thanks for the help and clarification.
The alert msg was only to test if it work. I don't need alert popup's.
I need to move a shape in the svg, tomorow I will try and give the feedback.
All work fine, and the example work as expected.
thanks for the help.
Another question, it is possible to update the font Font Awesome and materialdesignicons? I need some icons that are only available in new versions. Dorne or quadcopter is one.
When you search through this forum, you will see that other users have alteady asked that also (not specific for the svg node, but general for the dashboard). You probably can find the answer in those discussions.
