Node-red-contrib-mios
I am running Node-RED on a Raspberry Pi 4 with openhabian 2.5.3-1. I am using the node 'node-red-contrib-mios', which seems to do exactly what I need. I have a problem however, when I reboot. The node seems to output a corrupted payload. When I restart node-RED or deploy the nodes again, the problem resolves. If I disable node-RED and start it manually some time after a reboot, all is well. Thoughts?
Raise an issue on the repo. If the Dev is responsive and you can demonstrate the issue, it may get fixed.
