Node-red-contrib-opcua : dynamic setting of "Value" property of OpcUa-Item node
Dear Team,
For the use case I am trying to implement, I need to set the "Value" property of OpcUa-Item node dynamically using the msg object attribute, which gets the event from external system like Kafka broker. Can you help me by pointing to some examples in this regard please?
Basically, i am trying to write a tag value in a OPC UA server through this node.
Regards,
Mohan B.
