Node-red-contrib-sonos-plus
With one of the latest updates, my sonos flow does not work anymore...
When an eveent occurred, my sonos flow must play a file on my nas...
it worked some weeks ago, and now i dont hear the file playing and i have an error.
I attached a part of my message and the flow..
Hi - its a bug. I can reproduce it. Sorry for the inconvience.
Hope that I can fix it today.
ok, i have a workaround by using
  • library.export.track (search a file)
  • group.play.export (play the found file )
just published 5.03 - should be fixed there.
Does it work for you?
Hi Hklages,
It works again!
Greets peter
Verzonden vanuit Mail voor Windows 10
I do have some Problems with the new Version 5.03 of the node-red-contrib-sonos-plus.
Playing some radio-stations in my Dashbord is the name of the Radiostation displayed. The debugging window on the left shows me the following error displayed by a xml-node -called "Radio Station":
10.4.2021, 08:51:52node: Radio Station
msg : error
error
Error: Non-whitespace before first tag.
Line: 0
Column: 1
Char: W
The played Radiostation was WDR2 in Germany.
[{"id":"dc640cce.e046d","type":"ui_template","z":"e87bf2c.7a7039","group":"5df3954c.79a78c","name":"Radiostation","order":12,"width":6,"height":1,"format":"<div class=blockstation ng-bind-html=\"msg.payload\"></div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":1290,"y":1300,"wires":[[]]},{"id":"2c5612cd.57777e","type":"change","z":"e87bf2c.7a7039","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[\"DIDL-Lite\"].item[0][\"dc:title\"][0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1090,"y":1300,"wires":[["dc640cce.e046d"]]},{"id":"500c32dd.28636c","type":"xml","z":"e87bf2c.7a7039","name":"Radio Station","property":"payload","attr":"$","chr":"","x":900,"y":1300,"wires":[["2c5612cd.57777e"]]},{"id":"d38637d4.559ff8","type":"change","z":"e87bf2c.7a7039","name":"payload für Radiostaion","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.mediaData.CurrentURIMetaData.Title","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":1300,"wires":[["500c32dd.28636c"]]},{"id":"939762fe.8c86b8","type":"sonos-universal","z":"e87bf2c.7a7039","confignode":"703c72a2.0eae9c","command":"message","state":"","stateType":"str","name":"","x":320,"y":1140,"wires":[["d38637d4.559ff8","6e400820.d00548","6862c5fb.532fcc","b0c5878d.3ba49","a109073a.fb2d6"]]},{"id":"1224cac2.11e2ad","type":"inject","z":"e87bf2c.7a7039","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"4","crontab":"","once":true,"onceDelay":0.1,"topic":"get.trackplus","payload":"","payloadType":"str","x":140,"y":1140,"wires":[["939762fe.8c86b8"]]},{"id":"6e400820.d00548","type":"change","z":"e87bf2c.7a7039","name":"payload.artist","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.artist","tot":"msg"},{"t":"change","p":"payload","pt":"msg","from":"unknown","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":1100,"wires":[["71af078e.1fdb68","8d377ae0.d154d"]]},{"id":"6862c5fb.532fcc","type":"change","z":"e87bf2c.7a7039","name":"payload.title","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.title","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":1180,"wires":[["37ea71a2.083b36","8d377ae0.d154d"]]},{"id":"b0c5878d.3ba49","type":"change","z":"e87bf2c.7a7039","name":"payload.title","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.mediaData.NrTracks","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":1220,"wires":[["cde8c2b.1538a4"]]},{"id":"a109073a.fb2d6","type":"change","z":"e87bf2c.7a7039","name":"payload.title","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.positionData.Track","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":1260,"wires":[["ce34ea5e.170bf","f92fa4d5.c9b488"]]},{"id":"71af078e.1fdb68","type":"ui_template","z":"e87bf2c.7a7039","group":"5df3954c.79a78c","name":"Artist","order":7,"width":6,"height":2,"format":"<div