Node-Red controlling 8 outlets for AC Power
I'm having too much fun with Node-Red!
I had an old rack mounted power strip and I got to thinking that Node-Red and a Pi Zero W would be the perfect solution to giving myself an inexpensive IP controlled Power Strip.
I got a 5V power supply and an 8 relay strip and while I was at it I cut a connector into the side that I can tap for up to 4 more 5V devices, such as other Pi's.
I wrote this flow and now I can browse to the UI on my phone and control 8 AC powered devices individually.
[{"id":"12e7f6d3.29b8c1","type":"ui_switch","z":"afba7257.93f7d8","name":"","label":"Outlet 2 Trig","tooltip":"","group":"e39e26ea.b46c2","order":4,"width":"2","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"false","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"true","offvalueType":"bool","officon":"","offcolor":"","x":770,"y":160,"wires":[["c8b5d068.e7617"]]},{"id":"55de046d.70f5fc","type":"ui_switch","z":"afba7257.93f7d8","name":"","label":"Outlet 1 Trig","tooltip":"","group":"e39e26ea.b46c2","order":2,"width":"2","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"false","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"true","offvalueType":"bool","officon":"","offcolor":"","x":770,"y":80,"wires":[["eab001a8.c08d2"]]},{"id":"eab001a8.c08d2","type":"rpi-gpio out","z":"afba7257.93f7d8","name":"","pin":"16","set":true,"level":"1","freq":"","out":"out","x":940,"y":80,"wires":[]},{"id":"c8b5d068.e7617","type":"rpi-gpio out","z":"afba7257.93f7d8","name":"","pin":"15","set":true,"level":"1","freq":"","out":"out","x":940,"y":160,"wires":[]},{"id":"e6955cb1.862dc","type":"ui_switch","z":"afba7257.93f7d8","name":"","label":"Outlet 3 Trig","tooltip":"","group":"e39e26ea.b46c2","order":6,"width":"2","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"false","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"true","offvalueType":"bool","officon":"","offcolor":"","x":770,"y":240,"wires":[["e77c3c16.a7204"]]},{"id":"35908013.b85ef","type":"ui_switch","z":"afba7257.93f7d8","name":"","label":"Outlet 4 Trig","tooltip":"","group":"e39e26ea.b46c2","order":8,"width":"2","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"false","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"true","offvalueType":"bool","officon":"","offcolor":"","x":770,"y":320,"wires":[["bbddcfde.0089b"]]},{"id":"e77c3c16.a7204","type":"rpi-gpio out","z":"afba7257.93f7d8","name":"","pin":"13","set":true,"level":"1","freq":"","out":"out","x":940,"y":240,"wires":[]},{"id":"bbddcfde.0089b","type":"rpi-gpio out","z":"afba7257.93f7d8","name":"","pin":"12","set":true,"level":"1","freq":"","out":"out","x":940,"y":320,"wires":[]},{"id":"455208e1.694f78","type":"ui_text_input","z":"afba7257.93f7d8","name":"","label":"Outlet 1","tooltip":"","group":"544b825d.aa89b4","order":4,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":460,"y":80,"wires":[["5244108e.105cb8"]]},{"id":"5244108e.105cb8","type":"ui_text","z":"afba7257.93f7d8","group":"e39e26ea.b46c2","order":1,"width":"4","height":"1","name":"","label":"","format":"{{msg.payload}}","layout":"row-spread","x":630,"y":80,"wires":[]},{"id":"7d9c6e7e.0467e","type":"ui_text","z":"afba7257.93f7d8","group":"e39e26ea.b46c2","order":3,"width":"4","height":"1","name":"","label":"","format":"{{msg.payload}}","layout":"row-spread","x":630,"y":160,"wires":[]},{"id":"e37a4949.fb226","type":"ui_text_input","z":"afba7257.93f7d8","name":"","label":"Outlet 2","tooltip":"","group":"544b825d.aa89b4","order":4,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":460,"y":160,"wires":[["7d9c6e7e.0467e"]]},{"id":"23faf9bb.d9c526","type":"ui_text_input","z":"afba7257.93f7d8","name":"","label":"Outlet 3","tooltip":"","group":"544b825d.aa89b4","order":4,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":460,"y":240,"wires":[["e429bb13.b585a"]]},{"id":"e429bb13.b585a","type":"ui_text","z":"afba7257.93f7d8","group":"e39e26ea.b46c2","order":5,"width":"4","height":"1","name":"","label":"","format":"{{msg.payload}}","layout":"row-spread","x":630,"y":240,"wires":[]},{"id":"ddd3c576.b50f8","type":"ui_text_input","z":"afba7257.93f7d8","name":"","label":"Outlet 