This is an awsome node, i'm really enjoying the contex storage example to monitor some real world machine running time . But pushing things a little bit further i'd like to modify the rising edge counter to be persisent as well. I have a payload from a counter that i would like to persist across restarts. any ideas anyone?
you want to modify the rising edge counter within the node? If that’s the case the best bet as it is a contrib node is to open a discussion with the node author.
The best place for that is usually the nodes github page ( a link is generally avaialable from the nodes page on flows.nodered.org)
If you mean outside of node-red read the blog entry on the latest release about persistent storage.
@jupiter8: There are two ways to do it:
- Store the counter in a context variable, see persist across restarts
- Set the dsm configuration with an inject node:
Note: The inject node is only used once to define the configuration (or if you need to modify it).
Flow:
[{"id":"f18070e.d1f739","type":"dsm","z":"6ff0723.8c6b78c","name":"rising-edge counter","sm_config":"","x":380,"y":1200,"wires":[["581f1472.02c33c"]]},{"id":"6faa5214.722d9c","type":"inject","z":"6ff0723.8c6b78c","name":"","topic":"","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":1240,"wires":[["f18070e.d1f739"]]},{"id":"581f1472.02c33c","type":"debug","z":"6ff0723.8c6b78c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":570,"y":1200,"wires":[]},{"id":"cf54e77.7332618","type":"inject","z":"6ff0723.8c6b78c","name":"","topic":"","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":1200,"wires":[["f18070e.d1f739"]]},{"id":"ca10673e.2a1e28","type":"inject","z":"6ff0723.8c6b78c","name":"reset counter","topic":"reset","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":1160,"wires":[["f18070e.d1f739"]]},{"id":"98a31f23.6ae47","type":"inject","z":"6ff0723.8c6b78c","name":"set","topic":"set","payload":"{ \"data\": { \"counter\": 0 }, \t\"methods\": { \t \"reset\": \"sm.data.counter = 0;\", \t \"onTransition\": [ \t \"if (msg.payload === 1) {\", \" sm.data.counter++;\", \" msg.payload = sm.data.counter;\", \" output = true;\", \"}\" ], \t \"status\": { \t \"fill\": \"blue\", \"shape\": \"dot\", \"text\": { \"get\": \"sm.data.counter;\" } } \t} }","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":1120,"wires":[["f18070e.d1f739"]]}]
This isn't an issue but a question, so here is the right place to ask. You may also open an issue on github if you like, no problems for me.
Works a treat, thank you very much.
And by the way, how can i format the ouput of the "operating time" flow in hours min sec like a normal hour meter on a machine? I've searched for a javascript function example or node but all are giving Time, it has to be a simple sec to HH:mm:ss function...
Have a look at node-red-contrib-moment
@jupiter8
You can use the node @colin has proposed or use a simple function in the dsm node.
Just copy/past this configuration:
"currentState": "stopped",
"states": {
"stopped": {
"on": "started"
"started": {
"inc": "counting",
"off": "stopped"
"counting": {
"inc": "counting",
"off": "stopped"
"data": {
"prev_time": null,
"time": 0,
"seconds": 0,
"interval": 5
"methods": {
"init": [
"sm.calc_time = function () {",
" var now = Date.now();",
" sm.data.time += now - sm.data.prev_time;",
" sm.data.prev_time = now;",
" sm.data.seconds = Math.round(sm.data.time / 1000);",
"sm.sec2hhmmss = function(t) {",
" var min = t/60;",
" var t_h = pad(parseInt(min / 60));",
" var t_m = pad(parseInt(min % 60));",
" var t_s = pad(Math.round(t % 60));",
" return t_h+':'+t_m+':'+t_s;",
"on": [
"if (sm.currentState === 'started') {",
" sm.data.prev_time = Date.now();",
" resume('inc', msg);",
"output = false;"
"inc": [
"timeout.interval = setTimeout(function() {",
" sm.calc_time();",
" msg.data = sm.data;",
" /* msg.payload = sm.sec2hhmmss(sm.data.seconds);",
" node.send(msg); */",
"}, sm.data.interval*1000);",
"output = false;"
"off": [
"clearTimeout(timeout.interval);",
"sm.calc_time();",
"msg.payload = sm.sec2hhmmss(sm.data.seconds);"
"reset": [
"sm.data.time = 0;",
"sm.data.seconds = 0;"
"status": {
"fill": {
"get": "sm.currentState === 'counting' ? 'green' : 'grey';"
"shape": "dot",
"text": {
"get": "'time '+ sm.sec2hhmmss(sm.data.seconds);"
Exellent! Thanks.
