Node Red crashes on startup
After my SSD became unreadable, I had to reinstall everything. I had a backup of my flows and the package.json, which made it a little easier. Everything installed fine. But, when I start NR, it crashes immediately. But when I start it with node-red -safe, it starts fine. I thought that would start NR in safe mode ? It doesnt. I know in the past I had to start in safe mode, and I thought that was the way. Its running normally, with no exclamation mark to warn me that its running in safe mode. Should I just always start it this way ?
This is what is showing in the powershell window when starting with just node-red
C:\Windows\System32>node-red
15 Nov 15:44:41 - [info]
Welcome to Node-RED
15 Nov 15:44:41 - [info] Node-RED version: v3.1.0
15 Nov 15:44:41 - [info] Node.js  version: v20.9.0
15 Nov 15:44:41 - [info] Windows_NT 10.0.22631 x64 LE
15 Nov 15:44:43 - [info] Loading palette nodes
15 Nov 15:44:44 - [info] Polymer started at /polymer
15 Nov 15:44:45 - [info] Dashboard version 3.6.1 started at /ui
15 Nov 15:44:46 - [info] Settings file  : C:\Users\lenov\.node-red\settings.js
15 Nov 15:44:46 - [info] Context store  : 'default' [module=localfilesystem]
15 Nov 15:44:46 - [info] User directory : \Users\lenov\.node-red
15 Nov 15:44:46 - [warn] Projects disabled : editorTheme.projects.enabled=false
15 Nov 15:44:46 - [info] Flows file     : \Users\lenov\.node-red\flows.json
15 Nov 15:44:46 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
15 Nov 15:44:46 - [warn] Encrypted credentials not found
15 Nov 15:44:46 - [info] Starting flows
15 Nov 15:44:46 - [error] [position-config:1f69d2e37d8520dd] Coordinates Latitude and Longitude is missing in the configuration node!
15 Nov 15:44:46 - [error] [ntc-node-red-pushover-notifications:Node Red] Pushover credentials have not been set up
15 Nov 15:44:46 - [error] [e-mail:mike.kramer@blueyonder.co.uk] No e-mail userid set
15 Nov 15:44:46 - [error] [e-mail:mike.kramer@blueyonder.co.uk] No e-mail password set
15 Nov 15:44:46 - [info] Started flows
(node:5176) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 bbq1 listeners added to [RfxCom]. Use emitter.setMaxListeners() to increase limit
(Use `node --trace-warnings ...` to show where the warning was created)
(node:5176) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 temperaturerain1 listeners added to [RfxCom]. Use emitter.setMaxListeners() to increase limit
(node:5176) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 temperature1 listeners added to [RfxCom]. Use emitter.setMaxListeners() to increase limit
(node:5176) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 humidity1 listeners added to [RfxCom]. Use emitter.setMaxListeners() to increase limit
(node:5176) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 temperaturehumidity1 listeners added to [RfxCom]. Use emitter.setMaxListeners() to increase limit
(node:5176) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 temphumbaro1 listeners added to [RfxCom]. Use emitter.setMaxListeners() to increase limit
(node:5176) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 thermostat1 listeners added to [RfxCom]. Use emitter.setMaxListeners() to increase limit
(node:5176) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 rain1 listeners added to [RfxCom]. Use emitter.setMaxListeners() to increase limit
(node:5176) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 wind1 listeners added to [RfxCom]. Use emitter.setMaxListeners() to increase limit
(node:5176) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 uv1 listeners added to [RfxCom]. Use emitter.setMaxListeners() to increase limit
Shelly gen1 server is listening on port 20001
15 Nov 15:44:46 - [info] [rfx-sensor:Temp Wine Fridge Back] connecting to COM4
15 Nov 15:44:46 - [error] [daikin-controller:AC Study Speed] Could not get basic info: Error: Error while communicating with Daikin device: ECONNRESET
15 Nov 15:44:46 - [red] Uncaught Exception:
15 Nov 15:44:46 - [error] TypeError: myenergi.getStatusEddiAll is not a function
    at GetEddiAll._inputCallback (C:\Users\lenov\.node-red\node_modules\node-red-contrib-myenergi\getEddiAll.js:14:44)
    at C:\Users\lenov\AppData\Roaming\npm\node_modules\node-red\node_modules\@node-red\runtime\lib\nodes\Node.js:210:26
    at Object.trigger (C:\Users\lenov\AppData\Roaming\npm\node_modules\node-red\node_modules\@node-red\util\lib\hooks.js:166:13)
    at Node._emitInput (C:\Users\lenov\AppData\Roaming\npm\node_modules\node-red\node_modules\@node-red\runtime\lib\nodes\Node.js:202:11)
    at Node.emit (C:\Users\lenov\AppData\Roaming\npm\node_modules\node-red\node_modules\@node-red\runtime\lib\nodes\Node.js:186:25)
    at Node.receive (C:\Users\lenov\AppData\Roaming\npm\node_modules\node-red\node_modules\@node-red\runtime\lib\nodes\Node.js:494:10)
    at deliverMessageToDestination (C:\Users\lenov\AppData\Roaming\npm\node_modules\node-red\node_modules\@node-red\runtime\lib\flows\Flow.js:799:40)
    at Immediate.<anonymous> (C:\Users\lenov\AppData\Roaming\npm\node_modules\node-red\node_modules\@node-red\runtime\lib\flows\Flow.js:815:21)
    at process.processImmediate (node:internal/timers:478:21)
It looks like node-red-contrib-myenergi is NOT correctly handling async errors (causing node-red to crash)
You should raise an issue on its repository
That should be
node-red --safe
I think I found the issue. For whatever reason, NR lost the myenergi api key, amongst a lot of other configuration data, email password, pushover keys etc. After entering those again, it seems to work.
