I've been encountering persistent errors with my Node-RED Docker container, specifically when trying to use BACnet protocol communication. Here are the commands I used to create the Docker container:
docker run -d -p 1880:1880 -p 502:502 -v node_red_data:/data --name FORGE nodered/node-red
Initially, the Node-RED dashboard functions correctly, but over time it starts glitching. The logs show repeated errors related to the node-bacnet-contrib-extended module, indicating a TypeError: Cannot read properties of undefined (reading 'values'). This occurs in the read-single-point.js file and seems to be tied to a timeout issue in the node-bacnet client library.
Below are the relevant log entries:
2024-07-08 21:20:23 exception -> TypeError: Cannot read properties of undefined (reading 'values')
2024-07-08 21:20:23 at /data/node_modules/node-bacnet-contrib-extended/read-single-point.js:203:52
2024-07-08 21:20:23 at /data/node_modules/node-bacnet/lib/client.js:778:21
2024-07-08 21:20:23 at Timeout._onTimeout (/data/node_modules/node-bacnet/lib/client.js:158:7)
2024-07-08 21:20:23 at listOnTimeout (node:internal/timers:573:17)
2024-07-08 21:20:23 at process.processTimers (node:internal/timers:514:7)
2024-07-08 21:20:23 value: undefined
2024-07-08 21:20:23 err: Error: ERR_TIMEOUT
2024-07-08 21:20:23 at Timeout._onTimeout (/data/node_modules/node-bacnet/lib/client.js:158:16)
I'd appreciate any guidance on how to resolve this issue or improve the stability of the Node-RED dashboard for production in large volume purposes. Thanks in advance for your help!
