Node-red crash on DSM 7.2 Synology with node-red-contrib-hikvision-ultimate
Hi all.
First message here :blush:
I'm using node-red since many years sucessfully on Home Assistant add'on.
Now for professional project, I create an node-red container on Synology Container (docker).
Here's my docker-compose file
services:
  node-red:
    image: nodered/node-red:latest
    container_name: Node-RED
    user: 1029:65537
    environment:
      TZ: Europe/Paris
    healthcheck:
      test: timeout 10s bash -c ':> /dev/tcp/127.0.0.1/1880' || exit 1
      interval: 10s
      timeout: 5s
      retries: 3
      start_period: 90s
    hostname: node-red
    security_opt:
      - no-new-privileges:true
    read_only: true
    ports:
      - 6336:1880
    volumes:
      - /volume1/docker/nodered/data:/data:rw
    restart: on-failure:5
There's no problem at this time.
Issues begins when I add node-red-contrib-hikvision-ultimate palette.
After installation no issues.
Creating first node (ANPR node) and anter network information for camera in the node. Authentification sucessed.
But after few seconds node-red crash. It seams the first crash begins after the first connection to camera.
Afer restarting nodered, I tried to deleting and deployed the node quickly but crashed remains.
Restarting nodered, recrash... For now I have no nodes.
I'm disapointed on the task to check...
Here's the log of the container
Thanks for your help
Node-RED
date,stream,content
2025/11/29 22:21:26,stdout,    at TCP.done (node:_tls_wrap:648:7)
2025/11/29 22:21:26,stdout,    at node:net:343:12
2025/11/29 22:21:26,stdout,    at TLSSocket.emit (node:events:536:35)
2025/11/29 22:21:26,stdout,    at TLSSocket.socketCloseListener (node:_http_client:464:19)
2025/11/29 22:21:26,stdout,29 Nov 22:21:26 - [error] Error: aborted
2025/11/29 22:21:26,stdout,[red] Uncaught Exception:
2025/11/29 22:21:16,stdout,29 Nov 22:21:16 - [info] Started flows
2025/11/29 22:21:16,stdout,29 Nov 22:21:16 - [info] Starting flows
2025/11/29 22:21:16,stdout,---------------------------------------------------------------------
2025/11/29 22:21:16,stdout,file using your chosen key the next time you deploy a change.
2025/11/29 22:21:16,stdout,your settings file. Node-RED will then re-encrypt your credentials
2025/11/29 22:21:16,stdout,You should set your own key using the 'credentialSecret' option in
2025/11/29 22:21:16,stdout,your credentials.
2025/11/29 22:21:16,stdout,"file will not be recoverable, you will have to delete it and re-enter
2025/11/29 22:21:16,stdout,"If the system-generated key is lost for any reason, your credentials
2025/11/29 22:21:16,stdout,Your flow credentials file is encrypted using a system-generated key.
2025/11/29 22:21:16,stdout,29 Nov 22:21:16 - [warn]
2025/11/29 22:21:16,stdout,29 Nov 22:21:16 - [info] Server now running at http://127.0.0.1:1880/
2025/11/29 22:21:16,stdout,29 Nov 22:21:16 - [info] Flows file     : /data/flows.json
2025/11/29 22:21:16,stdout,29 Nov 22:21:16 - [warn] Projects disabled : editorTheme.projects.enabled=false
2025/11/29 22:21:16,stdout,29 Nov 22:21:16 - [info] User directory : /data
2025/11/29 22:21:16,stdout,29 Nov 22:21:16 - [info] Context store  : 'default' [module=memory]
2025/11/29 22:21:16,stdout,29 Nov 22:21:16 - [info] Settings file  : /data/settings.js
2025/11/29 22:21:13,stdout,29 Nov 22:21:13 - [info] Loading palette nodes
2025/11/29 22:21:12,stdout,29 Nov 22:21:12 - [info] Linux 4.4.302+ x64 LE
2025/11/29 22:21:12,stdout,29 Nov 22:21:12 - [info] Node.js  version: v20.19.5
2025/11/29 22:21:12,stdout,29 Nov 22:21:12 - [info] Node-RED version: v4.1.1
2025/11/29 22:21:12,stdout,===================
2025/11/29 22:21:12,stdout,Welcome to Node-RED
Welcome to the forum. Is it this issue? socket hang up · Issue #89 · Supergiovane/node-red-contrib-hikvision-ultimate · GitHub
Not sur this is the same...
I try to post on github. Wait...
