I am trying to upgrade node-red to version 3.0.0 from 2.2.2. But the core does no install.
Stop Node-RED ✔
Remove old version of Node-RED ✔
Node option not specified : --node14, --node16, or --node18
Leave existing Node.js : v14.10.0 Npm 6.14.8
Clean npm cache -
Install Node-RED core ✘ 3.0.0
Move global nodes to local -
Leave existing nodes -
Install extra Pi nodes ✔
Add shortcut commands ✔
Update systemd script ✔
Try specifying the --node16 flag to update node from v14.10.0 to the current lts version. (But it should only require 14+)
What do the install logs say?
type or paste code here
Started : Tue Jul 26 12:34:41 PM EDT 2022
Running for user henry at /home/henry
Found global nodes: :
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Reading package lists...
Building dependency tree...
Reading state information...
E: Unable to locate package nodered
Versions: node:v14.10.0 npm:6.14.8
Now install Node-RED
sudo: npm: command not found
3.0.0
Now create basic package.json for the user and move any global nodes
Installing extra nodes: node-red-node-pi-gpio@latest node-red-node-random@latest node-red-node-ping@latest node-red-contrib-play-audio@latest node-red-node-smooth@latest node-red-node-serialport@latest :
npm WARN notsup Unsupported engine for @serialport/bindings-interface@1.2.2: wanted: {"node":"^12.22 || ^14.13 || >=16"} (current: {"node":"14.10.0","npm":"6.14.8"})
npm WARN notsup Not compatible with your version of node/npm: @serialport/bindings-interface@1.2.2
npm WARN notsup Unsupported engine for @serialport/bindings-interface@1.2.1: wanted: {"node":"^12.22 || ^14.13 || >=16"} (current: {"node":"14.10.0","npm":"6.14.8"})
npm WARN notsup Not compatible with your version of node/npm: @serialport/bindings-interface@1.2.1
+ node-red-node-smooth@0.1.2
+ node-red-node-serialport@1.0.1
+ node-red-node-pi-gpio@2.0.5
+ node-red-node-random@0.4.0
+ node-red-contrib-play-audio@2.5.0
+ node-red-node-ping@0.3.1
updated 6 packages in 4.384s
Now add the shortcut and start/stop/log scripts to the menu
Now add systemd script and configure it for henry:henry @ /home/henry
ln: failed to create symbolic link '/usr/bin/python': File exists
Now add launcher to top bar, add cpu temp example, make sure ping works
adduser: The group `gpio' does not exist.
python3-rpi.gpio is already the newest version (0.7.1~a4-1build1).
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Memory : 4.7G
Finished: Tue Jul 26 12:35:21 PM EDT 2022
So you have Node v14.10.0 but you have nodes that require Node v14.13.0 or higher.