class=\"blockartist\" ng-bind-html=\"msg.payload\">\n    </div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":1270,"y":1100,"wires":[[]]},{"id":"8d377ae0.d154d","type":"batch","z":"e87bf2c.7a7039","name":"","mode":"count","count":"2","overlap":0,"interval":"2","allowEmptySequence":false,"topics":[],"x":790,"y":1140,"wires":[["d22be83d.67294"]]},{"id":"37ea71a2.083b36","type":"ui_template","z":"e87bf2c.7a7039","group":"5df3954c.79a78c","name":"Title","order":8,"width":6,"height":2,"format":"\n<div class=\"blocktitle\" ng-bind-html=\"msg.payload\"></div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":1270,"y":1180,"wires":[[]]},{"id":"cde8c2b.1538a4","type":"ui_text","z":"e87bf2c.7a7039","group":"5df3954c.79a78c","order":4,"width":1,"height":1,"name":"gesamtTracks","label":"","format":"{{msg.payload}}","layout":"col-center","x":1300,"y":1220,"wires":[]},{"id":"ce34ea5e.170bf","type":"ui_text","z":"e87bf2c.7a7039","group":"5df3954c.79a78c","order":3,"width":1,"height":1,"name":"TrackNr.","label":"","format":"{{msg.payload}}","layout":"col-center","x":1280,"y":1260,"wires":[]},{"id":"f92fa4d5.c9b488","type":"debug","z":"e87bf2c.7a7039","name":"Test4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":890,"y":1020,"wires":[]},{"id":"d22be83d.67294","type":"join","z":"e87bf2c.7a7039","name":"","mode":"custom","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":" - ","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"num","reduceFixup":"","x":910,"y":1140,"wires":[["27f464e0.790b04"]]},{"id":"27f464e0.790b04","type":"change","z":"e87bf2c.7a7039","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"- unknown","fromt":"str","to":" \\chr(20)","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"ä","fromt":"str","to":"ae","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"ö","fromt":"str","to":"oe","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"ü","fromt":"str","to":"ue","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"ß","fromt":"str","to":"ss","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"°","fromt":"str","to":"Grad","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"&amp;","fromt":"str","to":"&","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":1140,"wires":[["2a8e0f78.c353c8"]]},{"id":"2a8e0f78.c353c8","type":"mqtt out","z":"e87bf2c.7a7039","name":"","topic":"/MatrixDisplay2/rdsSz","qos":"","retain":"","broker":"4f9fd004.61dcd8","x":1320,"y":1140,"wires":[]},{"id":"5df3954c.79a78c","type":"ui_group","name":"SONOS","tab":"9a8f8e45.49d28","order":3,"disp":true,"width":"6","collapse":true},{"id":"703c72a2.0eae9c","type":"sonos-config","name":"Schlafzimmer","serialnum":"34-7E-5C-32-88-0E:3","ipaddress":"192.168.2.24"},{"id":"4f9fd004.61dcd8","type":"mqtt-broker","name":"Raspberry4","broker":"192.168.2.45","port":"1883","clientid":"3c5bcf5ccc4b4058a1778c49193320b6","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"9a8f8e45.49d28","type":"ui_tab","name":"Schlafzimmer","icon":"mi-hotel","order":6,"disabled":false,"hidden":false}]
![Screenshot_2021-04-10 Node-RED 192 168 2 45|690x32](upload://pwf9UqSwil2r2eO97bbBZjhwvx9.png)
(I'm not able to post a picture of the flow. Sorry)
This error comes up since the update to 5.03. I hope someone can help me.
Regards
Eberhard
Hi Eberhard!
Please remove the xml conversion and set msg payload. Conversion is not anymore necessary.
See the picture below (without the 2 nodes).
An even better solution might be sonos-events. That does not poll for the data but subscribes to the event.
Thank you so much!!
Regards Eberhard