4","tooltip":"","group":"544b825d.aa89b4","order":4,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":460,"y":320,"wires":[["71f14eed.c68d98"]]},{"id":"71f14eed.c68d98","type":"ui_text","z":"afba7257.93f7d8","group":"e39e26ea.b46c2","order":7,"width":"4","height":"1","name":"","label":"","format":"{{msg.payload}}","layout":"row-spread","x":630,"y":320,"wires":[]},{"id":"b93c5e95.14a28","type":"ui_switch","z":"afba7257.93f7d8","name":"","label":"Outlet 6 Trig","tooltip":"","group":"e39e26ea.b46c2","order":12,"width":"2","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"false","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"true","offvalueType":"bool","officon":"","offcolor":"","x":770,"y":480,"wires":[["e14662da.600f"]]},{"id":"e1eded42.1c1e78","type":"ui_switch","z":"afba7257.93f7d8","name":"","label":"Outlet 5 Trig","tooltip":"","group":"e39e26ea.b46c2","order":10,"width":"2","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"false","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"true","offvalueType":"bool","officon":"","offcolor":"","x":770,"y":400,"wires":[["9ebebef4.657988"]]},{"id":"9ebebef4.657988","type":"rpi-gpio out","z":"afba7257.93f7d8","name":"","pin":"11","set":true,"level":"1","freq":"","out":"out","x":940,"y":400,"wires":[]},{"id":"e14662da.600f","type":"rpi-gpio out","z":"afba7257.93f7d8","name":"","pin":"10","set":true,"level":"1","freq":"","out":"out","x":940,"y":480,"wires":[]},{"id":"ac735353.eae95","type":"ui_switch","z":"afba7257.93f7d8","name":"","label":"Outlet 7 Trig","tooltip":"","group":"e39e26ea.b46c2","order":14,"width":"2","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"false","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"true","offvalueType":"bool","officon":"","offcolor":"","x":770,"y":560,"wires":[["79dcec4d.0ca914"]]},{"id":"6d7697fc.a089b","type":"ui_switch","z":"afba7257.93f7d8","name":"","label":"Outlet 8 Trig","tooltip":"","group":"e39e26ea.b46c2","order":16,"width":"2","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"false","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"true","offvalueType":"bool","officon":"","offcolor":"","x":770,"y":640,"wires":[["6e8bcc3.5a6be34"]]},{"id":"79dcec4d.0ca914","type":"rpi-gpio out","z":"afba7257.93f7d8","name":"","pin":"8","set":true,"level":"1","freq":"","out":"out","x":940,"y":560,"wires":[]},{"id":"6e8bcc3.5a6be34","type":"rpi-gpio out","z":"afba7257.93f7d8","name":"","pin":"7","set":true,"level":"1","freq":"","out":"out","x":940,"y":640,"wires":[]},{"id":"c2307c8e.7e62a8","type":"ui_text_input","z":"afba7257.93f7d8","name":"","label":"Outlet 5","tooltip":"","group":"544b825d.aa89b4","order":4,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":460,"y":400,"wires":[["38d83845.39e63"]]},{"id":"38d83845.39e63","type":"ui_text","z":"afba7257.93f7d8","group":"e39e26ea.b46c2","order":9,"width":"4","height":"1","name":"","label":"","format":"{{msg.payload}}","layout":"row-spread","x":630,"y":400,"wires":[]},{"id":"c022e9d9.04a48","type":"ui_text","z":"afba7257.93f7d8","group":"e39e26ea.b46c2","order":11,"width":"4","height":"1","name":"","label":"","format":"{{msg.payload}}","layout":"row-spread","x":630,"y":480,"wires":[]},{"id":"e4d5208b.c18e9","type":"ui_text_input","z":"afba7257.93f7d8","name":"","label":"Outlet 6","tooltip":"","group":"544b825d.aa89b4","order":4,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":460,"y":480,"wires":[["c022e9d9.04a48"]]},{"id":"2fa8cc17.3b825c","type":"ui_text_input","z":"afba7257.93f7d8","name":"","label":"Outlet 7","tooltip":"","group":"544b825d.aa89b4","order":4,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":460,"y":560,"wires":[["92318a8.0aaf778"]]},{"id":"92318a8.0aaf778","type":"ui_text","z":"afba7257.93f7d8","group":"e39e26ea.b46c2","order":13,"width":"4","height":"1","name":"","label":"","format":"{{msg.payload}}","layout":"row-spread","x":630,"y":560,"wires":[]},{"id":"ed1cf884.b01a2","type":"ui_text_input","z":"afba7257.93f7d8","name":"","label":"Outlet 8","tooltip":"","group":"544b825d.aa89b4","order":4,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":460,"y":640,"wires":[["b8b62a88.a6a95"]]},{"id":"b8b62a88.a6a95","type":"ui_text","z":"afba7257.93f7d8","group":"e39e26ea.b46c2","order":15,"width":"4","height":"1","name":"","label":"","format":"{{msg.payload}}","layout":"row-spread","x":630,"y":640,"wires":[]},{"id":"e8570b5e.262f1","type":"change","z":"afba7257.93f7d8","name":"Outlet 1 Default Label","rules":[{"t":"set","p":"payload","pt":"msg","to":"Outlet 