Node-red-contrib-uibuilder v1.0.11 published
Hi all,
A quick update to uibuilder.
  • NEW Add some example flows to the example libary.
    Use the Node-RED administration UI's menu Import > Examples > uibuilder to import them.
  • FIX Bug in socket.io namespace if httpNodeRoot was set to something other than default. Also closes Issue #30
As so often, fix one problem, discover another!
v1.0.12 published. A minor fix to the default template index.html file.
