[node-red-contrib-iiot-opcua] Listener node gives encode error when "Send Just Values" is disabled
I'm trying to subscribe Prosys OPC UA Simulation Server 5.2.2 simulation folder just using iiot-opcua nodes. Using a "read node" I can read all values from tags of simulation folder but when I try to subscribe same tags using a "subscribe node", I get a error message.
My intention is subscribe tags instead call read node periodically:
Working flow using node "read" triggered by injection node:
        "id": "bb75dff736f15f64",
        "type": "tab",
        "label": "opc read",
        "disabled": false,
        "info": ""
        "id": "9b7c70c0d9bb699f",
        "type": "OPCUA-IIoT-Browser",
        "z": "bb75dff736f15f64",
        "connector": "18fecfa6.964f1",
        "nodeId": "ns=3;s=85/0:Simulation",
        "justValue": false,
        "sendNodesToRead": false,
        "sendNodesToListener": true,
        "sendNodesToBrowser": false,
        "multipleOutputs": false,
        "recursiveBrowse": false,
        "recursiveDepth": "1",
        "delayPerMessage": "",
        "showStatusActivities": false,
        "showErrors": false,
        "x": 340,
        "y": 160,
                "eac6e41e50101fb7"
        "id": "864b73bbd67aeaca",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload.resultsConverted",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 770,
        "y": 160,
        "id": "1f2ef3f06ccaadf3",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 140,
        "y": 160,
                "9b7c70c0d9bb699f"
        "id": "eac6e41e50101fb7",
        "type": "OPCUA-IIoT-Read",
        "attributeId": "130",
        "maxAge": "5",
        "depth": 1,
        "justValue": false,
        "parseStrings": false,
        "historyDays": "1",
        "x": 510,
        "y": 160,
                "864b73bbd67aeaca"
        "id": "18fecfa6.964f1",
        "type": "OPCUA-IIoT-Connector",
        "discoveryUrl": "",
        "endpoint": "opc.tcp://efc:53530/OPCUA/SimulationServer",
        "keepSessionAlive": true,
        "loginEnabled": false,
        "securityPolicy": "None",
        "securityMode": "None",
        "name": "PROSYS SERVER",
        "showErrors": true,
        "individualCerts": false,
        "publicCertificateFile": "",
        "privateKeyFile": "",
        "defaultSecureTokenLifetime": "60000",
        "endpointMustExist": true,
        "autoSelectRightEndpoint": true,
        "strategyMaxRetry": "",
        "strategyInitialDelay": "",
        "strategyMaxDelay": "",
        "strategyRandomisationFactor": "",
        "requestedSessionTimeout": "",
        "connectionStartDelay": "",
        "reconnectDelay": "",
        "maxBadSessionRequests": ""
Succesful output:
[{"nodeId":"ns=3;i=1001","statusCode":{"value":0},"nodeClass":2,"browseName":{"namespaceIndex":3,"name":"Counter"},"displayName":{"text":"Counter"},"description":{"text":""},"writeMask":0,"userWriteMask":0,"value":42,"dataType":"ns=0;i=6","valueRank":-1,"arrayDimensions":null,"accessLevel":5,"userAccessLevel":5,"minimumSamplingInterval":-1,"historizing":true},{"nodeId":"ns=3;i=1002","statusCode":{"value":0},"nodeClass":2,"browseName":{"namespaceIndex":3,"name":"Random"},"displayName":{"text":"Random"},"description":{"text":""},"writeMask":0,"userWriteMask":0,"value":-0.5189329,"dataType":"ns=0;i=11","valueRank":-1,"arrayDimensions":null,"accessLevel":5,"userAccessLevel":5,"minimumSamplingInterval":-1,"historizing":true},{"nodeId":"ns=3;i=1003","statusCode":{"value":0},"nodeClass":2,"browseName":{"namespaceIndex":3,"name":"Sawtooth"},"displayName":{"text":"Sawtooth"},"description":{"text":""},"writeMask":0,"userWriteMask":0,"value":-0.8,"dataType":"ns=0;i=11","valueRank":-1,"arrayDimensions":null,"accessLevel":5,"userAccessLevel":5,"minimumSamplingInterval":-1,"historizing":true},{"nodeId":"ns=3;i=1004","statusCode":{"value":0},"nodeClass":2,"browseName":{"namespaceIndex":3,"name":"Sinusoid"},"displayName":{"text":"Sinusoid"},"description":{"text":""},"writeMask":0,"userWriteMask":0,"value":-1.17557,"dataType":"ns=0;i=11","valueRank":-1,"arrayDimensions":null,"accessLevel":5,"userAccessLevel":5,"minimumSamplingInterval":-1,"historizing":true},{"nodeId":"ns=3;i=1005","statusCode":{"value":0},"nodeClass":2,"browseName":{"namespaceIndex":3,"name":"Square"},"displayName":{"text":"Square"},"description":{"text":""},"writeMask":0,"userWriteMask":0,"value":2,"dataType":"ns=0;i=11","valueRank":-1,"arrayDimensions":null,"accessLevel":5,"userAccessLevel":5,"minimumSamplingInterval":-1,"historizing":true},{"nodeId":"ns=3;i=1006","statusCode":{"value":0},"nodeClass":2,"browseName":{"namespaceIndex":3,"name":"Triangle"},"displayName":{"text":"Triangle"},"description":{"text":""},"writeMask":0,"userWriteMask":0,"value":-0.7999999,"dataType":"ns=0;i=11","valueRank":-1,"arrayDimensions":null,"accessLevel":5,"userAccessLevel":5,"minimumSamplingInterval":-1,"historizing":true}]
Fault subscribe flow using "listener node" as subscriber:
        "id": "507d8e18.767b68",
        "type": "tab",
        "label": "opc listener",
        "disabled": false,
        "info": ""
        "id": "39cdf744.28ca18",
        "type": "OPCUA-IIoT-Inject",
        "z": "507d8e18.767b68",
        "injectType": "listen",
        "payload": "{\"interval\":1000,\"queueSize\":4,\"options\":{\"requestedPublishingInterval\":1000,\"requestedLifetimeCount\":60,\"requestedMaxKeepAliveCount\":10,\"maxNotificationsPerPublish\":4,\"publishingEnabled\":true,\"priority\":1}}",
        "payloadType": "json",
        "topic": "",
        "repeat": "",
        "crontab": "",
        "once": false,
        "startDelay": "",
        "addressSpaceItems": [],
        "x": 170,
        "y": 100,
                "8b969a42.65dad8"
        "id": "8b969a42.65dad8",
        "name": "Single Browser",
        "justValue": false,
        "showErrors": true,
        "x": 340,
        "y": 100,
                "95f8eefc.7f68a8"
        "id": "243f0736.abdc18",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "x": 730,
        "y": 100,
        "id": "95f8eefc.7f68a8",
        "type": "OPCUA-IIoT-Listener",
        "action": "subscribe",
        "queueSize": "6",
        "topic": "",
        "justValue": true,
        "useGroupItems": true,
        "showStatusActivities": true,
        "showErrors": true,
        "x": 580,
        "y": 100,
                "243f0736.abdc18"
        "discoveryUrl": "",
        "showErrors": true,
Error message:
Error: encodeObject Error: [Error] Value: {
  payload: {
    addressSpaceItems: [ [Object] ],
    nodetype: 'listen',
    injectType: 'subscribe',
    value: DataValue {
      statusCode: [ConstantStatusCode],
      sourceTimestamp: [Date],
      sourcePicoseconds: 0,
      serverTimestamp: [Date],
      serverPicoseconds: 0,
      value: [Variant]
    monitoredItem: ClientMonitoredItemImpl {
      _events: [Object: null prototype],
      _eventsCount: 4,
      _maxListeners: undefined,
      subscription: [ClientSubscriptionImpl],
      itemToMonitor: [ReadValueId],
      monitoringParameters: [MonitoringParameters],
      monitoringMode: 2,
      timestampsToReturn: 2,
      result: [MonitoredItemCreateResult],
      monitoredItemId: 5,
      filterResult: undefined,
      [Symbol(kCapture)]: false
  topic: '',
  justValue: false,
  _msgid: 'c05f0190dbdeacf5'
If I enable "Send Just Values" listener node works but I didn't receive tag name or aditional data.
Any suggestions?
Node-RED and all nodes are updated.
