Hi, for the last several days node-red has been crashing throughout the day. I have not updated any node nor am I showing any nodes need to be updated. below is the log that shows when I start node-red up until it crashes. Based on the information below, my assumption is that the problem node is node-red-contrib-cast, but I'm not sure, since I have never had a problem until now.
Thought?
Welcome to Node-RED
15 Oct 05:48:40 - [info] Node-RED version: v0.19.4
15 Oct 05:48:40 - [info] Node.js version: v8.12.0
15 Oct 05:48:40 - [info] Windows_NT 10.0.17134 x64 LE
15 Oct 05:48:44 - [info] Loading palette nodes
15 Oct 05:48:45 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
In the future, you will have to enable it yourself.
See https://github.com/yagop/node-telegram-bot-api/issues/319. module.js:653:30
15 Oct 05:48:49 - [info] RedBot version: 0.15.3 (node-red-contrib-chatbot)
15 Oct 05:48:51 - [info] Dashboard version 2.9.8 started at /ui
15 Oct 05:48:51 - [warn] nodes/core/io/lib/mqtt.js is deprecated and will be removed in a future release of Node-RED. Please report this usage to the Node-RED mailing list.
15 Oct 05:48:51 - [warn] nodes/core/io/lib/mqttConnectionPool.js is deprecated and will be removed in a future release of Node-RED. Please report this usage to the Node-RED mailing list.
15 Oct 05:48:51 - [warn] ------------------------------------------------------
15 Oct 05:48:51 - [warn] [node-red/tail] Not currently supported on Windows.
15 Oct 05:48:51 - [info] Settings file : \Users\unpue.node-red\settings.js
15 Oct 05:48:51 - [info] HTTP Static : C:\Users\unpue\public
15 Oct 05:48:51 - [info] Context store : 'default' [module=memory]
15 Oct 05:48:51 - [info] User directory : \Users\unpue.node-red
15 Oct 05:48:51 - [warn] Projects disabled : editorTheme.projects.enabled=false
15 Oct 05:48:51 - [info] Flows file : \Users\unpue.node-red\flows_WR-DESKTOP.json
15 Oct 05:48:51 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
15 Oct 05:48:51 - [info] Starting flows
15 Oct 05:48:51 - [info] [yeelight-compat-hue-config:WR Table Lamp Color] Connecting to Yeelight 192.168.2.156:55443
registering node 4b8837cc.54ae58
registering node edb65760.c04638
registering node 7bdac50c.e20ffc
registering node ab3756e.79497a8
15 Oct 05:48:52 - [error] [pushbullet-config:xxxxxxxx@gmail.com] No credentials set for pushbullet config.
15 Oct 05:48:52 - [info] Started flows
15 Oct 05:48:52 - [info] [mqtt-broker:Win-Mosquitto] Connected to broker: mqtt://192.168.2.153:1883
15 Oct 05:48:52 - [info] [yeelight-compat-hue-config:WR Table Lamp Color] Connected to 192.168.2.156:55443
15 Oct 05:50:54 - [info] [exec:Doorbell] error:Error: Command failed: curl "http://192.168.2.146:1035/?ALARM=CHIME&@DONE@" on
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 28 0 28 0 0 28 0 --:--:-- --:--:-- --:--:-- 77
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0curl: (6) Could not resolve host: on
15 Oct 07:06:09 - [warn] [mytimeout:Timer] L495: newMsg(inMsg): RangeError: Maximum call stack size exceeded <{"payload":{"domain":"light","service":"turn_on","data":{"entity_id":"light.master_bedroom_level"}},"_msgid":"2edeb051.06437","domain":"light","service":"turn_on","data":{"entity_id":"light.master_bedroom_level"}}>
15 Oct 07:07:21 - [warn] [mytimeout:My Timeout] L495: newMsg(inMsg): RangeError: Maximum call stack size exceeded <{"payload":{"domain":"switch","service":"turn_on","data":{"entity_id":"switch.arellys_bedroom_light_switch"}},"_msgid":"f535a518.a249f8","domain":"switch","service":"turn_on","data":{"entity_id":"switch.arellys_bedroom_light_switch"}}>
15 Oct 07:17:06 - [warn] [mytimeout:My Timeout] L495: newMsg(inMsg): RangeError: Maximum call stack size exceeded <{"payload":{"domain":"switch","service":"turn_on","data":{"entity_id":"switch.andrews_bedroom_switch"}},"msgid":"1137c255.0bbd7e","domain":"switch","service":"turn_on","data":{"entity_id":"switch.andrews_bedroom_switch"}}>
15 Oct 07:22:46 - [red] Uncaught Exception:
15 Oct 07:22:46 - ReferenceError: node is not defined
at client.launch (C:\Users\unpue.node-red\node_modules\node-red-contrib-cast\cast-to-client.js:73:13)
at C:\Users\unpue.node-red\node_modules\castv2-client\lib\senders\platform.js:95:20
at C:\Users\unpue.node-red\node_modules\castv2-client\lib\controllers\receiver.js:51:14
at fn.onmessage (C:\Users\unpue.node-red\node_modules\castv2-client\lib\controllers\request-response.js:27:7)
at emitTwo (events.js:131:20)
at fn.emit (events.js:214:7)
at Channel.onmessage (C:\Users\unpue.node-red\node_modules\castv2-client\lib\controllers\controller.js:16:10)
at emitTwo (events.js:126:13)
at Channel.emit (events.js:214:7)
at Client.onmessage (C:\Users\unpue.node-red\node_modules\castv2\lib\channel.js:23:10)
at emitMany (events.js:152:20)
at Client.emit (events.js:224:7)
at PacketStreamWrapper.onpacket (C:\Users\unpue.node-red\node_modules\castv2\lib\client.js:81:10)
at emitOne (events.js:116:13)
at PacketStreamWrapper.emit (events.js:211:7)
at TLSSocket. (C:\Users\unpue.node-red\node_modules\castv2\lib\packet-stream-wrapper.js:28:16)
at emitNone (events.js:106:13)
at TLSSocket.emit (events.js:208:7)
at emitReadable (_stream_readable.js:513:10)
at emitReadable (_stream_readable.js:507:7)
at addChunk (_stream_readable.js:274:7)
at readableAddChunk (_stream_readable.js:250:11)