1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":40,"wires":[["5244108e.105cb8"]]},{"id":"59efec82.8aff2c","type":"change","z":"afba7257.93f7d8","name":"Outlet 2 Default Label","rules":[{"t":"set","p":"payload","pt":"msg","to":"Outlet 2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":120,"wires":[["7d9c6e7e.0467e"]]},{"id":"81f68b02.dea61","type":"change","z":"afba7257.93f7d8","name":"Outlet 3 Default Label","rules":[{"t":"set","p":"payload","pt":"msg","to":"Outlet 3","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":200,"wires":[["e429bb13.b585a"]]},{"id":"83b0d9cb.bed5f8","type":"change","z":"afba7257.93f7d8","name":"Outlet 4 Default Label","rules":[{"t":"set","p":"payload","pt":"msg","to":"Outlet 4","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":280,"wires":[["71f14eed.c68d98"]]},{"id":"c7a234e6.5df6a8","type":"change","z":"afba7257.93f7d8","name":"Outlet 5 Default Label","rules":[{"t":"set","p":"payload","pt":"msg","to":"Outlet 5","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":360,"wires":[["38d83845.39e63"]]},{"id":"cd89e010.ec15a","type":"change","z":"afba7257.93f7d8","name":"Outlet 6 Default Label","rules":[{"t":"set","p":"payload","pt":"msg","to":"Outlet 6","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":440,"wires":[["c022e9d9.04a48"]]},{"id":"7d870af6.97e664","type":"change","z":"afba7257.93f7d8","name":"Outlet 7 Default Label","rules":[{"t":"set","p":"payload","pt":"msg","to":"Outlet 7","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":520,"wires":[["92318a8.0aaf778"]]},{"id":"8c954048.587f58","type":"change","z":"afba7257.93f7d8","name":"Outlet 8 Default Label","rules":[{"t":"set","p":"payload","pt":"msg","to":"Outlet 8","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":600,"wires":[["b8b62a88.a6a95"]]},{"id":"3fa77f10.739fe8","type":"inject","z":"afba7257.93f7d8","name":"Initialize State","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":"1","x":120,"y":40,"wires":[["8c954048.587f58","7d870af6.97e664","cd89e010.ec15a","c7a234e6.5df6a8","83b0d9cb.bed5f8","81f68b02.dea61","59efec82.8aff2c","e8570b5e.262f1"]]},{"id":"e39e26ea.b46c2","type":"ui_group","z":"","name":"Power Ctrl","tab":"78d3dce8.eb878c","disp":true,"width":"6","collapse":false},{"id":"544b825d.aa89b4","type":"ui_group","z":"","name":"Outlet Labels","tab":"3f10fd07.050ec2","disp":true,"width":"6","collapse":false},{"id":"78d3dce8.eb878c","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false},{"id":"3f10fd07.050ec2","type":"ui_tab","z":"","name":"Tech Page","icon":"dashboard","disabled":false,"hidden":false}]
Your project reminds me of some Superhouse builds which you may be interested in to give you ideas.. He uses Arduino MQTT for end clients but Node-Red as the main brains...
Hey Robbo,
I finally had the chance to sit down and watch this video through. Neat stuff!
I am curious though what the benefits of the Arduino are though, vs the Pi. I can pick up a Pi Zero W at MicroCenter for $5 and I can't come up with any reason to go with an Arduino instead considering they seem to cost more for less functionality. I even grabbed a 4 pack of MCP3008s on Amazon and I started playing around with them so I can work with analog inputs too, which seemed like the one gaping hole in the Pi's capabilities. That's 4 Pi's with 8 ADC channels plus all the Pi GPIOs for under $35. Clearly the Arduinos are very popular though. What am I missing?
Thanks again for sharing! I have a list a mile long of things around my house I want to control. My next project is a scale with a load cell for my gravity fed water filter so I know when to add water without having to shake it, and I'm thinking about running a 1/4" water line and an electric ball valve so it will add the water on it's own too!
The Arduino is a micro controller so just runs the one program of your choosing and has better control of the hardware, where the Pi is a fully blown OS and does other things making it less reliable and not as fine control.
The Arduino Mega has 50+ GPIO pins and hardware PWM as well. A ESP board like the ESP8266 or it’s successor is also a micro controller with built in WiFi and Bluetooth and seems to be the go to controller these days. (It’s what the sonoffs use, so these devices can be re-flashed using Tasmota for local MQTT control). ESPhome is another easy way to flash these devices.
