Has anyone implemented thermostatTemperatureRange for the thermostat node?
I use this node in my KNX installation at my home and I have a KNX thermostat that I would like to control with the Nora thermostat node.
This works fine but my KNX thermostat has a variable that sets the max and min allowed temperature shift. I would like this to be the same max min value in the thermostat that is in google home app.
I have tried to implement the following in the nora-thermostat.js script witch results in following error: nora: "sync error (invalid object for sync)"
//Original Code
var state$ = new rxjs_1.BehaviorSubject({
online: true,
thermostatMode: 'off',
thermostatTemperatureAmbient: 25,
thermostatTemperatureSetpoint: 20,
thermostatTemperatureSetpointLow: 20,
thermostatTemperatureSetpointHigh: 30,
//new code
thermostatTemperaturerange: {
minTemperatureRangeCelsius: 15,
maxTemperatureRangeCelsius: 25,
Is there any way to do this locally ore must this be done by the developer of the node?
