Node-red-contrib-verisure
Been working on a node for a while, seems to being used "out there" now. This is a nodered version of the nodejs verisure module by ptz0n, reverse engineered integration, using their app apis.
  • One config node carrying the credentials. I advice to set up a separate read only user in Verisure for this integration
  • Separate node for just fetching the alarm status and if it has changed since last call
  • A third node for extracting different sensor data from verisure: climate values, lock status, door/window sensor status. Or just fetching the full site object and work on that yourselves.
No, no integrations the other way. Strict separations of concern and robustness in my smarthome design, so do not want any other systems changing Verisure, ie turning on/off alarm etc.
*https://www.npmjs.com/package/node-red-contrib-verisure
*https://github.com/ksvan/node-red-contrib-verisure#readme
