c051e411e3a5bd0002a5d5c51b","vt":"str"},{"t":"hask","v":"8cd67da0da9b11e390870002a5d5c51b","vt":"str"},{"t":"hask","v":"2904","vt":"str"},{"t":"hask","v":"2aff","vt":"str"}],"checkall":"true","repair":false,"outputs":11,"x":610,"y":240,"wires":[["1ffc7951.024a4f"],["a50ad569.2e6218"],["4f20d698.5fcd7"],["18f05622.4a7eda"],["6456013c.7fbd48"],["512c19e4.4eaee"],["60451453.d5fda4"],["f4cf3b81.325f58"],["2c16b8bd.47d628"],[],["6217570b.609788"]]},{"id":"f2a3079.9559078","type":"inject","z":"c0d5dea4.880a9","name":"Probe","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":230,"y":540,"wires":[["6c40fa5c.0c67c4"]]},{"id":"60451453.d5fda4","type":"function","z":"c0d5dea4.880a9","name":"Temperature","func":"msg.topic = \"Temperature\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a1c\"];\n    value = value.slice(1,5);\n    value = value.readFloatBE();\nmsg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":930,"y":320,"wires":[["3880141e.2cbf04"]]},{"id":"2c16b8bd.47d628","type":"function","z":"c0d5dea4.880a9","name":"Pressure - UUID4","func":"msg.topic = \"Pressure\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"8cd67da0da9b11e390870002a5d5c51b\"][0];\nmsg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":950,"y":400,"wires":[["3880141e.2cbf04"]]},{"id":"f4cf3b81.325f58","type":"function","z":"c0d5dea4.880a9","name":"Pressure -UUID2","func":"msg.topic = \"Pressure\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"835ab4c051e411e3a5bd0002a5d5c51b\"];\n    value = value.readInt16BE();\nmsg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":950,"y":360,"wires":[["3880141e.2cbf04"]]},{"id":"bfc2662e.abbe","type":"inject","z":"c0d5dea4.880a9","name":"Scale Value","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2904","x":210,"y":480,"wires":[["6c40fa5c.0c67c4"]]},{"id":"a50ad569.2e6218","type":"function","z":"c0d5dea4.880a9","name":"Manufacturer Name","func":"msg.topic = \"Manufacturer Name\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a29\"];\n    value = value.toString();\nmsg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":960,"y":120,"wires":[["3880141e.2cbf04"]]},{"id":"1ffc7951.024a4f","type":"function","z":"c0d5dea4.880a9","name":"Tx Power","func":"msg.topic = \"Tx Power\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a07\"];\n    value = value.readInt8(0);\nmsg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":920,"y":80,"wires":[["3880141e.2cbf04"]]},{"id":"4f20d698.5fcd7","type":"function","z":"c0d5dea4.880a9","name":"Firmware Revision","func":"msg.topic = \"Firmware Revision\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a26\"];\n    value = value.toString();\nmsg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":950,"y":160,"wires":[["3880141e.2cbf04"]]},{"id":"18f05622.4a7eda","type":"function","z":"c0d5dea4.880a9","name":"Serial Number","func":"msg.topic = \"Serial Number\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a25\"];\n    value = value.toString();\nmsg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":940,"y":200,"wires":[["3880141e.2cbf04"]]},{"id":"6456013c.7fbd48","type":"function","z":"c0d5dea4.880a9","name":"Model Number","func":"msg.topic = \"Model Number\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a24\"];\n    value = value.toString();\nmsg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":940,"y":240,"wires":[["3880141e.2cbf04"]]},{"id":"512c19e4.4eaee","type":"function","z":"c0d5dea4.880a9","name":"Measurement Interval","func":"msg.topic = \"Measurement Interval\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a21\"];\n    value = value.readInt16LE();\nmsg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":960,"y":280,"wires":[["3880141e.2cbf04"]]},{"id":"6217570b.609788","type":"buffer-parser","z":"c0d5dea4.880a9","name":"Advertising Blob","data":"payload.characteristics[\"2aff\"]","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int32le","name":"Pressure","offset":0,"length":3,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"Temperature","offset":2,"length":2,"offsetbit":0,"scale":"1","mask":""},{"type":"int8","name":"Battery Level","offset":4,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"string","name":"Device","offset":6,"length":6,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"output","multipleResult":true,"fanOutMultipleResult":true,"setTopic":true,"outputs":4,"x":700,"y":500,"wires":[["a85706bc.860988"],["7d54150f.ee403c"],["7190d2ce.c702ac"],["d0fcc386.ef9318"]]},{"id":"a85706bc.860988","type":"function","z":"c0d5dea4.880a9","name":"Pressure","func":"msg.topic = \"Pressure\";\nvar now = ( new Date() ).getTime();\nvar array = [\"0x0\"];\narray = array.concat(msg.payload);\nvar value = Buffer.from(array)\n    value = value.readUInt32LE();\nmsg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":920,"y":440,"wires":[["3880141e.2cbf04"]]},{"id":"7d54150f.ee403c","type":"function","z":"c0d5dea4.880a9","name":"Temperature","func":"msg.topic = \"Temperature\";\nvar now = ( new Date() ).getTime();\nvar value = Buffer.from(msg.payload);\n    value = value.readInt16LE(0);\n   msg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":930,"y":480,"wires":[["3880141e.2cbf04"]]},{"id":"d0fcc386.ef9318","type":"function","z":"c0d5dea4.880a9","name":"Device Address","func":"msg.topic = \"Device Address\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload;\n    value = value.toString();\nmsg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":940,"y":560,"wires":[["3880141e.2cbf04"]]},{"id":"7190d2ce.c702ac","type":"function","z":"c0d5dea4.880a9","name":"Battery Level","func":"msg.topic = \"Battery Level\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload;\n   msg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":930,"y":520,"wires":[["3880141e.2cbf04"]]},{"id":"9078f63b.0dc458","type":"Generic BLE","localName":"91087              ","address":"00:81:f9:97:40:20","uuid":"0081f9974020","characteristics":[{"uuid":"2a07","name":"Tx Power Level","type":"org.bluetooth.characteristic.tx_power_level","notifiable":false,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"2a29","name":"Manufacturer Name String","type":"org.bluetooth.characteristic.manufacturer_name_string","notifiable":false,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"2a26","name":"Firmware Revision String","type":"org.bluetooth.characteristic.firmware_revision_string","notifiable":false,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"2a25","name":"Serial Number String","type":"org.bluetooth.characteristic.serial_number_string","notifiable":false,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"2a24","name":"Model Number String","type":"org.bluetooth.characteristic.model_number_string","notifiable":false,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"2aff","name":"<Unnamed>","type":"(Custom Type)","notifiable":false,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"2a21","name":"Measurement Interval","type":"org.bluetooth.characteristic.measurement_interval","notifiable":false,"readable":true,"writable":true,"writeWithoutResponse":false},{"uuid":"2a1c","name":"Temperature Measurement","type":"org.bluetooth.characteristic.temperature_measurement","notifiable":true,"readable":true,"writable":false,"writeWithoutResponse":false},{"uuid":"8cd67da0da9b11e390870002a5d5c51b","name":"<Unnamed>","type":"(Custom Type)","notifiable":false,"readable":true,"writable":true,"writeWithoutResponse":false},{"uuid":"835ab4c051e411e3a5bd0002a5d5c51b","name":"<Unnamed>","type":"(Custom Type)","notifiable":true,"readable":true,"writable":false,"writeWithoutResponse":false}]}]
