We are using node-red-contrib-flow-manager to split up our flow to make version handling of the flows more manageable.
However the file "flow-manager-nodes-order.json" generated by the library just contain an array with all nodes in it. This file is causing conflicts all the time for us.
From the changelog (0.7) of node-red-contrib-flow-manager:
- added file flow-manager-nodes-order.json to keep nodes order, to remain in sync with UI nodes order, and avoid false-positives of "flows are not up to date" in UI.
From the description the description my best guess is that its not necessary to have this file version handled but I can be sure - anybody with tips / knowledge regarding this?
Thanks in advance!
